Question about SanDisk 2GB microSD Memory Card
Computer cannot detect 2gb microsd memory card
  • 1 more comment
  • jinesh_kn Dec 12, 2008
    pls give me solution
  • verod09 Jan 06, 2009
    my hp computer doesn't detect when i've inserted my memory card
    it worked perfectly fine before
    why did it stop working and what can i do to fix it?
  • mrsCULLEN Jan 30, 2009
    i have that same problem, it worked before, but now all of a sudden when i insert it to my computer it doesn't work. Also when i insert it to my phone it doesn't work.
  • 25 Answers
The best option is to buy a USB reader for SD cards. You can buy one at walmart, target, staples, office max, or anywhere that sells hardware. That will make it so it will read it like a USB and not like a card. They are fairly cheap as well. 5-10$?
Posted on Jan 01, 2009
How to show my music folder in laptop which is in sandisk 2GB memory card ?
Your music folder should be under your user folder. If you have music on your SD card, plug it into the computer and open "Computer". The laptop should detect the card and give it a drive letter. Open it and play the music directly from the card or copy it to your "My Music" folder and play from any media program. If this doesn't answer your question please elaborate on the issue.
Dec 29, 2012 | SanDisk 2GB microSD Memory Card
MEMORY CARD NOT SHOW........?
Hi. Nokia 3110 uses microSD card up to 2GB only. Please check the size/capacity of your memory card and make sure it is 2GB or lower. Higher capacity will not be recognized.
If your memory card is below 2GB, remove the card from your phone and use a card reader to connect that to any computer and see if you can see the drive. If your memory card appears in the computer but not on your phone, you may have a bad slot but if card did not appear in your computer, you may have to consider replacing the memory.
Good luck.
Sep 03, 2010 | Nokia 3110 Cellular Phone
My sandisk micro SD 2 GB card does not get detected in W760 mobile. Wat could be the problem
microSD card?
Sony cellphones don't use microSD, they use Sony memory stick micro (up to 4GB), Also called an "M2" card.
Oct 02, 2009 | SanDisk 2GB microSD Memory Card
Card not working
Plug into a PC with memory card reader and format it. If not, it is corrupt and needs replacing.
Aug 22, 2009 | PNY 2GB microSD Memory Card
Memory card cant be read My 4gb SanDisk microSD memory doesn't read on my computer. I bought it today at Radio Shack.
Are you using a card reader? If yes, you need to isolate the problem. Please follow the steps below:
1. Try connecting your memory card reader into different USB port of the computer.
2. Try using different card reader to see if there's a problem with the card or with the reader.
3. Connect it into different computer.
4. Remove and reinsert the MicroSD in the card reader and make sure that the card is properly seated.
5. If the card reader and the computer are working but still unable to detect the MicroSD, try to reformat the card.
6. If same problem persist, return it to the store and have it replaced.
Have a great day!
May 26, 2009 | SanDisk 2GB microSD Memory Card
2GB microsd Memory card not workin in vista
Put the microSD card into the device you are using and format it on there.
Sep 13, 2008 | SanDisk 2GB microSD Memory Card
SanDisk 2GB microSD Memory Card Logo
206 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
