Question about Kitchen Ranges
I have a Frigidaire Gallery gas range and oven #plgf389aca
It appears that my oven is taking an exteamly long time to reach its set temp. For example yesterday I set the oven at 400 degrees at 4:00pm and at 5:00 pm my display indicated it was still pre-heating. I have checked the temp. with a oven temp gauge and found it is reaching its desired temp. with in the normal time, but for some reason the oven isnt reading the oven temp and displaying it properly. What part in this oven is defective based on my explaination.
  • Anonymous Dec 26, 2008
    I have the same problem.
I need to shut off the self cleaning on my stove.
Posted on Dec 24, 2008
OVEN TEMP AT LEAST 75 DEGREES COLDER THAN IT IS SET AT .CAN I ADJUST THIS FRIGIDAIRE GAS RANGE GALLERY SERIES SELF CLEAN ,CONVECTION OVEN .
I appreciate your post, Ronald!
From the information you have provided you would like to calibrate the oven temperature on your Frigidaire range. I was unable to locate any instructions on how to perform a calibration on your oven. I would recommend consulting with a professional technician for proper calibration of your range. I hope this information is helpful. -Matt
Jan 01, 2015 | Frigidaire Kitchen Ranges
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
Lost manual for Frigidaire gallery gas oven. need to know how to use convection baking
What model Frigidaire oven do you have? Most Frigidaire manuals are available from the manufacturer's site: http://b2b.frigidaire.com/support/manuals.asp or http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/ . Note: these manuals are in the PDF format; you will need Adobe Reader or a similar program to read them.
For example the User's manual for the FGGF3054MW range (with convection oven) is available at http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316901218en.pdf .
I hope this helps.
Apr 13, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Frigidaire gas range broiler element does not light.
glow plug needs to draw 4 amps to open gas valve even if it red hot ...not drawing 4 amps replace glow plug
Aug 22, 2009 | Kitchen Ranges
Oven does not maintain temp.
It sounds like a thermocouple problem. While using the broiler, you gave the gas set to full and the thermostat is basically out of the loop.
Feb 20, 2009 | Frigidaire FGF316 Gas Kitchen Range
Frigidaire Range - Oven does not work
If your ignitor looks real dull orange then that is what is wrong. It needs to be bright as the sun or it is weak.
Dec 18, 2008 | Frigidaire GLGF386DC Stainless Steel Gas...
Frigidaire Gallery Professional Series - No clock/oven functions
i have an old model of the fridgedare gallery professional series stove. After self cleaning, the ignition sparks for the burners will not come off, they keep clicking and only stops when i pull out the plug. can you help me with this situation?
Nov 01, 2008 | Frigidaire FGB24S5A Gas Single Oven
Frigidaire gas range oven does not go up to correct temperature
It sounds like the thermostat is off. This would be the first place I would check.
Sep 28, 2007 | Frigidaire FGF316 Gas Kitchen Range
Kitchen Ranges Logo
367 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
