Question about Dell Inspiron 300M Notebook
Computer won't boot into windows
Hello, My computer can't boot into windows. It gave an error "A Disk Error occured. Press Ctrl+Alt+Del to restart". Sometimes it gave blue screen "Unmountable boot volume" STOP: 0X000000ED." My computer was working fine until I popped in a DVD. Now, I can't even go into safe mode successfully. Dell said to get a new hard drive. If it was a hard drive gone bad, how come the computer doesn't work only when I popped in a DVD?
  • 3 more comments
  • alpines_97 Dec 11, 2008
    the computer died after I inserted the DVD. I don't think that it was a coincidence. Before this, I had the same problem when I inserted a DVD, but I could still go into safe mode and perform registry fix, antivirus, and spyware, and it got good again. FYI, I'm not good with computer, so please keep the explanations simple. :)
    I don't have the CDs anymore. It's what's called the startup disk, right?
    Will my data be lost if I run the startup disk?
  • skypass Mar 23, 2009
    blank screen on my lap top Del Inspiron 300m
    I close it yesterday fine now my lap top turn on,,but only a white screen,,,,
    I press F2 to go to the bios ( cant acces)
    I press ctrl-alt-delte ( nothing)
    I am in urgent need of my lap top,,,,,,,please help someone?
  • Rob Duron
    Rob Duron May 11, 2010
    so the computer boots up when the suspect dvd is not in?
  • 148 Answers
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Posted on Dec 11, 2008
  • 1 more comment
  • mookid Dec 11, 2008
    Please try the following. It is a little advanced, but I hope the instructions are clear. If you get stuck at any point contact me.
    Insert the Windows CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
    2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
    3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
    4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
    5.At the command prompt, type chkdsk /r , and then press ENTER.
    6.At the command prompt, type exit , and then press ENTER to restart your computer.
    This takes a bit longer, but the system should boot back into Windows.
    Yes, that's correct. Maybe ask one of your friends if they have a startup disk you could borrow.
    No, if it can do its job it will just repair the system files and settings.
I was running avast anti-virus while browsing using chrome when I tripped on the power cable and the system shut down. the next time I turned the power on, I got DISK READ ERROR OCCURRED PRESS CTRL+ALT+DEL...
Weird problem... situation may have nothing to do with what happened. Your hard drive may have core problems. I would run the BIOS diagnostics if able. Also, boot from the OS install DVD and get to a command prompt where you can run CHKDSK.
Good Luck,
Steve
Sep 26, 2017 | ASUS Eee Computers & Internet
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
Disk read error occurred, press ctrl+alt+del to restart, but it just takes me . ... press ctrl alt del to restart" problem, HOW TO SOLVE
Have you checked your bios to see what the system is configured to boot from first? Make sure your hard drive is the first boot device in the list.
Oct 28, 2013 | eMachines D620 Laptop
"A disk read error occurred Press Ctrl+Alt+Del to
Most likely the hard drive is failing, run diagnostics on the hard drive if you have a resource CD. Or you can download them from support.dell.com
Jul 21, 2011 | Dell Latitude C810 Notebook
Asus Eee PC 900 (white model) At startup, I get this message, "A disk error occurred Press Ctrl+Alt+Del to restart". When ctrl alt del is pressed it just takes it back into a loop and get the same...
Try presing F9 whilst booting(every other boot) to take you to factory restore pages select system recovery or discscan then press "E" then"B" etc and reset OS
Sep 10, 2010 | ASUS Eee PC 900 Notebook
Not booting. "disk read error occurred"
This means you HDD is either corrupt or faulty, try downloading a copy of Hirens BCD to try to access the HDD (or use and external HDD enclosure) and if you can, put it back in the laptop, if not reformat it and reinstall windows.
Aug 11, 2009 | Acer TravelMate 4200 Notebook
Problem with a disk read error
There are a couple of possibilities.
1. The hard drive is defective.
2. The operating system is corrupt.
The easiest way to test this is to run the restore cd that came with the computer to reload Windows.
If you get this error while running the restore cd then you will need to get a new hard drive.
Jan 03, 2008 | Computers & Internet
Dell Inspiron 300M Notebook Logo
400 people viewed this question
Alun Cox
