Question about Nikon D50 Digital Camera
Nikon D50 Body issue
Don't actually know if it's just a body issue, but I think it is. When I look through the viewfinder, I see about 3/4 on it covered over by a dark gray haze, which I think might be the mirror partially obscuring the view. Also, I'm getting an "Err" message when I try to start up the camera. Starting up the camera has also given me problems - sometimes I get a blank display, sometimes a partial display... Truly bothersome considering I am in Korea now, and will be traveling to Angkor Wat tomorrow night. I really want this camera working again! Can anybody suggest what I should do considering my situation? Best regards, Mike
Sounds like your mirror is stuck up or partially up. I'd take it in to be repaired to be safe and so you don't have to fiddle around inside it.
Posted on Oct 14, 2007
I advise a high school yearbook and we shoot a d100. Today it's too dark to see through the viewfinder (yes the lens cap is removed), and i ger the r06 error. I've reset the camera, removed and...
First, the "r06" message is NOT an error code. It indicates the number of shots remaining in the internal memory buffer, before the camera must prevent additional shutter actuations so that it may transfer those images already in the buffer to the memory card. This "r" number will decrease with each shot taken in rapid succession until it reaches 0. The shutter release will no longer work until the buffer is transferred to the memory card, then shooting may continue again.
As far as not being able to even see through the viewfinder, it sounds like something may be obstructing the light from reaching the meter and viewfinder. The problem is most likely the position of mirror inside the camera body. With the lens off the body, the mirror should be plainly visible at about a 45 degree angle to the opening. A side view drawing of this is below. The solid red line is the mirror in the normal position. The red dashed line is the up position of the mirror when the shutter is released.
When the mirror is in the "normal" position, the light from the lens is projected on a screen so that the image is visible in the viewfinder for composing and can be metered. When in the "up" position (when the shutter release is fully depressed), the light from the lens is projected on the camera's sensor for as long as set by the manual settings or program; based on ISO, aperture, etc. At the end of this time, the mirror returns to the "normal" position.
If your D100's mirror is not in the lowered 45 degree angle position, the image seen in the viewfinder is inside the camera - not that which the lens would project. Hence, the dark viewfinder, long exposure times and - I'm guessing - severely overexposed pictures because way too much light is striking the sensor because the meter is only seeing darkness.
If the mirror is ok, with the lens removed from the body, look for the aperture lever as shown in the yellow circle in the picture below:
By default, the aperture is at minimum. The camera moves the lever from this position to full open (and anywhere between) as needed. You should gently move the lever to the other end of its travel to open the aperture to maximum. Point the lens away from a light source but preferably at a light colored background. Look through the lens. There should be no obstructions and be clear. Next, look at a dark colored background to find the same results. If you want, you can even allow sunlight to shine through the lens onto a sheet of paper (like a magnifying glass). The result should be a bright circle with no obstructions. Obstructions in the lens will prevent the meter in the camera from getting accurate information about the scene and if significant enough, prevent viewing through the viewfinder.
You may wish to have the camera & lens professionally cleaned and serviced to repair a mirror or lens issue.
If this was helpful, please rate it as such. Good luck!
Oct 04, 2011 | Nikon D100 Digital Camera
I have a Nikon d50, had it since 2006, I took a picture, heard a weird noise, and now the viewfinder is dark as if I have a lens cap on (I don't!) I took off the lens and saw inside the body of the...
Inside the camera is a mirror which reflects the scene up to the viewfinder. It flips out of the way when you press the shutter button. When the mirror flips up, the shutter opens and exposes the sensor. When you look inside, if the mirror is stuck in an up position, you will not see anything in the viewfinder. However, the mirror is super delicate....do not touch its surface or try to force it.
Sep 10, 2011 | Nikon D50 Digital Camera
I own a Dimage A2 and the viewfinder is very scratched. Can I buy one from anywhere?
In short, no. Spares are generally no longer available and expensive when they are.
But there are huge numbers of broken A1's and A2's which sell for near-nothing on auction websites which may be purchases as spares donors. The viewfinder lenses on both models are identical, although the actual electronic EVF display is different. Ask the right questions and buy wisely and you'll also end up with spare batteries and all the body covers which might have been lost from yours for no extra cost.
Jan 18, 2010 | Konica Minolta DiMAGE A2 Digital Camera
Image through nikon f80 dark and cloudy
I'm unfamiliar with the F80 but on models like the f65 and f75 the viewfinder screen has an lcd overlay and when the battery is exhausted or removed the viewfinder goes dark and blurry.
Looking at a picture of the f80 it looks like it's just an update on my f75 so it strongly suggests that you just need to insert a fresh battery. The lcd does draw power from the battery even with the camera turned off.
I hope that you found my answer useful, once you've tried another battery to confirm what I've suggested I'd appreciate it if you return the favour by rating my answer.
Jul 20, 2009 | Nikon F801S 35mm Film Camera
Image through Nokia F80 viewfinder dark and cloudy
Please also ignore this answer, (see askers comment above). I've only posted it so that this question doesn't continue to appear as an unanswered one.
If anyone else has this problem please go to
http://www.fixya.com/support/t2637498-image_nikon_f80_dark_cloudy
for an answer.
Subject is dark when looking through the viewfinder
Take the lens off and look at the lens opening on the body - at the 9 o'clock position is the aperture stopdown lever. It should be square to the edge - not bent sideways or too far from the side. It's a pretty flimsy lever and easily bent. You can bend it back square by grabbing with pliers and pushing toward the left side. Common problem.
May 07, 2009 | Nikon N65 35mm SLR Camera
Blur viewfinder
hi,
are the photos also blurred when they come out? if adjusting the diopter doesnt fix the issue, you might need to have your camera and lens calibrated. why the lens? its because the issue may be isolated to the lens calibration otherwise the technician will only calibrate the body.
Oct 06, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Is it possible to use the lcd in stead of the viewfinder
No, since the camera is a DSLR, there is no way for the CCD sensor to have an image until you take a picture. The shutter covers the sensor until you actually take the shot.
Mar 11, 2008 | Nikon D40x Digital Camera
Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Feb 11, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera Logo
107 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
