Question about NEC Electra Elite DTU 16D-2 Corded Phone
Display contrast - too dark
I messed up the contrast in my display - NEC DTU 16 - I can't read the date, time, incoming caller ID... and can't fix it. Please help.
    Problem Solver:
  • 16 Answers
You should be able to adjust LCD contrast when phone is idle, just use the up/down arrow button to adjust it (don't go off-hook). If you have background music set, the above procedure will adjust the music volume instead. You can turn Background music on and off by pressing <Feature>,2,6 when your phone is idle. Alternatively, you may press <Speaker> 6,0,2 and then use the UP/Down arrow key to adjust LCD contrast.
Posted on Dec 29, 2008
The caller ID screen is so faint I can't read it. Is there a way to brighten it or change the contrast so I can read it?
. Press and hold the dial/menu button until "Options Menu" is shown in the display.
2. Use the up/down buttons to scroll through the options below, and press the dial/menu
button to select the desired option you wish to set:
• Set Language
• Local Area Code
• Set Time/Date
• Set Flash Time
• LED Contrast
• Set Tone/Pulse
• Exit Options
3. Use the up/down buttons to adjust the setting, and press the dial/menu button to confirm
and set.
NOTE: It is important to set the Area code so that the telephone can distinguish local or long
distance calls when dialing from the Caller ID list.
NOTE: Time and Date will automatically set when you recieve the first or second Caller ID
Oct 16, 2012 | Emerson EM2646-WH Big Button Corded Phone...
NEC Dterm 80 phones
Caller id would have to be truned on, in system programming, as long as the caller id card is installed. If it works for the corded phones and not the cordless phones than, the analog caller id feature needs to be programmed. check out ldtsnj.com
Apr 13, 2009 | NEC DTU 8D-2 Corded Phone
Directory Button need programmed to display caller ID
We would need to know the phone system type you are trying to fix. It is the box where all the wiring is, usually a telephone closet or server room. Let us know and we can help.
Dec 31, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Caller ID Scroll
Your system needs to have a mif-m card and kmm chip installed and all programming setup in order to scroll through the caller id. If this is all setup you can hit the directory button and than use the arrow buttons under the display to scroll. ldtsnj.com
Oct 30, 2008 | NEC DTU 8D-2 Corded Phone
Cidco inc caller id box - model # JA-25A-18
When a call is received it will automatically set the time and date. To change the display contrast hold down the 'delete' button while toggling one of the other buttons. Hold the delete button down until the 'select,mem,mode' is displayed and choose between '25 name & number' or '64 numbers' . Make sure the batteries are good and the batt indicator in top left corner of display is off. I think that is all the features this early model unit was capable of.
Sep 29, 2008 | Home Security
Can't find caller id function on NEC ETW-16DC-1 BUSINESS PHONES SYSTEM
You have to make sure the phone system you have has CID cards in it. What kind of card is in the Electra phone system.
Sep 08, 2008 | NEC ETW 16DC-1 Corded Phone
Cleer ID display on NEC Ranger DK824 telephone system
I have a DK824 I bought in 2000 which did not have called ID capability - that was explained to me on purchase - if yours is 2 years old they must have kept the models the same for a long time though
Jun 25, 2008 | Lands Phones
Caller ID Display
This one could have different variables.
  1. your CO lines must have CID
  2. your CO card in the system must have CID capability
  3. older systems have a limited number of extensions that can display CID (16)
  4. your ext must be set to ring.
Mar 31, 2008 | NEC DTU 8D-2 Corded Phone
Display contrast needs adjusted
press speaker button and dial 602+ up and down key to adjust the display. dial 601 to increase ring volume. DJ
Jul 25, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Electra Elite DTU 16D-2 Corded Phone Logo
767 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
