Question about Insignia Digital-to-Analog Converter for Analog TVs
Installed Insignia box, keep getting No Signal
I followed the directions and installed the Insignia conversion box but keep getting No Signal. What could I be doing incorrectly? Or could I have a faulty box?
  • 1 more comment
  • sandran2 Dec 18, 2008
    I am using a digital indoor antenna and get perfect picture on the TV without the box. When I hook up the digital converter box to the antenna it doesn't tune in the channels and gives me a 'no signal' message. What am i missing?
  • Josef J Dec 21, 2008
    I have exactly the same problem.  Very frustrating.
  • lhair62 May 03, 2009
    nothing comes on just snow-- analog tv
  • 3 Answers
You need a stronger antenna. Many of the VHF channels moved over to UHF thus if your current antenna doesn't pick up UHF, you will not pick up those channels.
Posted on Jun 15, 2009
Just bought a 19" Insignia LED TV. Specs of the TV keeps appearing on and off at the bottom of the tv. Don't want to keep seeing it. How can I make it stop?
If the actual specs of the television keep appearing, the television could be in demo mode. Demo mode is turned on when the television is being displayed in the store. Is this a display open box model? There is an option in the display or set up menus to activate or deactivate demo or store mode.
If it is not the specs of the television but rather the channel and program information you are seeing, you may be having a different problem. In this case it is a signal issue you are having, and the only way to remedy that is to connect the television to a cable/set top box with RCA or component cables or to install a signal booster. http://www.amazon.com/Motorola-Booster-484095-001-00-Bi-Directional-Amplifier/dp/B000066E6Y
Dec 01, 2012 | Insignia Televison & Video
We can't set up our 32 inch insignia 120Hz tv. It keeps saying "no signal." We have been on the phone to both Insignia and Comcast with each essentially blaming the other. We have a digital cable box...
Tries unplug tv and cable box replug both back about an hours.The tv now,it resetting itself back to the factory setting.The cable box is now resetting and it upgrading it softwares.The tv should work now.Not,tell the cable company sent u another box,still have same problems,the tv board call the Tuner signal board have problems,must be replace.This Tuner signal board,that the board,where the tv incomming broadcasting signal cable plug into it.If the tv is out of warrenty,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 24, 2010 | Insignia NS-L46X10A LCD TV
No signal
Call the station to see if they are testing their signal. Also check the signal strenght: turn to channel WGEM and usung the signal meter in the converter box check to see if you have a strong signal. If signal is week change the direction of the antenna or get a signal amplifier; especially if you live more than 10 miles from their broadcast tower.
Mar 19, 2009 | Insignia Digital-to-Analog Converter for...
When I hooked the DTA800 to my RV atenna
My understanding is that the Digital signal is weaker than the analog, so need a stronger antenna to pick up the digital signal, and MAY still not get any reception at all. Have you considered satellite for you RV? Won't need the converter at all then.
Feb 22, 2009 | Insignia Digital-to-Analog Converter for...
I hooked my converter box direct to my v c r. Do I have to keep the green light on to record
yes, you do because no power to the converter box, no change in signal for what it was ment for.
Feb 18, 2009 | Insignia Digital-to-Analog Converter for...
Insignia mp3 player reads "Unable to format external memory!!"
I too had this same problem.
i downloaded and installed the firmware update...and now my 2gb microSD is readable.
link for download:
http://www.insignia-products.com/t-New%20Video%20Player%20Firmware.aspx
follow directions and you'll be good to go.
May 30, 2008 | SanDisk 4GB microSD High Capacity Memory...
Power light just blinks
can you get a signal without box to tv
everythings going hd these days it could be they have it set for an hd
rf's pull there signal from the air and and filters to wear its supposed to go
hd is direct signals
9 times out of 10 the new box in not compatible with tv
or the guy who came in and installed the box did something to your tv and ran away
May 16, 2008 | Toshiba 32A43 32" TV
Surround sound
Hi
Your receiver is capable of video conversion, so there should be no problem using your component cable.
Does your TV accept component, or only S-Video? If you can run component to your TV, the best quality signal path would be using a component cable from your Verizon box to your receiver, and component from your receiver to your TV.
Make sure you have set up the video input correctly, so that it is set to accept the incoming signal on the correct sockets.
Mar 21, 2008 | Audio Players & Recorders
Insignia Digital-to-Analog Converter for Analog TVs Logo
77 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
