Question about Kenmore 62602 Electric Dryer
Kenmore Elec. Dryer Model 66912 (1996)
Dryer will not start when you push the "push to start" relay but there is a loud hum for about 10-12 seconds, then nothing. Occurs on all cycles, cannot push again until switch appears to cool. Continunity on thermal fuse, operating thermostat, thermal cutoff, and high limit thermostat all check closed. Could it be the belt switch ? Afraid it might be the motor, if so how do I go about to remove it ? Do I need any special tools ?
  • 1 more comment
  • skid521 Dec 21, 2008
    Same issue. Mine was making scraping noises first, like it needed lubrication. Have checked all connections and circuits in the back panel. Drum spins with some resistance, but can't get into where the motor is located.
  • Anonymous Jan 04, 2009
    same prob model 69838 need wiring diagram then I can fix it somebody please post it .
  • Anonymous Jan 30, 2009
    dryer only humms when the start switch is pressed.
  • 103 Answers
SOURCE: i have a kenmore he4 no. 110.85871400. i have no
Check thermistor with ohm meter, make sure you unplug unit first, make sure wires are removed from thermistor or you will read ohms thru the wiring. If thermistor checks ok, the you have a relay board problem. replace power board.
Posted on Oct 01, 2009
milten1
  • 1304 Answers
SOURCE: I have a Kenmore Mod # 110.63932102 electric
have you checked the heat selector switch on the control panal
Posted on Oct 06, 2009
aasc
  • 1606 Answers
SOURCE: kenmore elite elec dryer, 110.64972300. runs no heat
Pull one wire off the element and start the dryer in a heat cycle . Check power from that wire to the cabinet . Touch the meter to the terminal you pulled that wire off of , and check that voltage . You cannot get correct voltage by checking across the element . Trace the wire NOT getting 120 volts . It will either go to the timer or motor . It will lead you to the problem .
Posted on Apr 28, 2010
erpaalai
  • 999 Answers
SOURCE: dryer wont start when button is pushed
Did you check the door switch? Electronic control could be an issue but start with the basics and you have covered most of them already... good job.
Eric
Posted on Jun 13, 2010
  • 385 Answers
SOURCE: I have replaced the thermal
Sounds like you have some sort of blockage either in the dryer itself or in the exhaust vent.The thermal fuse will blow if the air is not flowing enough.Hope this helps.
Posted on Apr 13, 2011
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore 80 series dryer makes loud humming noise when it is drying clothes think it may be a belt that needs to be replaced
More likely is that your motor is going bad...that will make a very loud hum when it starts to go...
DryerRepair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 07, 2010 | Kenmore 65924 Electric Dryer
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Drum turns hard after holding start button down and has a loud hum
that is a sign of the dryer motor going bad,it will fet to the point where it will not work at all just hum when you push the start button,time for a new dryer it's not worth fixing-mike
Apr 28, 2009 | Kenmore Dryers
No air...drum not turning...Kenmore elec.dryer # 110.62822011
does it make a humming sound if so you may have a bad motor os something stuck in the blower wheel
Jan 10, 2009 | Kenmore 62602 Electric Dryer
DRYER WON'T START WHEN START BUTTON IS PUSHED
if its a humming than a click,,wont start for a few mintues,,than the hum again ,,your motor is shot,,,replace,,onthejob
Jan 05, 2009 | Kenmore 62872 Electric Dryer
The problem is the motor switch . Try spinning the drum with the door switch held in and pressing the start button all at the same time .If the problem is lint in the switch that might be all you have to do . If that don't work you will need to replace the motor and no special tool required. I can walk you through it.
Dec 12, 2008 | GE WSM2700W Unitized Spacemaker Washer and...
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
Kenmore 62602 Electric Dryer Logo
124 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
