Vusys hd19a monitor wont power up and stays on standby
My hd19a monitor wont power up and wont bring up a picture and just stays constantly on standby.
2 Suggested Answers
SOURCE: vusys hd19a monitor is always on standby
Cut and paste from another site:
I was called to repair similar incident last week. A Compaq box (don't remember the model) with a 'smart' usb keyboard. By this I mean that the keyboard had a row of what I'll call hot buttons. The client had pushed a button with a moon on it causing the monitor to go into sleep mode. I suspect that whatever key you pushed had the same effect.
After plugging a known good monitor into the faulty box I verified that the box was OK. This left me to think the monitor itself had a problem. Plugged the suspect monitor into a known good machine.. and it worked fine!!!
Set machine and monitor to original configuration and still had no video. Decided that the monitor was too smart for its own good and maybe there was something in the monitors menu. Pushed and held the 'menu' button on the monitor for a few seconds and menu comes forward. Green power led also comes on (surprising me) so I powered up the computer and lo and behold the problem is fixed!
Posted on Jan 20, 2009
  • 34 Answers
SOURCE: on internet when moniter failed keyboard and mouse
Probably a power supply issue.
Posted on Dec 30, 2009
My tv wont turn on.Stays in standby.
Not knowing brand or model number someone is going to have to open the set and examine the power supply for damage, puffy filter caps and check voltage into and out of that board.
Dec 20, 2012 | Televison & Video
Power plug
Most LCD monitors use IEC sockets - these are 3pins sockets.
Power leads are available from computer shops and electrical stores.
Jun 06, 2010 | Microsoft Likom HD19A 19" LCD Monitor
I just bought a new flat panel LCD monitor to replace our CRT one and it goes into sleep mode on it's own while we are surfing or checking e-mails etc...We use XP Pro and do not allow the computer to...
The setup menu on your monitor needs to be changed. On most monitors there are buttons which you press in sequence, go through these buttons and you will find a monitor mode which allows it to stay on permanently.
Jan 04, 2010 | Dell E173FP 17" LCD Monitor
Vusys hd19a monitor is always on standby
Dec 11, 2008 | Microsoft Likom HD19A 19" LCD Monitor
My samsung Syncmaster 940mw wont turn on when the pc is turned on
Your needs internal servicing by experienced person. Capacitor or ERT may be malfunctioning
May 25, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
I have a vusys monitor and for some reason when i plug it in to my computer it displays a message "out of range" and i recieve no picture any solutionfor this please?
Either
1.) The resolution/frequency your computer is currently running at is a higher resolution then the monitor can handle. Use a different monitor, if it works then lower resolution and replace with the vusys.
2.) You have physical failure. Your video card, cable, or monitor is bad. (Or you don't have it plugged into the right card). Try a different monitor if it works then and you did step one, then you probably have a bad cable or monitor.
Apr 30, 2008 | Computers & Internet
Monitor wont come out of standby
You got two outlooks, a fried motherboard or a fried component. If you have integrated graphics then its probably your motherboard, if you have your own, separate graphics card installed then it could have to do with your graphics card.
Google is your friend. It might not be damaged hardware, just some bug.
Jan 05, 2008 | Abit IC7-G Motherboard
Monitor problem
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Dec 27, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Monitor Start up
It is the same problem I experienced and now it suddenly stopped and dead.
what the manufacturer of the unit has to say about inherent design fault which they are liable under UK consumer law to rectify within 6 years
And incidently who are manufacturer to this Licon make is please
Jun 29, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Computers & Internet Logo
47 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
