Question about Crosley CDE6000 Electric Dryer
I replaced the heating element on my crosley dryer and also the high limit thermostat and also the control thermostat. dryer worked for a few minutes then quit working replaced the control thermostat again worked a few minutes then quit again. have completely cleaned out every aspect of the lint and exhaust tube please help me. It seems that the heating element is on all of the time and not going on and off.
  • Crosley Master
  • 8,220 Answers
The blower wheel is loosei replaced the heating element - 37859d6.jpga common problem on these dryers.
Posted on Jan 13, 2009
Dryer spns but there is no heat
probally the heeting element
Mar 10, 2015 | Samsung Dryers
Dryer runs but doesn't heat.
The high and Low thermostatic limit switches must be in working order for the heating element to get power to operate. High limit opens in the event of a overheat condition to cut off the heating element. The low limit cuts on and off to control normal operation of the heating element for a more or less constant heat for drying.
Mar 18, 2014 | Kenmore Elite HE4 Electric Dryer
No heat in dryer mode
In electric dryers, heat is generated by the heating element. The element is a coil of heating wire enclosed in a metal chamber. Electric current flowing through the coil creates heat and the air being pulled through the chamber absorbs this heat. If the element is defective then it will not heat. It can be tested with a multi-meter for continuity. Unplug the dryer and remove the front or rear panel to locate the element so it can be tested.
The high limit thermostat is a safety device mounted on the heating chamber and is designed to prevent the dryer from overheating when the exhaust vent is restricted. A restricted vent will cause the high limit thermostat to trip or activate, interrupting the circuit to the heating element or gas valve. The high limit thermostat is not designed to activate repeatedly like a cycling thermostat and will eventually fail causing a no heat symptom. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter. If there is no continuity then it will need to be replaced and the restricted vent system corrected as well.
Cycling thermostats control the temperature inside the dryer drum. They are designed to "cycle" the heating element on and off to maintain the correct amount of heat. Cycling thermostats are normally located on the blower housing or elsewhere in the internal airflow ducting. Over time, the cycling thermostat can become defective. Disconnect the power to the dryer and check the thermostat for continuity with a multi-meter.
Dec 02, 2013 | Splendide 2100 Vented Washer-Dryer
Model #CEDX563JQ0 Crosley Dryer won't heat and getting current
I would check to be sure you have 220v going to Dryer. Possibly timer problem as heat circuit runs through that too.
Aug 27, 2017 | Crosley Dryers
Kenmore dryer blows cold air. I replaced heat element still no luck? model 96263800
It doesn't necessarily mean the heating element is busted when an electric dryer stops heating. The heating circuit is not just composed solely by the heating element, it is composed by the thermal cut-off, high-limit thermostat, cycling thermostat, motor centrifugal switch, and the timer. The first thing to look at when an electric dryer stops heating is the thermal cut-off. It cuts power to the heating element when it blows most likely due to the failure of the high-limit thermostat. The thermal cut-off must be replaced, together with the high-limit thermostat, if found open. Click on the link below for the detailed instructions in troubleshooting this problem.
Troubleshooting Whirlpool and Whirlpool-Made Electric Dryers (Filter on Top and with Removable Back Panel) Running But Not Heating
Mar 25, 2011 | Kenmore Dryers
Dryer quit heating no power to element what is wrong?
The problem is most likely the thermal cut-off and the high-limit thermostat. The thermal cut-off blows when the high-limit thermostat fails and since these parts are wired in series with the heating element, power to the heating element is therefore terminated. Check the continuity of the thermal cut-off and if it reads open, replace it along with the high-limit thermostat.
You can bypass the thermal cut-off and the high-limit thermostat for troubleshooting purposes. Join together the wires of each part and insulate it properly then reconnect power. The two components indeed need to be replaced if the dryer heats up. If not and still no power to the heating element, check the continuity of the heating circuit. Check the continuity/resistance of the heating element if there's power to its terminals but doesn't heat. Replace the heating element if it reads open.
Let us know if you need further advice. Just indicate the exact model number of the dryer for accurate troubleshooting tips.
Jan 23, 2011 | Kenmore 700 6972 Dryer
Dryers tumbles but there is no heat
The problem is obviously in the heating circuit which is basically composed of the heating element, thermal cut-off, high-limit thermostat, cycling thermostat, and the motor centrifugal switch. The most common part that causes the dryer not to heat is the thermal cut-off and/or the high-limit thermostat. Verify this condition by bypassing the said components.
Disconnect power then access the thermal cut-off (cut-out) and the high-limit thermostat. Disconnect the wires of each component then connect them together and insulate it properly. Reconnect power then start the dryer. The problem is indeed in the thermal cut-off (cut-out) and the high-limit thermostat if the dryer heats up. Replace both parts and it should solve the problem. It is an easy and cheap repair to make. Indicate the exact model number of the dryer should you need further assistance.
Dryers with lint filter on the front.
Dryers with lint filter on the top.
Also bypass the cycling thermostat if the dryer still doesn't heat with the thermal cut-off and the high-limit thermostat bypassed. Check the heating element visually for obvious broken or damaged coil. An ohmmeter will be of great help in checking the resistance/continuity of the heating element. Replace the heating element if broken or damaged, NEVER attempt to repair it.
The problem is likely in the motor centrifugal switch if the dryer still doesn't heat with good heating element and the three components above bypassed. Indicate the exact model number of the dryer should you need further assistance.
Dec 31, 2010 | Kenmore 600 6965 Electric Dryer
Dryer will not run
Hi.
Check first the door lock, and the thermal fuse located at the rear of the dryer.
If the dryer does not tumble, then parts that must be tested are belt, motor, and control panel.
If the dryer does not heat , test high limit thermostat, element, control panel.
You can get parts and diagrams entering model number here.
Nov 13, 2009 | Crosley CDE6000 Electric Dryer
Thermal fuse location
the thermal is on the heater box on the right side it has two white wires going to it
you need to remove the high limit stat and bracket and the heating element to get to the safety stat
Jun 13, 2008 | Crosley CDE6000 Electric Dryer
Crosley Dryer Heats then stops
If im thinking right, this dryer has the element in the top left corner.  This unit has two thermostats, one mounted right above the element, and the other in the lower left front mounted on the fan housing.  The one in the front is called the high limit thermostat, which means when it gets to a preset high temp, it cuts off the system until cooling occurs.  The top thermostat, mounted above the element is the operating thermostat.  It probably is one of the two thermostats.  Its a very good idea to replace not only both of the thermostats, but the fuse as well.  The fuse kit (Maytag Part# LA-1053) comes with a thermostat and 2 fuses, be sure to follow he instructions on how to determine the fuse for electric and gas.  The high limit thermostat (Maytag Part# 53-0771) is an easy replacement.  Something is causing the unit to short cycle.  Sometimes you can hot-wire the operating thermostat (use caution, severe caution if doing this, not recommended if you arent sure whats going on).  By doing this (removing the two wires from the thermostat, taping them together), you can watch and see if the element stays on longer, at least until the high limit switch comes on.  This is really not recommended, if the high limit is out, it will not be good.  Just easier to replace them both.
Oct 24, 2007 | Crosley CDE6000 Electric Dryer
Crosley CDE6000 Electric Dryer Logo
153 people viewed this question
Top Crosley Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
