Question about Brother MFC-8840D All-In-One Laser Printer
Faxing - document feeder sends the paper through and continues spinning like their should be more papers to feed and there are not - then the red status light comes on. It will fax from the flat reader after I turn it off and back on.
There was a staple caught in the exit guide on the underside of the top lid. There must be a sensor in this spring loaded guide. I removed it and problem solved.
Posted on Feb 28, 2009
  • 215 Answers
Sounds like a sticky or bad sensor in the feeder. does it come up and say doc. jam? there is one sensor i had problems with that caused that. it is the sensor that tells when paper is on tray of feeder. if you look where you set paper to feed in, you can see a black lever. its actually mounted on center of tray. it might be sticking down after it feeds last sheet in. it should spring back up freely. if that looks ok, there are a couple of other sensors in feeder, but not that easily accessible.
hth,
razors
Posted on Jan 09, 2009
    President:
  • Brother Master
  • 990 Answers
Sound like paper pick up roller have problem, change it!
Posted on Dec 11, 2008
WHEN FAXING, PAPER WON'T FEED
Lift up the top cover and check the rollers for wear.
Jan 31, 2014 | HP LaserJet Office Equipment & Supplies
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
When faxing the paper does not automatically feed through..how might I fix this?
Try cleaning the feed rollers in the document feeder with water on a damp rag.
Jun 09, 2010 | Samsung SF-565P All-In-One Laser Printer
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Top ADF will not recognize paper in the feed tray.
Try to replace the 'paper is present' sensor with the 'cover open' one to see if now it is detecting the paper. Also, check the actuator that enter in that sensor.
Jan 16, 2009 | Konica Minolta bizhub 161f All-In-One...
Which way does the paper go into the feed when faxing?
Load the originals, with the print side up, into the document feeder tray. If you are sending a single-page fax, such as a photograph, you can also load the original on the glass. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jan 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Jamming of paper using the Automatic Document Feeder
You may have a really tiny paper jam. You need to open up unit to get access to feeder properly. Use a torch, jams can be so small you can miss them. cheers lilacgerry
Jan 28, 2008 | Brother MFC 6800 All-In-One Laser Printer
SCX-6320F Samsung
Dear ,
Do u need to pull out the paper or  it comes on it's know,
THE ADF SENSOR OR
THE ADF ASSEMBLY CABLE SEEMS FAULTY..
PLEASE REPLACE AND CHECK..
HAPPY FAXING/COPYING/PRINTING
OMNIPRESENT
Oct 10, 2007 | Samsung SCX-6320F All-In-One Laser Printer
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Brother MFC-8840D All-In-One Laser Printer Logo
87 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
