Question about LG Studioworks 700S 17" CRT Monitor
Monitor lg my monitor was ripped out of my computer leaving the plug behind and the 4 or so wires are hanging out. i want to know the wiring diagram for the pin plug if anyone can help.
  • 65 Answers
Easy ,red,green,blue and ground first, then find vertical and horizontal sync,then ddc pins you can solder and test with your compuiter on.
Posted on Jul 07, 2007
I need wiring diagram to ignition switch, switch was ripped out and need to know we're wires go. Need a new switch and what the switch plugs into
Call the manufacturer tech line. Give them the model and make. They always have a pdf file format they can email you on the wI ring schematic.
Nov 01, 2015 | Garden
LG 500G Monitor display on white screen
Sometimes it is simple, make sure the wiring behind the computer is not touching. Touching causes cross-talk in signals. Try it.
Mar 27, 2014 | Computers & Internet
Rear view mirror was wire ripped off
U will have 2 isolate all the wires so they cant touch each other & the body work -steel - just use some electrical tape 2 prevent wires touching!!!!! Or open the door & look 4 the plug C if U can pull on the plug 2 disconnect it!!!! Good luck!!!!
Nov 23, 2013 | 1999 Acura TL
W2361v will not turn on.
This monitor has a manufacturer's defect in two of the wiring harnesses: the harness going from the controller board to the power button (4 grey, 1 blue wire) and from the power button to the side controls (3 grey, 1 blue wire). The insulation was not stripped properly from the blue wires on any of the 4 connectors. You will have to open the monitor (snaps apart, no screws) and replace the 2 blue wires. You can solder jumpers to the pins or replace the entire harnesses.
Sep 06, 2012 | LG FLATRON W2361V 23 inch LCD Monitor
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Air bag light flashes 5 times then2 times how to reset light have tried leaving battery disconnected overnight to no avail.light started after removal of fuses to check for power to rear wipers.
CLEARING CODES (works for code 52)
1. Only intermittent codes and codes that diagnostic monitor recognizes as being repaired may be cleared from memory. To clear codes, cycle ignition OFF to ON. Observe AIR BAG warning light. AIR BAG warning light will illuminate for 4-8 seconds, and flash fault code.
(Comment) Loosely translated - If you dont have the problem fixed, this wont work. Code 52 should clear with this!
2. Locate air bag diagnostic 2-pin connector.
(Comment) This was a fun one. According to the air bag wiring diagram that I also got from Mitchell, the Airbag Diagnostic Connector is located "Right side of Instrument Panel". The only thing I found immediately to the right of the I/P (between the stereo and Instrument panel) was a black computer with 4 connectors which is NOT what I was looking for. I finally found a blog that mentioned the computer for the air bag computer was behind the right side kick panel. Sure enough....there it was. Attached to the side of the diagnostic computer was a two prong diagnostic connector.
3. Connect a jumper wire between diagnostic connector terminals. Leave jumper wire connected until diagnostic monitor tone sounds (about 5 seconds). Disconnect jumper wire. Fault code is cleared.
Oct 07, 2008 | 1998 Ford Explorer
T910BU
The plug was cut off from this monitor and I need the wiring diagram for it, can you help me?
Nov 28, 2007 | LG Flatron Ez T910BU 19" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
75 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
