Question about KitchenAid Architect® KEMS308S Electric Oven
KitchenAid KEMS308GSS0 ARCHITECH SERIES OVEN DOOR INNER GLASS REPLACEMENT? DO YOU NEED THE INSULATION TO REPLACE THE INNER GLASS IT IS NOT APPRENT FROM THE DIAGRAM WHETHER THE INSULATION IS FOR THE GLASS THE OR FOR THE DOOR ITSELF
3 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
you would need to remove the door (specific instuctions for each model generally in user manual "HOW TO REMOVE DOOR".. once off a few scews alow the bottom and top the outerglass w/ handle shloud release giving you access to clean
Posted on Mar 09, 2008
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
Replacing inner door glass kitchenaid kebc208ss
Click HERE for the service manual and refer page no. 21-22
This will solve your problem.
Goodluck,
Please don't forget to rate me as fixya..
Feb 16, 2008 | KitchenAid Architect Series KEBC208KSS...
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Replace inner oven door glass on kitchenaid wall oven
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
INNER GLASS REPLACEMENT FOR KITCHENAID KEM308GSS0
I took it apprt removing the door according to manufacturers in structions and I found out it only needs a peice of glass, so I put it back together and put the door back for now and I ordered the glass from a parts supplier on the interenet after I dentifying the part online from an exploded Isometric assembly drawing on the vendors site. When it gets here I will install it. very simple a teenager could do it. The big question is why did it crack inthe first place?
Dec 11, 2008 | KitchenAid Architect® KEMS308S Electric...
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
KitchenAid Architect® KEMS308S Electric Oven Logo
177 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
