Question about IBM ThinkPad R31 2656 Notebook
Trouble creating wireless access point from D-Link DI-514 router
My main router is a linksys 8-port wired. i would like to add D-Link DI-514 as wireless access point only for my laptops that have wireless capability. found a tutorial
http://www.tweaktown.com/guides/1575/3/using_an_old_router_as_a_diy_wireless_access_point/index.html
that seems more focused on converting an old linksys wireless router.
or the problem could be: (1) my laptops (ibm thinkpad R-31 and X-40) are a bit older and have wireless specs that are not compatible with the D-Link; (2) i'm doing something else wrong and just don't know what i'm doing.
just in case my laptop specs are not compatible, a friend gave me a belkin wireless network card (F5D8010).
any help would be greatly appreciated.
  • Barney Fife
    Barney Fife Dec 11, 2008
    i have 6 computers on my router and not all of them are wireless capable. only the two laptops. the 4 other desktops are older and don't want to invest extra cash in those older computers. they do what i need them do, so for now, i don't need/want to upgrade. i just want to be able to use the laptops in wireless mode.
  •  C. Dante
    C. Dante May 11, 2010
    Why don't you simply replace the Linksys with the D-Link?
  • 4 Answers
You should be able to plug the D-Link into any of the Linksys wired ports (not the Uplink port) and tell the D-Link to get an IP address from the Linksys router (as long as the Linksys router has DHCP turned on). Verify that both boxes are on the same network (192.168...) and don't have the same IP address. What happens when you do this? Can you get to the Linksys & D-Link from a wired workstation?
Posted on May 21, 2009
I want to change the pass word for the router dsl 605 ew
open any browser and type the default gateway address then log in to your modem set up by typing the current password there is a option maintainence or similar point to administration you can enter your new pasword and save settings by clicking on the button below it
Dec 06, 2010 | D-Link DI 514 Wireless Router (DI-514)
CaN you use a wireless router as a repeaters as well? I was not sure if this is possible. Thanks
Sorry to say that router are only access points, but there is a way to make as a repeater. You need to purchase another kind of hardware for this to work.
You can purchase a wireless bridge, configure it to talk with your existing router.
( if you don't want to share files between the main router and the secondary router ) wire the bridge into the internet port on your router.
that should do it.
Sep 18, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Can you connect more than 1 computer to it ?
Yes, either by wireless or LAN cable provived the D-Link has sufficient LAN ports on the router.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Sep 18, 2010 | D-Link DI 514 Wireless Router (DI-514)
I can't remember the security password i created
the password for the wireless internet or the password to access the router? If you can't access the router. There is a pinhole to reset it to factory specs. If you can still access the router but don't remember the security key. then just log into the router and make a new key.
Thank you,
Lee
Jan 08, 2010 | D-Link DI 514 Wireless Router (DI-514)
Wireless internet, form LAn port
Yes you can, that way the Wireless network and the wired network will be on the same LAN
Nov 27, 2009 | D-Link DI 514 Wireless Router (DI-514)
DI-524 wired/wireless access point
Just for fun, make the router give out IP addresses starting at 192.168.0.101 forward. Configure the AP at 192.168.0.2 with no DHCP (the host will give out the addresses), a netmask of 255.255.255.0, and a gateway of 192.168.0.1. Now, let the laptop find DHCP, or give it a 192.168.0.x address where x is greater than 2 but less than 101.
How lucky is that?
Carl
Nov 19, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
I want to encrypt my router so it cant be accessed by someone outside my house i have a d-link di-514 thanks
>Goto your router/modem settings
>Choose your wireless security and create a network(ie access code) key to provide security to your router from unauthorized access..
Aug 14, 2009 | D-Link DI 514 Wireless Router (DI-514)
DL-514 as a Passive Access Point
Generally - yes it is doable.
The problem is that if you want to use your 2nd router as an access point, it has to work as a DHCP server in order to get your security settings working (MAC address filtering, WEP etc.).
What you can do is that you give your first router (192.168..1) a DHCP range from 192.168.1.2 - 192.168.1.50 and your 2nd router(static 192.168.1.51) in the same subnet a range from 192.168.1.52 - 192.168.1.100. As long as they don't overlap, you should be fine.
Usually - and you're right here - you would disable DHCP on the 2nd router in order ot not create IP conflicts, but if it has to serve as a wireless access point, it is in charge of wireless security.
Mar 12, 2009 | D-Link DI 514 Wireless Router (DI-514)
1. Connect a pc to the router using a cable (wireless won't work)
2. Open a browser and type in: 192.168.0.1
3. Login with username: admin password: (blank)
4. Browse around the menus until you find a setting similar to "use as access point" and select it.
5. Save settings and log out.
6. Connect a cable from a port on your main router to this router's internet/wan port.
Dec 11, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like 192.168.0.2
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
IBM ThinkPad R31 2656 Notebook Logo
144 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
