Question about Mitsubishi WD62627 62" HDTV
Mitsubishi WD-62627 HD - Replaced lamp & now display is crooked
Replaced the lamp on my 62" Mitsu 62627 last night and after finally getting the lamp into the housing, I powered it on and the display ahs a slightly lean from left to right which is very visible on stations like CNN or ESPN where there are graphics that remain on screen. It never did this previously and there's no way through any of the regular accessible settings (i.e. not the service menu) to correct. Anyone have a similar problem and if so, could you self-correct going through the service menu or did you have someone come out to fix?
  • hewillis Dec 12, 2008
    Just did this and it is still crooked. Reinserted and hand tightened and then reinserted & screwdriver tightened. Any other suggestions?
    Genius:
  • 1,199 Answers
The lamp is not placed in the housing in the correct position ( try slight adjustment on lamp wing-nut this must be done with your hands
this should fix ya
Posted on Dec 11, 2008
I have the WD 62627 model. the lamp light is on, when i power up the tv, it comes on for like 6 to 10 secs then it turns off. Does this mean I need a new Lamp?
I would say that it probably is a bad capacitor on the power supply board of the tv. What you want to look for is any round cylinders with the tops pushed up at all. The replacements are usually really cheap, it might also be the lamp, but usually when lamps go they go completely while a bad capacitor is known to cause intermittent problems that escalate into a tv only working for about 5-10 seconds.
May 03, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have the Mitsubishi WD62327 62". I just changed the bulb which I did last year on my own too. My problem is not replacing the bulb but now the tv does not want to turn on. This did not happen to me last...
You need to reset the timer lamp. On mine it is getting the display to lamp then hold the left and menu button for five seconds.
If that doesn't work go to the mitsubishi site and DL the PDF of your model and it should be in there unless you have the paper manual still around.
Aug 11, 2010 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi 62 inch, Lamp Problem
it sounds like the lamp is not seating right, make sure it is, try unplugging the tv instead of messing with the lamp if it powers on then you are better off calling a tv shop.
Dec 30, 2009 | Televison & Video
Mitsu WD62525 - replaced lamp & after startup, lamp light is solid red. Anything else I can do?
Try the V26 Power pwb repair kit at www.tvrepairworld.com that will usually repair the issue. The kit contains the parts and the CD with instructions
Nov 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replacement Mitsubishi lamp busted again in less a year!
A Halogen lamp is a Halogen lamp. They are designed to last between 3000 to 5000 hrs.
You got a much longer life than expected on
the original lamp.
Jul 22, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Crooked picture
Go into your view options in your menu and use the remote to center your screen.
Jun 03, 2009 | Mitsubishi WD-62528 62" LCD HDTV
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture on my 62" DLP Mitsubishi
I am not sure what the problem is, but usually if a lamp is bad, the other 2 lamps will still function. Since you are getting no picture at all, I am thinking it is a circuit board problem. TV electronics are expected to last 3-5 years. After that, many components will start to go out one by one. If you have your tv repaired, I would replace the whole circuit boards instead of just the bad component. The power board is the #1 board I would replace 1st. This is the most stressed board and will cause most of your tv problems.
Dec 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
No power - Mitsubishi 62" WD62525
you probably need to replace the lamp part #:915P020010. Hard to diagnose the exact problem without a more detail explanation on symptoms.
Sep 23, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62327 no pix and no sound
First do the self diagnosis test, search threads here or go to www.ctechnicians.com
Dec 03, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD62627 62" HDTV Logo
211 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
