Question about Audiovox AVD300T Car DVD Player
PLAYER SAYS NO DISC
DISC INSERTED SAYS LOADING THEN SAYS NO DISC. CAN ANYONE HELP? THANKS!
  • 363 Answers
Try cleaning the lens first
Posted on Oct 01, 2007
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
Feb 28, 2012 | Toshiba SD-P1900 Portable DVD Player
Stopped playing after I inserted damp CD in 200 disc loading mechanism
this can be due to some moisture in lens.
leave the unit to get dry for 2 days.
Jul 04, 2008 | Kenwood DV-5700 Multi-disc DVD Player
I insert the dvd and player says loading, and then says no disk?
Ensure a disc has been inserted into the player. Verify that the disc being used is supported by the player. Clean the disc. Attempt to play a different, commercially produced disc. Remove the disc and leave the player on for a half hour to resolve the possibility of moisture condensation inside the player. If the issue is still unresolved, service may be required.
Jul 27, 2010 | Televison & Video
Dvd player says no disc when there is a disc in
Hi
Please check weather you have inserted the disc ,whose format is supported by your KOSS player.
If the formatt is not been supported /regonised by the player,It shows as NO DISC only.
check with some other disc which you previously played.If it plays the disc which you using has the problem.
Thanx
Jul 26, 2010 | Dynex DX-PDVD7 Portable DVD Player
Car cd player will not work
It sounds like it's not loading the disc propperly, it ejects immediatly yes? A mechanical loading fault.Try banging it as the disc loads..... not a cure but the knocking might dislodge something, it may have to come out and be fixed.
Apr 05, 2009 | Car Audio & Video
Jensen VM9312 not loading DVD.
If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
If the new disc does not work either , I would suggest resting the deck .
If reseting does not help , it is still under warrantee. so have it serviced.
Dec 11, 2008 | Jensen VM9020TS Car DVD Player
"no disc"
unscrew the unit try to clean the lense..this will fixya
Feb 04, 2008 | Cyberhome CH-DVD 300 DVD Player
Menu reads "Disc is dirty" and refuses to play disc when inserted
One note my friend don't buy SONY they have propriety tech on they're lenses that has poor Pickup on some CD\DVD's.
Sep 21, 2007 | Sony DVP-NS55PS DVD Player
SAYS NO DISC
Try playing commercial DVD instead of DVD+R or DVD-R.
Mar 06, 2007 | Audiovox AVD300T Car DVD Player
DVD Player stops in "Loading..." mode
1. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player. 2. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on. 3. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged. 4. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players. if nothing helps, call for service.
Sep 12, 2005 | Cyberhome CH-DVD 300 DVD Player
Audiovox AVD300T Car DVD Player Logo
122 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
