Question about ViewSonic PJ755D Multimedia Projector
Image flickers I just replaced what I thought was a bad bulb because the image flickered. New bulb, same problem. I dusted the unit because I understand dust will sometimes cause issues. Also, the unit makes a slight popping sound on occasion. Any recommendations? I am having a difficult time getting an answer from Viewsonic.
    President:
  • 3,130 Answers
It sounds like the socket that the bulb goes into has an intermittant connection problem, or where the wires attach from the bulb socket to a plug or printed circuit board connection, or possibly a bad connection in the bulb driver circuit. Good Luck.
Posted on Mar 19, 2007
TV wont turn on after dusting
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Take it to a repair shop.
Apr 08, 2014 | Scott LCT37SHA TV
I have what looks like black sots/dust on my projected image. I thought it might have been the bulb but after replacing and cleaning the color wheel i am still seeing the "dusty" image.
Hi Jay,
It sounds like you are having some issues with the polarizing plates. If you are in the US, I can have one of our technicians speak with you. Feel free to check out our website and send us a message. Projector Repair Bulb Replacement
Jan 27, 2014 | InFocus IN104 Projector
Mitsubishi wd-65738 flickering
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
May 25, 2017 | Mitsubishi WD-57833 57" HDTV
Projector picture flickering
Dusting is not going to help. I could be the lamp if it happens with no input hooked up.
Dec 05, 2012 | NEC NP200 Projector
Flickering
Did you check your cable? if the connection is bad the image will flicker in and out.
Oct 24, 2012 | Promethean Board Lamp for PROMETHEAN PRM25...
My projector is flickering?
I have about 10 of these in the school I work in, most of them have gone mental flickering, my solutions has been to open the covers remove the bulb and carefully using a compressor blow all the dust out..This has worked and cured them in about 6 out of 8 cases
Nov 20, 2011 | NEC NP200 Projector
Infocus IN72 - blinking RED light
firdt off, did you reset the lamp counter? did you clean the dust out of the projector? it may be overheating as well. if the lamp looks ok, you may have just blown the ballast. try projector doctor online.
Mar 03, 2010 | InFocus IN72 Multimedia Projector
Picture flickers on Sony HDTV
Hi,It seems your ballast(board that powers light bulb) is going weak.The ballast was used to provide a lower voltage because lamp didn't use as much as brand new one. A newer one takes more voltage and when ballast doesn't provide as much power it will flicker or produce a dimmer image.I found the one for your tv here: http://www.discount-merchant.com/1091041-KDS-60A3000-p/1091041.htm?Click=48173 Good luck and God bless you!
Jan 06, 2010 | Sony KDS-60A3000 60" HDTV
Boot up problem
It is dust built up inside on the fan wheels. You wouldn't believe it but it is just dust. If you are mechanically and electrically inclined, take apart the housing and blow out the entire unit with compressed air especially all the vents and blower fans (my Optoma has 3). It'll work like new again. I was completely amazed.
Mar 24, 2009 | ViewSonic Office Equipment & Supplies
Proector image is dim
I have changed the bulb on my LG projector recently. I found the rotating colour wheel to be full of dust. Upon opening the cavity where the light is redirected and reflected onto the imager, I saw all mirrors also had a layer of dust. I don't think it was so dirty that it affected the brightness of the image, but I cleaned it anyway using an earbud. I cleaned both sides of the color wheel as well. You need to be careful in working with the optics of the projector!
Sep 05, 2008 | InFocus X1 Multimedia Projector
ViewSonic PJ755D Multimedia Projector Logo
778 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
