Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Sony VX-2100 unresponsive dials
The camera's dials stopped working for a while. The exposure dial and the menu dial. After a few months they started working again. Now once more upon starting another project the dials are unresponsive.
  • 29 Answers
It can happen if any of the setting switch is struck or short....
Posted on Jan 12, 2010
While my setting is on A (aperture) on my Mode Dial, its my shutter speed, and sometimes my exposure compensation, that is changing when I move my main command dial
It may be possible to swap the functions of the primary control dial and secondary control dial - check in the manual or the menu system.
Jun 12, 2016 | Nikon D5200 DSLR 18-55mm Lens Kit with...
How do I change the aperture when my camera is in manual mode
You have to hold down the exposure compensation button at the same time as turning the control dial.
The values appear on the control panel screen.
I found this on page 33 of the manual...
Set the mode dial to M and turn the control dial to set the value.
• To set the shutter speed: Turn the control dial.
To set the aperture value:Turn the control dial while holding down the
[+-](exposure compensation) button.
The exposure level indicator appears on the control panel screen, showing the difference (ranging from -3 EV to +3 EV) between the exposure value calculated by the currently selected aperture
and shutter speed compared to the exposure value considered optimum by the camera.
Oct 13, 2014 | Olympus EVOLT E-410 Digital Camera
My cannon g12 camera takes over exposed photographs. he shutter is working well. so, help me.
Check your Exposure Compensation Dial. In shooting modes where exposure compensation is allowed, this dial can be set to decrease or increase the brightness of the image in 1/3-stop increments across a range of -2 to 2. You use this control to override the camera's automatic exposure settings to get a slightly darker or lighter image. It should be set to 0.
Mar 04, 2012 | Canon G12 Digital Camera
How do I turn on the Rear Command Dial in my Nikon D80 Digital Camera?
That depends on what you want the command dial to do. If you're in either the Manual (M) or Shutter Priority (S) modes, the command dial will change the shutter speed. If you're in the Program (P) mode, the command dial will shift the program exposure. If you're in any other exposure mode, the command dial does nothing.
If you hold down the metering mode button, the command dial will change the exposure metering mode.
If you hold down the exposure compensation button, the command dial will change the amount of the exposure compensation.
If you hold down the release mode button, the command dial will change the release mode.
If you hold down the AF button, the command dial will change the autofocus mode.
If you hold down the QUAL button, the command dial will change the image storage mode.
If you hold down the ISO button, the command dial will change the ISO.
If you hold down the WB button, the command dial will change the white balance setting.
If you're looking at the menus, the command dial will navigate the menu.
If you're reviewing pictures, the command dial will move to the previous or next picture.
Hope this helps. If you still have problems or other questions about this, please don't hesitate to reply to this post.
Jun 29, 2011 | Cameras
A few pictures "whited out" now no flash at all.
There can be 2 issues that i would check first:
Check the exposure. The symptom described looks like a heavily overexposed photo. But the foto pn automatic and make a phot on the shade. Make sure the exsposure is not far right into ++.
Alternatively you can set the camera to automatic ( small camera icon on the dial) . If that solves it , the exposure was the issue
Also the White balance is something to check
How to on page 26
manual :
pdf.crse.com/manuals/3296322111.pdf
Please let me know if this worked.
thanks
rene
Jun 08, 2011 | Sony Cyber-shot DSC-H10/B Digital Camera
Broken mode dial?
Make sure that the SETUP option is nearest to the black mark on the camera, if you are still not shown the options menu, you should probably call Nikon USA to get the camera serviced if still under warranty.
Jul 16, 2010 | Nikon COOLPIX P3 Digital Camera
Over exposure photos
Try change the exposure of the camera: start the camera, set the dial to 'I' (automatic iso), then press the 'up' menu near the display until 'exposure' settings appear. move the slider to the left/right, according to your preference.
I reccomend using the automatic iso for taking pictures, it automatically adjust exposure.
Apr 25, 2009 | Panasonic Lumix DMC-LZ7 Digital Camera
Nikon FG Exposure Compensation Dial
try to set the itty ***** red dot to 0 again make sure the collar goes down its the compensation mode once its down try turning the speed dial again i haven't had a film camera for about 8yrs i had a nikon 6060 which is almost like a fg . hope this helps
Jan 03, 2009 | Nikon FG 35mm SLR Camera
How can I change the exposures, or f-stops on the Nikon N75 35mm camera?
That depends on the exposure mode. In the point&shoot modes the camera sets the exposure.
In P you can turn the command dial to change the exposure.
In S you turn the command dial to set the shutter speed, the camera changes the aperture to suit.
In A you turn the command dial to set the aperture, the camera changes the shutter speed to suit.
In M you turn the command dial to set the shutter speed, you hold down the aperture button and turn the command dial to set the aperture.
If you don't have a manual, get one from http://www.butkus.org/chinon/nikon.htm
Oct 16, 2008 | Nikon Cameras
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
112 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
