Question about Video Cameras
Sony handycam dcr-hc53
Please help.
I've been following all the instructions and yet no luck. I'm trying to connect the camera to my laptop. I only have the cables that sony gives with the camera and I assume they're the right ones. It's a mini dv tape that my videos are on, but i'm also supposed to be able to do usb streaming but it's not working. When i connect the camera and turn the usb streaming on, with it plugged into the computer the computer makes the noise of a usb device connecting, and tells me new hardware is found etc.. but when i go to say 'my computer' and look for it there it's not there.. and the software that i received with the camera doesn't recognise the camera as being connected or anything.. and i don't know what to do or how to get my videos onto my computer for editing.
Please help!!!
Thank you!
I have the same problem but am not sure which i-link cable I need, a 4pin to 4 pin or a 4pin to 6 pin for the DVR HC53E.
Advice would be gratefully received.
Thanks a lot.
Tracey
  • 3 more comments
  • shiverhawk79 Jan 04, 2009
    i'm having the same problem as tracey
  • NICSTEV Jan 10, 2009
    i HAVE THE SAME PROBLEM, DID YOU GET A FIX FOR THIS?
  • Anonymous Mar 10, 2009
    i have same problem, i've tried 4-4pin 4-6pin usb, both xp and vista and still can't get to upload footage. i think there's a problem. grrr
  • roma_chavo Mar 20, 2009
    same problem
    any advice?
  • johncroxall Mar 21, 2009
    will not connect to pc running win xp ,
    inport from handycam software comes up with a warning triangle and
    says can not find handycam tape check link had it in every usb port ?
    no luck
    john
5 Suggested Answers
welcomejee
  • 10594 Answers
SOURCE: sony handycam dcr-hc53
I think you are using Windows Vista and facing problem to connect Sony DCR-HC53
Download Update for Picture Motion Browser software at Sony Support.
You need iLINK cable to transfer movie data in to computer. iLINK cable is shown in below picture.
You can have more info HERE about iLINK connectivity if you are running Windows XP in your laptop.
Posted on Oct 23, 2008
welcomejee
  • 10594 Answers
SOURCE: I have a Sony Handycam DCR-TRV22E Mini DV Digital camera and cannot get my PC to recognise it.
Go to camera menu and enable USB Stream, problem will be solved and PC will recognise your camera.
Posted on Jun 21, 2008
SOURCE: sony handycam dcr-trv19 mini dv
Because of the fact that Microsoft thinks they're so smart and released Windows Vista as their newest piece of ****, this camera will not work with Vista. The drivers for Windows Vista are non-existent. I went to the site for Sony and could only find XP drivers and 98 and 2000. They do not make them for Vista. And of course Vista should have most common drivers preinstalled, yet they don't have this one. I haven't found a way around it yet. I tried to get the drivers for Windows XP and install them. No good! It cannot be used on "this current operating system." Good luck. Hope somebody else finds an answer.
Posted on Dec 25, 2008
mail2pvs
  • 390 Answers
SOURCE: where to download software for my sony handycam DCR-HC22E Mini DV
you can download the applicable softwares from the following link
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRHC21
select the operating system from the dropdownlist below and if it is XP you have then select XP instead of XP SP2
cheers
Posted on Jul 15, 2009
SOURCE: where is the usb port on the sony digital 8 steady
Look on the front of the handycam. there is is a flap that will open, exposing the slots. Its right on the front...but sometimes hard to see. Its by the light and microphone. Hope that helps.
Posted on Dec 21, 2009
I have A Sony DCR-HC53 handycam, the tape wil not eject, how con I fix this?
This can be caused by several problems including a defective eject switch in the cameras internal circuitry or a bad motor. This will require disassembling the camera to repair and can usually be done fairly inexpensively. However, it's not really a user serviceable problem and should be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Aug 29, 2011 | Sony DCR-HC52 Mini DV Camcorder
Cnt install camcorder software
Try installing the PMB software from this Link.
http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4598&mdl=DCRSX40
Follow the exact same steps as mentioned under Download and Installation Instructions on the page.
If the issue persists, disconnect the Camcorder, turn it OFF, connect it to the Computer and then turn it ON.
Then continue with installation process.
Good Luck!!!!!!!!!!!!!!!!
Sep 16, 2009 | Sony Handycam DCR-SR40 Camcorder
How to save videos from sony handycam to my home pc
you need to put the camera into playback mode
then go into the menu and go to the setup menu
Then USB streaming and turn it on
That should enable the computer to recognize the camera
May 29, 2009 | Sony Handycam DCR-TRV140 Digital Camcorder
Oct 23, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
Vidio
You need "Picture Package" software supplied with Sony camera to transfer video files in to PC. If you have software CD, please install it and connect your camrea with USB port.
If you dont have CD, check following Sony official weblink to download USB Driver, though it will not give you proper control on file transfer procedure yet it do help you to connect camera with PC.
http://support.sony-europe.com/dime/camcorders/dv/dv.aspx?site=&m=DCR-HC19E&site=odw_en_GB&odw_model=DCR-HC19E
  • download.. Sony USB driver for Microsoft Windows.
Have nice day.
Aug 07, 2008 | Sony DCR-HC19E Mini DV Digital Camcorder
Jun 21, 2008 | Sony Handycam DCR-TRV22E Mini DV Digital...
Connect Sony Handycam DCR-PC5 Mini DV Digital Camcorder to my Laptop
try to install the cd software of your sony handycam into your laptop..
hope it will help thanks...
May 27, 2008 | Sony Handycam DCR-PC5 Mini DV Digital...
Instruction manual
from where can i download the user manual of sony handycam digital8 dcr-trv265e in my laptop for future security.
Dec 12, 2007 | Sony Handycam DCR-TRV265E Digital...
Video Cameras Logo
887 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
