Question about SanDisk Sansa e260 MP3 Player
My Sansa E260's screen is white and it won't turn off
I had it plugged into the computer and disconnected it while it was charging, then the screen went white and nothing is working. Any suggestions?
After leaving it on all night and running the battery down I plugged it back in, it charged and everything is working fine. The morale of this story is, don't unplug it from the computer while it is in use.
Posted on Mar 31, 2007
5 Suggested Answers
SOURCE:
SOURCE: My Sansa E260's screen is white and it won't turn off
you have to hold down the power button for 13 whole seconds. I have had the same thing happen to mine and I dont know if there is a permanent way of fixing it but that should turn it off so you can turn it on again.
Posted on Apr 14, 2008
monopogo77
SOURCE: computer(s) wont recognize sansa e260
i have the same SANSA e260.....and the same problem....its easy just turn on your sansa then push the menu botton, slide the wheel in the center and at the end of the options say USB enter there and change usb mode from MTP to MSC mode.....and ready
Posted on Jan 03, 2009
ah1f39
  • 34 Answers
SOURCE: the sansa e 260 fails to work properly
Make sure that the USB mde on the player is set to MTP. Update player to the latest firmware.
http://www.sansaworld.com/
http://www.sansaworldmp3.com/
Posted on Apr 05, 2009
anujtaluka
  • 392 Answers
SOURCE: Hi! My Sansa e260 won't turn on. It charges
try upgrading the firmware...if that doesnt help u'll need to replace the battery here's how to update firmware- http://kb.sandisk.com/app/answers/detail/a_id/306
Posted on Aug 15, 2009
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
Sansa e260 Problem
I have the sansa e260 with the same problem as well. Can someone help....Please!!!
Aug 05, 2009 | SanDisk Sansa e200 MP3 Player
MTP Mode Doesnt Work
Try uninstalling MTP Mode in the Windows Device Manager, and replugging the player - set the menu setting in the Sansa itself to "auto" for USB Mode before replugging. Let me know how it works.
Jun 13, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e260 Car Connection Problem
Since I haven't heard back, I am going to clear this from my queue
May 16, 2008 | SanDisk Sansa e260 MP3 Player
Apr 13, 2008 | SanDisk Sansa e260 MP3 Player
Problem with sansa e260
that happens to me too. i think the problem is that your computer can't like, sense that it's plugged in, so your battery's dying out, and the computer wont charge it
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Wont turn on
Make sure you dont have the device locked. There is a switch on the top of the unit
Jul 26, 2007 | SanDisk Sansa e260 MP3 Player
White screen only
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Apr 15, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
89 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
