Question about Nikon N70 35mm SLR Camera
How to rewind film nikon n70 - Nikon N70 35mm SLR Camera
SOURCE:
devocap
  • 201 Answers
SOURCE: Isn't recognizing there is film
I will offer a solution under the assumption, that you are not familiar with this camera. Please ensure the film is loaded correctly extending the film all the way across to the orange line located on the right side near the winding post. This ensures the film is positioned correctly and will feed onto the post. Also the film advancer may need to activated by releasing the shutter. Hope it helps. Good Luck!
Posted on Jan 28, 2008
  • 20 Answers
SOURCE: location of rewind pin for nikon n6006 film camera
There is a safety switch to prevent accidental operation.  Hold the camera like you are taking a photo.  Rotate the camera down so the lense is pointing towards the floor and you are now looking at the bottom of the camera.  On the right is a small button.  In the middle is a slide switch with an arrow pointing to the left.  You need to hold in the button on the right while sliding the switch to the left.
Posted on Feb 05, 2009
  • 13 Answers
SOURCE: FILM WILL NOT REWIND
On the N80 - there are custom functions you can set in terms of when a film rewinds. Normally it is default to rewinding automatically at the end of a film. If this setting has been changed, or you want to rewind a film before the end - you need to press two buttons and hold them, at the same time.
The first button is the LCD backlight button next to the LCD, and the second is the flash sync button on the rear of the camera. Both should have a little red film symbol on them. Press them both and hold them, and the film should begin to rewind.
Posted on May 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: Film door on Nikon N70 will not latch!
There is a little spring inside the door latch that moves when you slide cover switch. The spring may be worn out or fallen off. The only way to truely tell is to dismantle the door and switch
Posted on Sep 16, 2009
Testimonial: "Thanks for the info. Do you have instructions on how to do this?"
lillwolf
SOURCE: My Nikon N2020 will not open to insert film
life up on manual film rewinder to release the the back to load film
Posted on Dec 26, 2009
I have the same problem. An N70 with the err message. If the rewind buttons are pressed (without any film in the camera) the camera tries to rewind but will only stop if the back is opened. I tried...
The Err message alone indicates that a malfunction has been detected, and the manual recommends to fire the shutter and check for the message to clear. If it does not, to contact a Nikon Service Rep.
If it is Err + E, the film did not advance properly and needs to be reloaded.
May 03, 2011 | Nikon N70 35mm SLR Camera
Is there a manual rewind on nikon n65?
If by manual you mean turning a crank to rewind the film, no. If you mean to do it at a point other than the end of the roll, yes.
To rewind film mid-roll, press the two film rewind buttons simultaneously for approximately one second. The film will then rewind and the frame counter will count backward. The film is completely rewound when the E appears in place of the frame number.
The two film rewind buttons are marked with a red film canister symbol with left-pointing arrows. One is the exposure compensation button next to the control panel, the other is the self-timer button next to the mode dial.
If you need a manual, you can download one from
http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
Jan 21, 2011 | Nikon N65 35mm SLR Camera
I have a NikonN70, how do i unload the film?
Slide the camera back lock release down, open the back, and pull out the film cartridge. Full instructions are in the manual. "LOADING FILM" is on page 16, "REWINDING FILM" is on page 24, and page 25 shows how to remove the film.
http://butkus.org/chinon/nikon/nikon_n70/nikon_n70.htm
Oct 05, 2010 | Nikon N70 35mm SLR Camera
How do i rewind the film in my nikon n2020
Set the film advance mode selector to L.
While sliding film rewind lever, push film rewind button.
Fold out film rewind crank and rotate until film advance indicator stops moving.
If you don't have a manual, you can download one from http://www.butkus.org/chinon/nikon.htm
Feb 13, 2010 | Nikon N2020 35mm SLR Camera
How to open filnm compartment of old 35mm nikon
Is it an SLR model?
I am not familiar with Nikons; however, Minolta and Canon SLR film camera's film compartments are opened by lifting up on the film rewind mechanism on the top left side of the camera.
If the Nikons are designed like Minolta and Canon, there will be a small tab to push in at the bottom of the camera. This releases the film and allows it to be rewound. At the top left will be a small rewind lever that is used to do the rewind. The part of the camera that the rewind lever is attached to is pulled up to open the back of the camera.
Oct 14, 2009 | Photography
Jul 29, 2009 | Nikon N2020 35mm SLR Camera
Don't know how to open door latch on nikon 35mm SLR camera
You haven't stated which model you have, but generally most SLR's open by pulling upwards on the film rewind crank (the knob on the left side of the top-plate as viewed from behind). If this doesn't work then add the exact model as a comment to my answer and I'll try to give you specific instructions for your model.
Jun 15, 2009 | Nikon N70 35mm SLR Camera
May 21, 2009 | Nikon N80 35mm SLR Camera
Don't know how to rewind film
Hi there.
The film should auto rewind when it reaches the last picture and its been taken.
Take a look in the camera's menu.
Good luck and thanks for using FixYa!!
Can't rewind film
It should automatically rewind when the roll is at the end. For mid-roll rewind press both the rewind buttons simultaneously for about 1 sec and the film will rewind.
May 21, 2009 | Nikon F80 35mm SLR Camera
Nikon N70 35mm SLR Camera Logo
287 people viewed this question
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
