Question about Pioneer AVH-P4000DVD Monitor
Pioneer p4000dvd hye i have the same problem as agenore, what do i do? it doesnt play in park, with e brake up, down car on off... help!
    Problem Solver:
  • 5 Answers
Now this is ONLY in the case that you have done the bypass or at least grounded the handbrake cable properly to get past the warning screen and nothing else works.
I took mine to a technician that went through the settings, found nothing wrong, except for the fact that it won't play video. What he did afterward was open the unit up and checked out inside. Apparently there was just some little plug that got loose and/or fell off inside. This probably happened during shipping or could have happened if someone dropped the unit I guess. Anyway he re-plugged the little plug inside and it worked fine. I'm still to pick it up and test it myself but this is what I was told today so just thought I'd share it with you guys. Maybe that's what you guys need to get done.
Please note that if your unit is under warranty (like mine WAS), this would pretty much void it.
Posted on May 27, 2009
Parking brake
better check on your dc wiring system make sure u have fixed them tightly
Sep 09, 2009 | Pioneer AVH-P4000DVD Monitor
Dvd player to work while in motion
This can be done with a toggle switch or a relay.
**Toggle** Connect one side of a toggle switch to a ground and the other to the light green wire on the unit (parking brake input). Once the vehicle is started, just flip the toggle and apply ground. Taa-daaah.
**Relay** (see image)** This will bypass the parking brake automatically every time.
Aug 03, 2009 | Pioneer AVH-P4000DVD Monitor
I have a pioneer AVH-P4000dvd 2 din in dash dvd player. I hooked it up right, I did not do the by-pass, I hooked it up to the e-brake. When I play a dvd I get audio but no video. I have full control of the...
push in the driving brake. while holding in the brake , engage the parking brake. disengage the parking brake.then repeat this step again. a notice should pop up and you should be fine after that. I put one in a F-350 and had the same problem.
Jun 27, 2009 | Pioneer AVH-P4000DVD Monitor
It wont play dvds or any kind of video
Having the car in "park" is not the key. The unit needs to see a 'ground' on the light green wire that attaches to the parking brake. (see manual). You can get around this by installing a toggle switch OR a relay that will user the 'amp remote' wire as the trigger.
May 28, 2009 | Pioneer AVH-P4000DVD Monitor
THE SCREEN WONT TURN ON
it might be hooked up so that you have to have the parking brake on while you play dvds or you might have to turn your dimmer all the way down for it to play while driving. does it play the audio and everything when you put a dvd in but wont displau if so then that is your problem.
May 05, 2009 | Car Audio & Video
Im trying to bypass parking brake switch for pioneer AVH-P4000DVD. I already connected it to ground and then to power, but none of it works. I know that if i Install a toggle switch with 12volt current and...
This what you do. Connect the video wire to a power suppy and install a switch in the power wire. When you put the DVD in and the warning comes up, turn the switch on then off. This will allow you to watch the DVD without the park brake being applied.
Mar 21, 2009 | Pioneer AVH-P4000DVD Monitor
No video from ipod
Do you have the green cord that attaches to the parking break hooked up?
This stereo is designed so that you cannot watch videos while driving, therefore you need to have the parking break on in order to get video.
when you play a dvd with out the parking break on, you will only get sound.
Mar 18, 2009 | Pioneer AVH-P4000DVD Monitor
Watch a dvd while driving pioneer AVH-P4000 DVD
ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
Mar 03, 2009 | Pioneer AVH-P4000DVD Monitor
agenore have you solved this problem yet? If not I know how you can get past this.
matt
Nov 12, 2008 | Pioneer AVH-P4000DVD Monitor
Pioneer AVH-P4000DVD Monitor Logo
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
