Question about Kodak EasyShare Photo Printer 500
Easyshare 500 printer
The paper will not load in the printer. It makes the noise and the thing rolls but it doesnt pick up the paper it says that there is no paper in the tray. I added a new cartridge and now the cartridge wont come out when I press the button.
Be sure the paper tray is full.  Though not a satisfactory solution, I've found the little steel tab that lifts the paper up to be grabbed by the roller just doesn't lift it far enough.  I keep the paper tray full.  Now I only have the problem if I let the tray get down to only one or two sheets.
Posted on Dec 20, 2008
Won't load paper
Clean the paper feed with alcohol and a paper towel by rubbing and rotating the drum. Wait for it to dry completely then it should grab the paper. Also make sure paper is free from dust. Good luck!
Jan 25, 2013 | Kodak EasyShare Photo Printer 500
Printer Dock 3 Print Problems
Unfortunately you may have to force feed the paper through as the printer is trying to pull it, it works but you have to stop pushing once it takes the paper!
Jan 04, 2012 | Kodak EasyShare Printer Dock Series 3
My pictures are coming out with pink or purple streaks. Every time I print a picture, the streaks are in different places, all going from bottom left to top right . I have changed the ink roll and the...
Try cleaning the paint roller.
6 Care and maintenance
Cleaning the paper feed roller To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the paper feed roller clean. Inspect the roller weekly for debris particles, and clean if necessary.
IMPORTANT: Unplug the power before cleaning the paper feed roller.
spacer.gif spacer.gif spacer.gif spacer.gif 1.Unplug the AC power cord from the power outlet.
2.Remove the paper tray from the photo printer, and leave the paper tray door open.
3.Lightly moisten a lint-free cloth with water.
IMPORTANT: Do not use cotton or cotton swabs to clean the paper feed roller.
autourg00462006id1604162.jpg 4.Use the moistened cloth to gently wipe clean the surface of the paper feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
5.Allow the paper feed roller to fully dry before reconnecting the power.
Click below for the complete manual:
Kodak EasyShare Photo Printer 500 Manual
Hope this helps.
Zeppelinx12
Mar 11, 2011 | Kodak EasyShare Photo Printer 500
My printer, HP injet 1410, could not pick up the paper. Can you tell me what the problem is.
I assume the printer is making noises and moving, TRYING to pick up the paper...
If so, there are 3 possible issues:
1) you have too liittle paper in the paper tray. Add more paper so that the tray is full to around 3/4, not less.
2) You may have too much paper on the tray. Remove some paper from the tray untill the tray is around 3/4 full, not more
3) The rubber rolls that pick up the paper may be dirty with paper dust or dirt. Put 2 drops of alcohol on q-tip and carefully clean them. Let dry 30 mins. before trying to use the printer.
Mar 26, 2010 | HP PSC 1410 All-In-One InkJet Printer
Not feeding the paper
inside the printer has to be a roll that takes the paper and get's it into the printer try to wipe that roll with some technical alcohol, i hope this helps you.
Jun 17, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I have an Easy Share printer dock series 3 that has paper loaded
To prevent misfeeds and to make sure your pictures look their best, we recommend that you keep the feed roller clean. IMPORTANT: Unplug the power before cleaning the feed rollers.
  1. Unplug the AC power cord from the power outlet.
  2. Remove the paper tray from the printer, and leave the paper tray door open. IMPORTANT: Do not use cotton or cotton swabs to clean the feed roller.
  3. Lightly moisten a lint-free cloth with water.
  4. Use the moistened cloth to gently wipe clean the surface of the feed roller. Advance the feed roller with your thumb as necessary, and continue cleaning.
  5. Let the feed roller dry fully before plugging the AC power cord back into the power outlet.
  6. Insert the paper tray into the printer, then press the Print button to resume printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Dirty rollers? I had the same problem and think the rollers are no longer sticky enough to pick up the paper due to a coating of dust... maybe cleaning the rollers would work?
Jan 28, 2009 | Kodak EASYSHARE Plus Series 3 Thermal...
I have an a1530cs copier. It will not pick up any paper when the button is presseed . it just makes a noise (low vibration) like it is wanting to pick-up .can you please help me?
Most such printing problems stem from incorrect paper types or paper loading. Make sure that your paper is loaded properly, and that the paper type is made for your specific printer.
If paper is not feeding properly into the printer, the problem may stem from hardware failure. Check the feed assembly to see if all the parts are in working order. You may be able to manually advance the paper in order to see which component may be failing. If necessary, clean the paper pickup rollers to make sure the paper path is free of sticky dirt and debris.
Apr 04, 2008 | Office Equipment & Supplies
Out of Paper
make sure that the paper is kodak xtralife with perforated tabs, otherwise the printer will really not pick it up and if it would - it's gonna be a really bad print
detach all the things that are attached to the printer.
grab a piece of lint-free cloth, wet the other end and leave the other end dry
clean the roller horizontally
use the dry end to dry up the roller and watch for water build ups
have at least 10 photo papers in the paper tray
slide the paper tray back into the printer
plug the printer onto the wall outlet, wait for the initializing sound
put cam to the printer dock
print a picture
Jan 20, 2008 | Kodak EASYSHARE CD33 & Printer Dock Series...
Kodak EasyShare Photo Printer 500 Logo
249 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
