Question about Goodman CLQ36AR49 Air Conditioner
My goodman cental air system is having problems. First, the blower inside (furnace) keeps running for hrs after the outside condensor shuts down. Now, the condenser blower motor wont operate at full speed. I have replaced the motor and capasitor with no changes. Can anyone help with these problems???
    Novelist:
  • 199 Answers
The cause of your indoor fan running all the time or for long time after your heat pump has stopped heating is the fan delay relay. It has welded its internal contacts together. If you take off the side below the control panel, the fan delay relay is normally mounted on the header where the fan discharges. Good news, the fan delay relay are fairly inexpensive and easily to change.
As far as the condensing fan motor not running at full speed, when it was changed, did the technician install the correct fan motor. Most condensing fan motors are either 875 rpm or 1175 rpm. They are exactly the same size and if the technician did not look closely he could have installed the wrong rpm motor. There is another possibility, he may have used the wrong capacitor. I have seen the condensing fan actually operate backwards at a lower than normal rpm. The fan if properly installed will discharge air upwards.
Posted on Dec 24, 2012
SOURCE:
SOURCE: My Goodman GMP100-4 blower fan
Replaced capacitor and cleaned filter. Problem solved.
Posted on Jul 13, 2008
  • 18 Answers
SOURCE: Inside blower not starting every time
This should have a time delay sequencer for the blower in the a/c mode. These are bad about being interminent in the a/c mode and also in fan. I have had some that would freeze up and I would get there and the fan be running. Thaw out and check and everything be ok. Got to cycling the fan on and off and sooner or later it would get where fan didn't come on. After replacement the customer didn't have anymore problem. Check the rely, looks like a heat sequencer but mounted on plate to blower compartment.
Posted on May 15, 2008
meBNme
  • 334 Answers
SOURCE: Goodman Air Handler motor will not turn off.
Look at your Thermostat wiring.
If there is a green wire going to the "G" terminal, disconnect it.
If it stops running, you have a bad T-stat.
If it keeps running, you either have a stuck fan relay or a low voltage control wiring malfunction.
Those are usually related to one of the safety switches having problems.
If green is not going to G, let me know, and we will determine which one is indeed the fan wire and go from there.
Remember, when you rate the solution, it closes further dialog, so only rate when you are satisfied with the discusion.
Thanks for visiting FIXYA!
Posted on Jan 03, 2009
  • 687 Answers
You have a voltage bleed somewhere or a short, whatever you want to call it. Do you have a control board on this unit where the relays are integrated into it or do you have the old type where the relay is separate? Anyway, you need to take a meter and take voltage readings to the motor when it's acting up and when it's running right. I have had the same problem with a Goodman unit before and it turned out to be the tstat! What I would do is remove the cover off the tstat and take a small jumper wire and touch the r terminal to the y terminal. If the motor starts right up, you know it's the tstat. If you have the same problem, then the only thing it can be is a low voltage short to the unit from the tstat, bad control board if you have one, or a bad relay. But if the unit is working fine in heat, it's probably not the relay. I hope this helps.
Posted on Apr 09, 2009
relaga58
  • 158 Answers
SOURCE: Goodman CKL60-1 Condenser Fan Runs OK, then stops
check connections tightness or if you just change the connector will solve the problem that is if the motor has not burn out yet
Posted on May 28, 2009
Furnace running all the time.
Pull the thermostat off the wall. If the fan keeps running, it is a relay in the board or just an independent fan relay.
Dec 13, 2013 | Goodman Manufacturing Goodman AEPF313716...
1993 goodman status light 4 times blinking
Witch blower is running, the inducer or the systems blower?
System blower could mean the the high limit is opening and shutting down the systems gas train, I would check this out first.
The other problem could be with the pressure switch for the gas train, it is supplied from the inducer motor, check to see if it is operating fully.
HSI boards do go from time to time, this sounds more like a system control problem.
Jan 24, 2008 | Goodman GMS90703BXA Heater
After one heat cycle, the blower motor keeps running, even after cool down is complete. The furnace will not refire until i turn off the power and wait about 20 minutes for a reset.
your limit switch is opening up, that causes constant fan. Check for flashing codes after flame shuts off and fan continues. Check airflow, filters, lack on return air for possible hi temp limit problems.
Nov 17, 2011 | Goodman Heating & Cooling
Our furnace keeps shutting down soon after burner ignites inducer motor stays running wont heat until reset switch behind inducer motor is pushed
Sometimes a "Flame Sensor" gets carboned up and does not detect that the furnace has ignited, so it shuts down the fuel source. Might try cleaning that if so equipped.
Dec 05, 2010 | Goodman GPG152407041 15 SEER Packaged...
I have 3 goodman system but my goodman ckl30-1g, stop blowing cold air a few days ago. the inside unit attempts to start and the outside compressor fan runs just fine but no cold air is being pushed...
The fan may be running on the condensor, but; Goodmans usually come with a dual capacitor. A lot of times these fail and the compressor cuts off on the overload. Turn off the power and check for a bulging capacitor. It can still be blown even if it is not bulging. I get calls a lot of time with the same info you provided. Otherwise it can also be refrigerant or a compressor problem. If you have an overflow it will be located in the condensate line; But if that was tripped nothing would happen with your condensor. If you do see a visible Failure or you measure it with a meter. Check you microfarads and voltage. They are easy to chage just make sure you write down what wire goes where.
Jun 21, 2010 | Goodman CKL30AR30 Air Conditioner
My air stops running inside before it get to the temp. Its set for but the outside unit keeps running and after a minute or two the air will start blowing inside again but the outside unit never turns off...
you have a possible thermal overload problem in your furnace blower motor dirt will cause this problem when it doesnt allow air across the windings of the blower motor if not dirt the motors going bad and getting hot use a shop vac and eliminate dirt keep your filter changed and your evaperator a coil may also need checked for cleanliness this will require cutting into plenum my advice someone qualified and remember dirt kills
Jun 18, 2010 | Goodman CKL36AR36 Air Conditioner
My furnace heats the house well, but during the cool down it actually blows cold air dropping the temperature causing the furnace to re-ignite. How do I adjust? Goodman - GMS9/GCS9
Depending on the age of the furnace you may be able to adjust the cool down. On some furnaces there is a silver box usually made by honeywell. This is your fan limit control. If you take the cover off you will see a dial with different temperature settings with 3 pins in a grove. The first one is fan on with temperature rise this turns the blower on when the furnace starts and warms up. The second is the fan off after furnace shuts down, this would be the one you want to adjust to a higher temperature to keep the blower from blowing cold air. The last pin is the high limit if the furnace gets to this temperature it will shut the furnace off but keep the blower running. Make sure that the thermostat fan option is set to auto and not on.
Jan 02, 2010 | Goodman GMS90703BXA Heater
71122 ac model starts but the fan does not blow any air .shuts off within seconds.
which fan shuts down? Outside condensor fan? Or blower inside? If its the outside condensor fan motor you probably have a bad run capacitor or a bad condensor fan motor
Jul 26, 2009 | Heating & Cooling
Ruud A/C condensor unit won't come on
It sounds to me that the wire going to y2 on the furnance coming from the thermostat was not wired back up this is the wire that supplies control voltage to the contactor on the condensing unit. I would call the installer who changed the furnace out back to remedy this problem.
Jun 01, 2008 | Heating & Cooling
Blower fan keeps shutting on/off,
Your blower fan turning on and off shows your thermostat is working. I am willing to bet you have the fan in the automatic condition. Check for a sticking contactor at the outside unit.
May 31, 2008 | Heating & Cooling
Goodman CLQ36AR49 Air Conditioner Logo
349 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
