Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Wont spin and not emtying
Checked filter all clear Checked outlet all clear any solutions
  • Hotpoint Master
  • 3,463 Answers
Select drain and spin on programme and with the rear panel removed, see if you can detect the pump running, if possible test to see if you are getting a supply to it.BE CAREFUL.
if not , then you will need to investigate furher, if you are getting a supply, then it is possible the pump impellor is turning slowly or something wrapped round the impellor.
Posted on Dec 11, 2008
My washer makes alound grindin noise wen trying to empty
1) most Noises coming from washing machines coming during the cycles of SPIN .Clothes load can be un-balance. Stop the machine and balance the clothes.Start again, and repeat the step if necessary.
God bless you
Jun 28, 2012 | Washing Machines
Will not spin the machine panel says check outlet pipes have done and cleared water out but machine spin programme will not complete
You probabl;y need to clean filter.
Remove lower rearcover of washer.
Remove large black hose fastened to bottom of drum.
Remove and clean filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Please rate my solution.
Thanks.
Nov 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Daewoo dwf-6094r wont spin on spin cycle
You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And rate me pl, if the solution has worked......
Dec 02, 2007 | Washing Machines
Washing machine
You have to check and clean out your outlet filter. This requires periodic cleaning, according to your usage. If its a front loader, the small door is at the front bottom, be prepared for water to come out while opening.
Oct 06, 2007 | Washing Machines
Hoover AAA 160 Error 3
If you are certain that all pipes are clear, then you may wish to check the pressure pot & pressure switch ( & small hose joining the two as this could be telling lies to the program unit. If the machine is emptying but the switch fails to read the level correctly, it can cause the same sort of error problem. Pressure pots can fill with the "grey soap gunk" and switches pressure are a reletively common fault also. Good luck
Jul 27, 2007 | Hoover AAA160 Front Load Washer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
43 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
