Hi my samsung galaxy 5 gt 15503t is locked by telstra i need an unlocking code can any one help ?
SOURCE: need code to unlock gt 15503t
To unlock your phone from security code, follow the information from this link.
To unlock your phone from network, follow the information from this link.
SOURCE: hi, how do i factory reset my samsung galaxy
Well it is a bit techie situation. First try to enter Recovery Mode. There are a few ways to enter in Recovery Mode -> video link.Once in a recovery you can easily choose Factory Reset. On upper link you can find three ways to do it, and one way of doing it goes like this, it usually works:
1. Power Off your phone2. Press and hold Volume Up button + Power button + Home Menu button (just hold all three buttons at same time until logo appears)3. Select Wipe all data / Factory Reset (you select it with Volume Up and Volume Down buttons and execute it with Power button or in some cases with Home Menu button).
If you watch videos you will find same thing.
SOURCE: my son has locked himself
Welcome to Fixya.
To make the phone ask for the PUK code, the sim lock has to be enabled.
To lock the SIM card, perform the following steps:
1. From any Home screen, tap the Menu key.
2. Tap Settings.
3. Tap Location and security.
4. Scroll to and tap Set up SIM card lock.
5. Tap Lock SIM card to select and enable the SIM lock.
6. Enter the SIM PIN.
7. Tap OK.
The default pin is 1234.
Now, whenever you will turn off then on your phone, it will ask for a SIM unlock code. Just incorrectly enter the code and it will be PUK locked.
Hope this helps!
SOURCE: hi i need unlock code
Method 1.Unlock Samsung Galaxy Mini via Imei ->>
samsung/galaxy-mini/unlock-code/network-unlocker
Method 2.Follow this guide to unlock your Samsung Galaxy mini >>
http://androidforums.com/samsung-galaxy-mini-s5570/
SOURCE: i have a samsung galaxy
you can unlock your samsung galaxy s 2 easily with imei unlock code. get your samsung galaxy s 2 unlock code some reliable source. because if you enter wrong unlock code it's hardlocked for your phone. so get your trusted samsung unlock code.
