Question about Canon Speedlite 540EZ TTL Flash
Starblitz Flash with Canon Rebel "S" Film Camera
I came across a Starblitz 3600 DTZ flash gun with tilt head, and already own a Canon Rebel "S" film camera...
The flash works great... however as I might suspect, the camera and flash do not talk to each other...
There are many labelled switches on the back which I have no idea of their purpose, but I have tried every position and the camera doesn't seem to read it...
Also, on the front of the flash seems to be a small sensor for becoming a slave flash, but again, in every position of the switches while firing the on-camera flash, the camera isn't making the flash gun go off when directly in front of or off to the side of the camera... is it even able to be a slave, which would be my preference over an on-camera flash mount...
Thanks in advance...
Michael.
  • Anonymous Jan 11, 2009
    I have canon 400d and I got starbliz 3600dtz from my father. However camera and flash seem not to talk to each other.
  • asjapulk Jan 11, 2009
    Canon 400d and starbliz 36000dtz seem not to communicate between them. Flash has different settings however I dont have a manual to search their meanings.
markevans
  • 148 Answers
SOURCE: dark shadow on right side of picture
sounds like a shutter leaf dropping into the image. however, they are usually horizontal and more likely to manifest when in landscape mode. (horizontal, normal)
try using flash pointed up to ceiling.
also, could need to check for auto sync speed setting. usually 1/125 to 1/60. if its off, it could be catching the shutter in the wrong place.
check manual for settings for using flash.
mark
Posted on Dec 23, 2007
SOURCE: Canon Rebel XTi/EOS 400D
I made the mistake of putting ahotshoe protector from my old camera on the new EOS 400D. It stopped the flash from popping up. I took it off and things now work.
Posted on Mar 15, 2008
SOURCE: low battery warning
What type of batteries did you buy?
For digital cameras, you want to use batteries with high milliamp hour (mah) rating: "2500 mah" if they are rechargeable.
If you bought regular batteries, you want to use good quality. Look for the "e2" or "better for digital equipment" type.
Does the camera have a DC power plug option? Try taking pictures with it plugged in if it does. If it still malfunctions with power right from the wall, then you bought a bad camera.
Posted on May 13, 2008
trav1856
  • 57 Answers
SOURCE: Film Loading Error
This also happens to Yashicas often. (though instead of stirpping the film, it will rewind it back into the roll. Something's wrong with either the firmware or the drive system. It'll need to be taken to a camera repair shop, or you'll have to send it back to Canon for warranty service, if it's still within warranty.
Posted on Dec 04, 2008
futureloginn
  • 734 Answers
SOURCE: Canon Powershot A550 flash will not work it just blinks on & off?
Hi
There are several things that could cause this.
1- Check the battery door indicator switch under the battery door and beside the memory card slot. Is the little black switch damaged or missing? Try pressing down gently using a pen it with the door open and then press the power button. Does it turn on?
2- The fuse has blown and needs to be replaced. Offhand I don't recall where it is on the SD750 PCB or how hard it is to solder on a new one (depends on if its tricky to get at or not). Good thing is fuses are really cheap.
3- Other power problem with the PCB due to corrosion or impact damage. The PCB or 'motherboard' of the camera will need to be replaced.
Can I use Speedlight SB-50DX with Canon EOS Rebel Xti
It is not possible to use the Nikon SB-50DX directly on a Canon EOS Rebel camera. The Nikon flash gun hot shoe contacts do not match the Canon hot shoe contacts.
You can use the Nikon as a slave flash gun with a PC flash cord that matches the Nikon's flash contacts then connect the end of this flash cord to a flash trigger. The Canon's flash can then trigger the Nikon flash gun via the flash trigger.
Dec 27, 2011 | Nikon Speedlight SB-50DX TTL Flash
I have a Sunpak pf30x flash (ETTL II for Canon) and a 550d Canon but the flash will not work. the flash works on my Canon Eos 300 film. Help
Many flashguns deigned for film cameras - even really expensive ones - will not work with DSLRs.
I have a perfectly good pentax gun that cost me almost £300. It is fanstastic on my TOTR Pentax SLR but will only blat at maximum power on my Pentax DSLR. I had to spend another almost £300 to buy the new gun that will work with all the bells and whistles on my DSLR.
It looks as though Canon work theirs the same way.
May 22, 2011 | Sunpak PF30X for Canon Flash
Hello, Please help me I love my camera! The last 3 rolls of film I have taken only the last half of the roll come out the first part of the film is black I'm only getting half of the pictures I take. It's...
Most likely this is a shutter problem. If you are using flash and getting the half pictures, then make sure the flash is a canon compatible flash and the synch is set to 60th. If the problem is all the time including non-flash pictures, then the shutter will have to be repaired.
Mar 26, 2010 | Canon EOS Rebel GII with 35-80 lens 35mm...
Can i use my sunpak 4000af with my canon rebel t1i?
The Sunpak PZ 4000 and 5000 were made for film cameras. I have one for my EOS film cameras. It works just fine. I know this series of flashes was not made for the digital cameras. It likely will not harm your camera if the flash is designed for your camera brand. But some functions will not work.
For example, do not use a flash for Minolta on a Nikon.
You risk damaging your cameras electronics or frying the flash.
Get their PZ 20, PZ 30, PZ40 or PZ 42X for your digital camera.
Sep 30, 2009 | Sunpak PZ 4000AF for Canon TTL Flash
The flash attachment fades out photos on my Canon Rebel digital
set the flash in A mode if not set camera aperture close
Aug 01, 2009 | Canon Speedlite 540EZ TTL Flash
Black line across top of all my developed pictures
You have light leak somewhere to the film.
Usually from the bad film door seal.
Mar 29, 2009 | Canon EOS Rebel GII with 35-80 lens 35mm...
Flash on a canon rebel 2000 eso
Just push the flash back and it locks ,...... thats flash off
Oct 14, 2008 | Canon EOS Rebel 2000 with 28-80 lens 35mm...
Eos camera not taking pictures on film
Do you use compact flash type II (microdrive) wich is not compatible?
Sep 21, 2008 | Canon Cameras
Canon Speedlite 540EZ TTL Flash Logo
414 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
