Code 78 makes all black copies.
Hello again
I was able to enter simulation mode for the CS-2114 copier as you said. I pressed in 78 and pressed print and it went to "98" (96?). I pressed a few buttons after nothing seemed to be happening and nothing again, and pressed stop/clear to exit. Powered machine on again and now get all black copies. How do I get back to where I was?
thanks
Hi!
I checked the service manual and those numbers are not error codes.I don't know what they mean, but the black pages could be several things. According to the book, the exposure lamp could be bad. Look to see if it lights up after you push the print button. If it is not on then the lamp is probably blown. If it does light up, then you have something blocking the image from being projected on to the drum. Carefully remove the toner cart., dev. unit, and then the drum unit. Look to see if there is paper jammed anywhere. It also could be the thermal fuse mounted on the lamp assy(scanner) or a bad power board(AVR PCB) or the main circut board. You should call a local service tech for an estimate. If their a decent company they won't charge you for the estimate. Good luck!
Posted on Jan 11, 2009
My machine sharp MX 3100N is giving the error code U2-05, what steps should i use to solve it
This error refers to a discrepancy between the HDD & the machine. If the hard drive has not been swapped out & nothing has changed on the machine then try resetting the copier to see if that rectifies it.
To reset the machine you will need to enter simulation mode.
First, make sure the copier is in COPY mode.
Then press the following 4 keys in quick succession: # * C *
You should then have a screen showing simulation mode.
Then enter 16 & press either of the copy keys (black or colour).
This should then display U2 ERROR RESET.
Press EXECUTE, YES then press the CA key.
The machine will exit simulation mode & restart.
If after restart the machine displays U2 again then you will probably have a HDD fault. Unfortunately, the HDD would have to be replaced by an authorised dealer as new Firmware would have to be reload to allow the machine to recognise a new HDD.
Hope this helps.
Dave.
Jan 19, 2017 | SHARP MX-3100N
I am getting a flashin L and can't make copies?
L1 = Scanner (reading) feed trouble Scanner (reading)
L3 = Scanner (reading) return trouble Scanner (reading)
Reset method :
* Entering the simulation mode
1) Clear key ON - Exposure mode select key ON - Clear key ON - Exposure mode select key ON
(The machine is ready for entry of the main code of simulation.)
2) Main code input by 10-key ? Start key ON
3) Sub code input by 10-key ? Start key ON
The machine enters the selected simulation mode.
Press the start key to start the operation of the selected simulation.
Main Code =(14 Used to cancel the self diag other than U2 trouble.)
Sub code = 0
* Canceling the simulation and returning to the normal mode
1) Press the clear key.
Copy SIM 14
Sep 07, 2010 | Sharp AL 800 Copier
I just replaced all the moving parts in my Sharp AR-M620 copier including the finisher and drum etc...I have the service codes and sub codes to reset the print counters, drums, developers etc but don't...
1) Copy mode key ON ? Program key ON ? Asterisk (*) key ON ?
CLEAR key ON ? Asterisk (*) key ON ? Ready for input of a main
code of simulation
2) Entering a main code with the 10-key ? START key ON
3) Entering a sub code with the 10-key ? START key ON
4) Select an item with the scroll key and the item key.
5) The machine enters the mode corresponding to the selected item.
Press START key or EXECUTE key to start the simulation opera-
tion.
To cancel the current simulation mode or to change the main code
and the sub code, press the user setup key.
* Canceling the simulation mode to return to the normal mode
1) Press CA key.
Sep 06, 2010 | Sharp AR-M620N Copier
Could you tell me how can i enter the simulation mode for the kyocera 1815 copier.
I would suggest you check the manual of the kyocera 1815 copier. this should be stated clearly on the user manual. so check the user manual for the information as regards this.
Take care.
Jul 14, 2010 | Kyocera Office Equipment & Supplies
Sharp AR-M550 with a paper tray error F3-12
1. Start and end of simulations Note: The "PAUSE" key in the descriptions means the "INTERRUPT" key. Simulation IN The Simulation IN mode becomes only available from the Copy mode screen. In the simulation mode, printer operation is inhibited. Printer operation is also inhibited in either of the Aging mode or the Adjustment Copy mode. The printer selection key is disabled, too. By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation main code input screen appears. * If the interval between any two key operations is more than 5 seconds, the entry into the simulation mode is canceled. (Ref.) 1 ~ 9: Loading/ sensor checks 10 ~ 19: Resetting troubles 20 ~ 29: Counter/mode setting 30 ~ 39: Sensor activation checks 40 ~ 59: Adjustments 60 ~ 69: Digital readout and printer Simulation OUT The simulation can be terminated by pressing the [CA] key. 2. Simulation main code input screen SIMULATION NO. _ INPUT MAIN NO. AND PRESS PRINT SWITCH 1 If any trouble has occurred when the trouble code is requested, the 7-segment readout displays the trouble code (main only). [Note] The trouble code is canceled when the copier enters the simulation IN mode. [Note] The 7-segment readout becomes blank when the copier enters the simulation IN mode. 2 Only the [PRINT] key LED comes on. [Note] The [PRINT] key LED is usually OFF. It comes on when the copier waits for the [PRINT] key to be turned ON in the simulation mode. 3 The main code input area (2 digits) waits for the input of a main code. [Numeric Key]: Main code input [Note] Codes are entered in the ring format. [PRINT]: Sets entered data. [C]: Clears entered data. [CA]: Terminates simulation. [Others]: Cancels (ignores) entered data. 4 If a simulation has a sub code, it should be executed on the sub code input screen; a simulation does not have a sub code, it should be executed on the simulation execution screen. 3. Simulation sub code input screen
Dec 08, 2009 | Sharp AR-5320 Black and White Copier
Have a ricoh 1035p with black copies after replacing the drum. Is there a drum count reset and if so what is the code to reset?
Hello sir; There have not thing to reset but there do have two simulations to do, before you go for it make sure you do clean the image roller with alcohol and drum blade be replaced then go to simulation; press "clear mode", "107", hold down "clear/stop" key until SP mode show out then enter sp3001-2 and sp 2005. turn power off and back on.
Jun 04, 2009 | Ricoh Office Equipment & Supplies
Cs-2114 all dark copies
if you replace drum meanwhile you have to replace developer too, after you replace then you have to simulated follow these steps;
1, power off,hold down"print"&"stop/clear" key while you turn on.
2,press"stop/clear" key within 2 second.
3,enter 60, press print,pess "'stop/clear" key
4,enter 73, press print, enter000000 press print
5, mode 1, enter 03 press print mode 2 & 3 all enter0 press print
Dec 12, 2008 | Office Equipment & Supplies
when in the simulation mode you have to follow the instruction, otherwise you going to screw up whole machine, try to turn off the power and on again, see what happen.
Dec 11, 2008 | Office Equipment & Supplies
Mita cs-2114 copier with flashing "replace unit" light
after you see "---" within 2second press"stop/clear" again thenyouwill see"00" show out then enter 60 press print
Dec 09, 2008 | Office Equipment & Supplies
Flashing
turn off the power , hold down "print" &"stop/clear" while turning on power. now within 2 secund, press
'stop/clear" key again, now enter78, press print let it run, will be automatically stop running, when they stop running press "stop/clear" to end the simulation.
Dec 08, 2008 | Office Equipment & Supplies
52 people viewed this question
jasbo
jasbo
