Question about Dell 2161DS KVM over IP Switch (1P500) KVM Switch
Dell kvm switch
On kvm switch not listing the server list
i press print screen and twice scroll lock and space
but nothing work s
please help me
waiting for your reply thanks
I've had that happen when I've added some newer rev SIPs. The newer ones come with a notice to load the 2161DS with versions 2.0.13 or newer firmware; by unplugging the new SIPs and leaving just the older ones (and I'm at a loss as to the exact revisions) I got back the OSCAR prompts. Plug the SIPs back in one at a time, and they would display, but once the session timed out, the key sequence would do nothing once again. Don't know if this is what you have, but I do know that certain SIPs can interact with your firmware to cause this symptom - my bigger problem now, is that when I try to update with the newer firmware (d2_0_13_english.fl) I get a message: "Unable to upgrade the firmware. Reason: Incompatible file."
Posted on Apr 18, 2009
On model f1de108c, what does error code E7 mean? Yes I'm a newbe.
If you have this KVM device hooked up to a master surge or surge protector:
  • Power it down
  • Unplug the all kvm cables
  • Unplug power cable
  • Check the DIP switches and make sure they are all set to OFF position
  • Re-connect the power cable only
  • Press and hold the + and - buttons together for 30 seconds
The Bank Display should read, "15".
If it does not, then check to see if you are using converters or adapters on the KVM and/or Server End.
If you are, you'll need to remove them.
Next
  • Unplug the power cable
  • Set all the DIP switches to ON
  • Press and hold the + and - buttons for 30 seconds again.
  • Bank Display should be set to "00".
  • Connect your VGA, Kybrd, and mouse cable
You should now check and see the OSD coming up on the screen.
To get into the On-Screen Display (OSD) menu, press SCROLL LOCK, SCROLL LOCK,
SPACEBAR on your keyboard.
You should be able to see your master or server computer on the list.
Well the adapters are the main cause, its not that they do not work, but most of the times it causes the KVM to malfunction, hence not recommended. Apart from that if the KVM is connected to a surge master it causes the error.
But not to worry, now that we have reset the KVM it should not be a problem.
The + and - buttons actually releases the static current from the KVM.
Have a great day!
Jun 02, 2011 | Belkin OmniView PRO2 8-port KVM Switch
What are the keystrokes for a dell 582rr kvm?
Have you tried pressing Ctrl twice and then the port you want to control? I can't find the exact answer for you but here are few more;
1. Scroll lock twice and the port number you want to assign.
2. Numlock twice and the port number.
Same sequence as done with Ctrl key. (press Ctrl key twice and the desired port number).
Hope one of these will definitely work for you.
Good luck.
Thanks for using FixYa.
Jun 19, 2010 | Dell (582RR) 16-port KVM Switch
I am looking for the hotkey combination for our HP 336044-b21 KVM switch from a iogear KVM?
IOGEAR KVM switches uses Scroll Lock for the hot key. The models of IOGEAR KVM switches starts the letters "GCS". I don't think that your HP 336044-b21 came from IOGEAR.
Anyway, if that's an IOGEAR KVM switch, you may quickly press Scroll Lock twice + Enter (for two port KVM).
Scroll Lock twice + port # + Enter (for 4 port, or 8 port KVM).
NOTE: You need to verify the brand of your KVM switch by referring to the user manual of it.
Thank you and good luck!
May 20, 2010 | HP 336044-B21 8-port KVM Switch
KVM will only switch one way
Please make sure that the keyboard is hooked up on the KB port of the KVM. check underneath the GCS632U for the correct console port. you will see a keyboard and mouse icon. Make sure that the keyboard is connected to the keyboard port. tap scroll lock key twice to switch between computers.
May 13, 2009 | IOGear GCS632U 2-port KVM Switch
IOGEAR KVM SWITCH WILL NOT TOGGLE BETWEEN COMPUTERS
On my KVM switch it works pressing
Scroll lock key twice then
press up or down arrow
to toggle
Apr 11, 2009 | IOGear MiniView GCS612A 2-port KVM Switch
Freedom 9 kvm switch how do you switch from one pc to the other?
Press the Scroll Lock twice fast and then eith the up or down arrow.
Apr 06, 2009 | Freedom9 freeView 2UA (KVM02U) 2-port KVM...
Keyboard Sequence for Compaq 4-Port KVM Switch (Series 4115)
Mine uses the "Print Screen" for the menu & "Print Screen" + 1, 2, 3, or 4 for direct access.
Feb 13, 2009 | Compaq (147092-001) 4-port KVM Switch
KVM 2 PORT SWITCH
Yes try uninstaling the kvm switch reboot pc's install the kvm again and try another key and see if that works
Jan 29, 2008 | JustCom jc-102cp 2-port KVM Switch
What are the hot keys to switch between PC's?
You might try Scroll Lock twice followed by Up and Down Aerrows
Scroll Lock + Scroll Lock + Up or #1 or #2... and Scroll Lock + Scroll Lock + Down or #1 or #2 to switch b/w comps
Feb 15, 2007 | IC Intracom 156752 4-port KVM Switch
Computers & Internet Logo
749 people viewed this question
Alun Cox
