Question about Frigidaire Affinity ATF7000ES Front Load Washer
Frigidaire Affinity Front load washer will not spin.Will do everything else,but when it comes to the spin cycle the power on the display will shut off.I did the error panel test comes up with error 47. Thank you for any help
  • 85 Answers
E 47 is a defective door lock asm pn 131763245 for about $67
Posted on Dec 14, 2008
Where is the pressure calibration switch on an affinity front load washer?
Hello garrett_lind, I appreciate your inquiry!
From my understanding you are searching for the pressure calibration switch on your Frigidaire washer due to the fact that it is not spinning on the last cycle. Some possibilities as to why your appliance is not spinning could be your timer or drain pump. I could not locate steps to access the pressure switch but for electrical components I would recommend having a professional come out to properly diagnose and repair the appliance. -Matt
Aug 12, 2014 | Frigidaire Affinity ATF7000ES Front Load...
WHY DO I GET ERROR E47 WHEN THE SPIN CYCLE IS SUPPOSED TO START?
Good Afternoon Friend,
I understand you are receiving an E47 when the spin cycle is supposed to start, on your Frigidaire Affinity washer, model# ATF7000E. The E47 code states that the control board of you appliance thinks that the door is open. This could also be a false error code. I suggest resetting your washer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Once power is restored, start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Affinity ATF7000E Front Load...
Mywashermakesahummingnosieandwontspin
I understand that your Frigidaire Affinity washer, model# ATF6000F, is making a humming noise and will not spin. If your load is too small, this can cause your washer to not spin. Add a couple of similar items to help balance the load. On the other side, your washer could be overloaded. Try taking out some items and restarting the cycle. If neither of these is effective, try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. When power is restored, run any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire Affinity ATF6000F Front Load...
My frigidaire affinity front load washer buzzes and will not cycle what wouldcause that?
Good Morning Friend,
I see that your Frigidaire Affinity washer, model# ATF7000E, is buzzing and will not cycle. Some possible causes of this could be:
-Your washer is overloaded with clothes. Try taking some clothes out and restarting.
-There could be an article of clothing that might have slipped in between the gasket and the drum that might be stopping the drum from spinning. Check to see if there are any clothes that might be missing and possibly stuck between the drum and gasket.
If you have tried the above solutions and are still having trouble, I suggest giving your washer a hard reset. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. After the time has passed, restore power and start a cycle. If your appliance is still buzzing and not spinning, I suggest that you contact your local authorized technician for further assistance. They will be able to diagnose your washer and determine the cause of the buzzing and why it is not spinning. Hope this is helpful.
-Best Regards-
WP
May 05, 2014 | Frigidaire Affinity ATF7000E Front Load...
Why does my washer do every thing but spin dry could a pressure swicth be bad on door?
Good Afternoon Dale,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, not spinning your clothes dry. First, if the drum is not spinning at all, I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored run a spin only cycle. If it starts spinning and the clothes are still coming out damp, try one of the following:
    1)Try changing the spin speed to a higher speed.
    2)Make sure that you have not overloaded your washer.
    3)Make sure that the wash load is not too small. If you are only washing a couple of items, try adding 1 or 2 similar items to balance the load.
    4)Try rearranging the load to allow proper spinning.
    5)Check the drain hose for any kinks. If it is kinked, straighten it.
    If you are still having trouble with your washer spin drying, I suggest contacting your local authorized technician. Hope this helps.
    -Best Regards-
    WP
May 01, 2014 | Frigidaire Affinity ATF7000ES Front Load...
Won't wash
press the pause and stop button at the same time it will give u a code
Mar 20, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Affinity front load washer will not spin
sounds like the impeller on the drain pump is blocked. Noise could be coins trapped in drum. Check filter thoroughly, if you cannot remove blockage you may have to remove tubes from pump to clear out any blockage.
Dec 20, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Washing Machines Logo
461 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
