Question about Kenmore 62602 Electric Dryer
I have a kenmore dryer model number 110.62602101 that will not start
    Sergeant:
  • 359 Answers
Check door switch and power first thing
Posted on Dec 21, 2008
3 Suggested Answers
  • 7 Answers
SOURCE: how do i put the dryer belt on a kenmore dryer
there is a tension bracket on the bottom side. LOOK and roughly draw the path of the belt. Feed the new belt around the drum. The last thing is to adjust the tension below. Its spring loaded, so no exact measurements here.
Posted on Jan 31, 2010
TheMobilian
  • 8220 Answers
SOURCE: How do you put the belt back onto the drum of
What I do first is remove the filter and thos 2 phillips screws where the filter housing bolts to the top. Then with a putty knife I pop the top., so that I can remove the crews holding the front on. I raise up the front so the clips at the bottom don't get damaged. I remove the drum and clean out the dryer. I remove the filter hoising and clean it out with water. I vacuum the blower housing and motor. I oil the wheels and roller with HVAC high temp resistance slow disapating zoomoil ($2 at any ace hardware). I get a friend to help hold the drum up whileI connect the idler. I stick the idler in the floor with the weel facing left. I loop the belt through the idler and onto the motor. I give it a few slow turns to make sure it is not twisted. The ribbed side needs to be against the tub not the slick side by the way. I have photos and more HERE
BELT ROUTING INFO HERE
Posted on Feb 14, 2010
Testimonial: "My dryer is now working.Your instructions did the trick! "
Model 64982. Where can I get push to start button?
This is a Sears Model that begins with the number 110.64982 and has more numbers. You should be able to find tag inside dryer door. Once you have the full number any local parts outlet should be able to get the part.
Be awre, this switch does NOT fail often and MAY not be the problem. There are SEVERAL reason why your dryer may not start when button is pressed and you should check those before you buy a part you may not be able to return.
The video below WILL help get you started:
How to Troubleshoot Brown Top Kenmore Dryer that Won Start
Nov 21, 2015 | Kenmore Dryers
How do I stop my kenmore dryer, model 970-c87172, from beeping? Drying, cool down, wrinkle rid and clean lint filter lights flash 3 times. Start light doesn't flash at all. It does this even
Hi Brenda
First off It seems that you model is not correct. Kenmore model numbers start with 3 number followed by a . and then some more numbers. Most Kenmore laundry numbers start with 110.xxxxxxxx. The number you have looks like a serial number which is no help.
Oct 19, 2014 | Kenmore Dryers
Old Kenmore Dryer can't turn-off and won't heat
Look like you need a timer control
model number should start with a 110. number timer for your dryer is about $70
Dec 05, 2013 | Kenmore Dryers
Kenmore model 84152/94152, 8 years old, started out with3 beeps over and over while running just fine otherwise. Now, 12 hours later, stupid thing started, while not running as in not in use, beeping once...
that isn't a model number and kenmore doesn't make anything so you have to send the full model number off of the dryer,open the door look around the opening where you put the clothes in and send the model number,if it's beeping and starting on it's own it sounds like you have a computer board problem with it but can't help you without the model number.
Dec 31, 2017 | Frigidaire FEQ1442ES Electric Dryer
My kenmore dryer 70s series wont start
send the model number,open the door and look around the opening where you put the clothes in,you'll see a tag with model and serial number,just need model number.
Mar 18, 2013 | Kenmore Dryers
Kenmore dryer,, looking for adiagram for the belt on a kenmore dryer
Below are the belt diagrams for Kenmore dryers.
Figure 1. Whirlpool-made Kenmore dryers with removable back panel, filter on top, and model numbers starting with 110 or C110.
Figure 2. Whirlpool-made Kenmore dryers with non-removable back panel, filter below the door, and model numbers starting with 110 or C110.
Figure 3. Frigidaire-made Kenmore dryers (model numbers starting with 417).
Mar 01, 2011 | Kenmore Dryers
My Kenmore Series 70 Dryer will not start at all. No sensation of the start button doing anything when I push it. Thermal fuse continuity is good (0 ohms). Light goes off inside the dryer when I depress...
most likely its the push button that is bad. you can buy one from any appliance dealer that services a kenmore dryer. the part is a reasonable price. you also have to give them the model number and serial number. have a good day!!
Oct 15, 2010 | Kenmore Dryers
Kenmore gas dryer doesn't stay running have to hold button down.
POST MODEL NUMBER, BUT IT MAY BE THE MOTOR START SWITCH.
Apr 18, 2009 | Kenmore 73952 Gas Dryer
Kenmore dryer will not come on
make sure your door switch is good / if not the dryer wont start / larry
Dec 05, 2008 | Kenmore 74742 Gas Dryer
Need manuals
What problem are you having, the problems i have seen with kenmore elites are below.
1. when you press start and release dryer shuts off
for this problem, change the board in the console
2. not producing heat
for this problem, check to see if 220 is getting to element, check to see if you are getting 220 from outlet, check your thermal cutoff on heating housing, check your heater relay which is located in top console.
Apr 02, 2008 | Kenmore 63942 Dryer
Kenmore 62602 Electric Dryer Logo
101 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
