Question about Archos 605 WiFi Digital Media Player
Connection problem. I'm having the same problem, tried entering wep key for my router and get connection failed, also tried an open connection BT Openworld same message connection failed. Have you managed to solve?
  • dertuman May 11, 2010
    well, it turned out that my motherboard antenna wasnt sending a proper signal... with other connections it does work, like starbucks and stuff, or a normal house wifi connection. Try with other connections.
Don't know if this will work with this router, but witth my Orange router, I had exactly the same. I had to press a "pairing" button on the router when it was trying to connect to my Archos, and then it connected almost straight away. Otherwise, I could not connect.
Posted on Dec 16, 2008
Connecting android tablet to wifi
Network security key
Some later model wireless routers have the Password (ie.Encryption key) and the SSID already configured in the wireless router and this information is printed on a label on the bottom of the router.
These settings can be used to configure the wireless card and wireless adapters in your computer/laptop.
If these settings do not suit you, then it can be changed to suit your requirements.
The encryption key secures your data and wireless connection from unauthorized access.To configure the wireless settings in the router, connect a LAN cable from your computer to the wireless router, then open a Browser on your computer and enter the router's configuration IP address, then enter the admin login and password and then go to the wireless settings and configure the SSID and Encryption key.
The router's encryption key can be a Passphrase or the WEP or WPA or WPA2 key.If you use the Passphrase method select either WEP or WPA or WPA2 to generate the encryption key. You can enter the WEP or WPA or WPA2 key with 8 to 63 ASCII characters or 64 Hex digits.
Most people use Passphrase which is easier to remember eg. I was born in January 1988.
The strongest and latest security is WPA2, the weakest and oldest is WEP. To connect to your wireless router from the computer/laptop, configure the wireless card in your computer/laptop with the router's wireless settings ie SSID, plus the WPA or WPA2 encryption key. Then computer/laptops can communicate with your wireless router.
Nov 30, 2012 | Computers & Internet
When i try to connect my DSi to my wireless router the same error code keeps showing on the screen. the error code is 051100-1. any ideas?
That code comes up when the settings for your wireless router have changed since you last connected. Have you tried re-entering your settings? That should fix the problem.
Apr 30, 2011 | Nintendo DSi White Console
Keep having to enter the wep key to start ps3 then it times out saying the key is incorrect ? Recently changed from AOL to BT and console was working fine but now no service
Can I just ask, are you entering your AOL WEP key or your new BT WEP key? Just in case you didnt know your BT router will have its WEP key on a sticker on the back of the router. You need to go into network settings --> internet settings and change the WEP key that is registered to the system. It should then connect with no problem.
Hope this helps.
Aug 08, 2010 | Sony Playstation 3 (PS3) Console
What is the wep key? And how do I get on the internet?
A WEP key is your security key or Wireless Encryption Protocol key that you need to enter to allow you to access the internet thourhg your router. Usually when you have a new router the WEP key comes either on a sticker on the back of the router or on a card supplied with the router for instance BT HomeHub. To connect to the internet you will need to go through the connection settings wizard on the DS and when asked to input the WEP key use the security key supplied by your router.
Hope this helps
Jul 30, 2010 | Nintendo DS Console
My Linksys will not connect to my WII
Well the first thing is that you have WRT160N router. This router has issues with the firmware. So first you will need to upgrade the firmware of the router. Download the firmware of the router from the manufacturer's web site. Connect your computer to the router. Open the router page. Click on Administration tab. Just below administration you will find firmware upgrade subtab. If you click on it, you will find the browse option. Browse the file that you have downloaded from the web site. and Click upgrade.
For WII, you will also need to change the MTU to 1365 and open some port numbers on the router.
Apr 17, 2010 | Linksys WRT160N Wireless Router
In the middle of a connection, my husband's wifi connection was severed with a message that the settings were changed and a prompting that he type his WEP password. I am the primary connector to the...
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 31, 2010 | Computers & Internet
How do I get my WEP Key for my LINKSYS ROUTER
To access the web-based utility, launch the web browser on
your computer (INTERNET EXPLORER), and enter the Router’s default IP address,, in the Address field/bar. Then, press Enter. A password request screen will appear. Leave the User name field blank then default password admin. (You can set a new password from the Administration tab’s Management screen.) Click OK to continue.
The Internet Setup section configures the Router to your Internet connection. Most of this information can be obtained through your ISP/ your internet provider. Internet Connection Type Select the type of Internet connection your ISP provides from the drop-down menu. By default, the Router’s Internet Connection Type is set to Automatic Configuration - DHCP, which should be kept only if your ISP supports DHCP or you are connecting through a dynamic IP address. 68be046.jpg IMPORTANT: If you are using WEP encryption, always remember that each device in your wireless network MUST use the same WEP your wireless network will not function properly.
WEP Encryption Select a level of WEP encryption, 64 bits
10 hex digits or 128 bits 26 hex digits. The default is
64 bits 10 hex digits.
Passphrase Enter a Passphrase to automatically generate WEP keys. Then click Generate.
Key 1-4 If you did not enter a Passphrase, enter the WEP key(s) manually.
Click Save Settings to apply your chang
Nov 12, 2009 | Linksys Wireless-G WRT54G Router
Error Code 51331
Wii Error Code 51331 means there is a problem with wireless security.
Make sure your router’s WEP key matches the WEP Key you entered in the Wii.
If your router is using 64-bit encryption, the WEP Key must be 10 characters.
For 128-bit encryption, the WEP Key must be 26 characters.
WEP Keys can only use the characters 0-9 and A-F.
If your router allows more than one WEP key to be entered at a time, make sure the key you’re using is on slot one.
If you double checked the WEP or WPA key with the router and the Wii and they match, but you still receive the Wii Error Code 51331, then MAC filtering may be enabled in the router. You will have to add your Wii’s MAC address to the router’s allowed list. You can do this by logging into your router and going to the “access control, access list, or network filter” settings.
If you still have trouble with Wii Error Code 51331, try changing the wireless router’s channel to 1 or 11. This may increase download speed.
Check Nintendo’s router page for special notes on your router if available. Follow the instructions of the special notes.
Your wireless router must broadcast in mixed or b/g mode and cannot be set to “g” only mode.
If you still encounter the Wii Error Code 51331, try doing manually setting up the Wii’s internet connection. You can find your network information to enter into the Wii by doing this:
On your PC, click “Start” and then “Run.”
Type “CMD” into the field that appears to open a new window.
Type “IPCONFIG/ALL” and press “Enter” to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
Power cycle the wireless router and modem by unplugging both from the wall. After waiting a minute, plug the modem back in and wait another couple of minutes for the modem to initialize. Plug the router in and wait for the router to initialize. Now try reconnecting the Wii to Nintendo WiFi Connection.
Hope this helps a little
Sep 10, 2008 | Nintendo Wii Console
Trying to connect Wireless printer
Will it connect without security. Try it out and let me know what you get.
Jun 13, 2008 | 2wire 2700HG-B Router (2700HGB)
Archos 605 WiFi Digital Media Player Logo
127 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
