Question about Dryers
Whirlpool dryer LEQ8000JQ3 does not heat up when drying
  • clara1972 Dec 11, 2008
    The machine is drying thru the normal cycle as used do! It takes over 5 cycles to dry the garments. Please advise.
    my email is clara@americanapparel.net or call 917.558.6063
    Is there a technician in the Manhattan area? Zip: 10003?
    Clara
  • Anonymous Jan 29, 2009
    did you get an answer, e-mail me at davidwjacobs@msn.com, thanks!
5 Suggested Answers
duby1990
  • 367 Answers
SOURCE: Whirlpool dryer LEQ8000JQ3 does not heat when drying
You can check which one you need to replace by using an ohm meater. You usually dont have to replace both.
Posted on Dec 11, 2008
  • 433 Answers
SOURCE: ELECTRIC DRYER, RUNS NO HEAT WHIRLPOOL LEQ8000JQ3
check the heater element and thermal fuses for continuety
Posted on Mar 17, 2010
hunter19_46m
  • 7482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please rate me, Thank you
Posted on May 13, 2010
TheMobilian
  • 8220 Answers
SOURCE: whirlpool model#LEQ8000JQ3 will tumble but not
Maybe what 5, 10 years old at the most. Unplug the dryer and look for air blockages. d404494.jpgThat will give you a clue if it is the heater element or the limits mounted on the heater chamber. Overheating causes these guys to kick out. 012813e.jpgThe dryer itself will still run. If their is severe blockage to the filter housing the thermal fuse will get in the act and kill all power to the dryer through the door circuit. You say it runs so ts get down to the nitty gritty. bc32dd7.jpgUnplug the dryer and take the back dust cover off. There you will find the heater and limits on the right and the filter chute and blower with thermal limit. Lets look at your heater1c9285f.jpgIt mounts on bottom and easier to take out than older ones was16e16c9.jpg
Posted on Jul 24, 2010
Electric Whirlpool dryer m11036334, dryer will not always heat
Sounds like a limit switch has broken. Doesn't sound too expensive to fix.
Nov 14, 2016 | Whirlpool Dryers
Whirlpool Ultimate Care 2 LEQ8000JQ3 w/ Accudry- how do I make sure the Accudry feature works properly when I replace element?
The orange wire mounted to the 250 limit at the base of the heating element connects to the timer motor. When the element is on the motor cannot move forward in autodry. When the element is off the timer motor slowly advances. that is how it works. If you small limit on top is blown you have a restriction in your venting system or a clogged filter chute or a bad cycling thermostat. I worked on one and did a video recently. ROPER DRYER NO HEAT VIDEO
Jul 08, 2012 | Whirlpool Dryers
Whirlpool model#LEQ8000JQ3 will tumble but not heat up. Vent is not clogged all the way out. Also how old is this dryer?
Jul 24, 2010 | Whirlpool Dryers
May 09, 2010 | Dryers
Mar 17, 2010 | Dryers
Whirlpool electric dryer will not run. breakers
It's more than likely either the thermal fuse, or the door switch.
Feb 13, 2010 | Whirlpool Dryers
Dec 11, 2008 | Dryers
Ultimate care II Whirlpool dryer
yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
May 24, 2008 | Dryers
Dryers Logo
232 people viewed this question
Top Dryers Experts
