Question about Executone 64 Corded Phone
Executone 64 System: Only certain extensions ring
When the main incoming number is called, only certain extensions ring. How do I add more extensions into this hunt group? or is there a setting on the extension phone?
Http://www.executonesystems.com/documents/IDS_UserGuide.doc
Try going to this user guide and see if this helps.
Posted on Jan 26, 2009
How to stop / edit all incoming calls ringing to other 2 extensions at the same time?
What phone system are you using?
I will gladly show you how
KX-TEA/TES/TA series or KX-TDA/TDE/NCP series
Oct 25, 2015 | Panasonic KX-T7633 Corded Phone
How can I change the system main greeting on an Executone Model 64?
from any phone dial 436 and then press #, then enter managers mailbox usually 5000 and the password, by default it is 5000.
then 3, 8 and 1# for CCR 1,(or 2# for CCr2 and so on) and follow the prompts
if you need additional help, call me. 2033955027. Joe
Sep 05, 2014 | Executone 64 Corded Phone
How do I reprogram the phone to ring when a new call comes in, default to a certain line, and show caller id when a call comes in.
The answer to the Caller ID question:
Depend on the type of system that the phone is connected to. Late model Partner ACS equipment will display Caller ID info between the first and second rings, provided that the telephone line is plugged into a module that supports Caller ID.
The answers for the other 2 questions are taken directly out of the Partner ACS Programming Guide which is available for free download at Avaya's website.
Ther answer to the incoming call line ringing question:
Again, depends on the system. For the Partner ACS:
1) Press FEATURE 00 at extension 10 or 11.
2) Enter the number of the extension to be programmed for Line Ringing.
The green lights next to the line or pool buttons show the current Line Ringing settings for all
lines or pools assigned to the extension. (If a line or pool is not assigned to a button, the green
light next to that button is off.) The following ringing options can be shown by the green light
next to the line or pool button:
? Immediate Ring - on steady
? Delayed Ring - flashes slowly
? No Ring - flutters quickly
3) Press the line or pool button until the button light shows the correct setting (the setting for the
currently selected line or pool also appears on the display).
4) Continue programming, or exit programming mode.
Line selection:
For incoming calls, the line selection (hunt sequence) is set by the local service provider). For outgoing calls....again....it depends on the system. For the Partner ACS:
1) Press FEAURE 00, SYSTEM PROG, SYSTEM PROG, CENTRAL PROG at extension 10 or 11.
2) Enter the number of the extension to be programmed for Automatic Line Selection.
3) Press **.
4) Press the line, pool, or INTERCOM buttons in the desired order. The valid entries for Automatic
Line Selection
depend upon the type of extension:
? Key Extension: Outside system lines, Left Intercom (the factory setting)
? Pooled Extension: Pool 880 button 1, button 2, Left Intercom, Right Intercom (the factory
setting), Pools 881-883, individual lines
For each button pressed, a display similar to the following appears:
5) To exit Automatic Line Selection, press **.
6) Press CENTRAL PROG and enter a new extension number, or exit programming mode.
Changing line ringing and line selection are tasks that are normally reserved for the Administrator of the telephone system.
Jan 06, 2011 | Lucent 18D Corded Phone
How to reprogram so that incoming calls ring on all phones, not just the main phone.
Hi, this can be done at customer level programming, first add all extensions that you want to ring into a group ie 500, this is done in MMC 600, add them as members. Once you have done this you need to go to MMc 714 and set the group you have chosen as the destination corresponding to that incoming phone number. I have uploaded a video which hopefully will help - please visit www.abbeytelecom.com for written instruction.
Dec 14, 2010 | Samsung Prostar 816 Phone
Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Dec 01, 2010 | Panasonic KX-T7633 Corded Phone
Answering
Hello, if you are using this phone on a Panasonic 308 or 824 system press 40 for an external incomming call or 4 followed by the extension number to pick up a certain extension that is ringing.
Thank you.
Mar 25, 2010 | Panasonic KX-T7730 Corded Phone
Privacy
Unfortunately you cannot toggle this feature.
On extension 10 or 11
Feature 00
Left Intercom, Left Intercom, Right Intercom
Enter extension number that you don't want to ring
hit the line key until display shows No ring
To do next extension : Right Intercom and enter next extension number.
Follow same procedure for all extensions.
Feature 00 to exit programming
Let us know if you need additional assistance.
Cheers
Jul 16, 2009 | Avaya Eurostyle 18D Corded Phone
Stop ringing at main phones when outside calls come in.
Here is a link to program line ringing.
It sounds like your extension is forwarded (confirmed by the one beep you hear on an incoming call.
From any display phone, press Feature 11
then enter your extension number 2 times. So if you are extension 20, do this:
Feature11-20-20
see if that does it.
May 28, 2009 | Lucent PARTNER18 Corded Phone
Extension is locked
the phone is in IN/OUT mode
if you call the phone from another display phone it should show the ext you are calling in a IN/OUT mode.
to remove this you will need to place a key on the phone through programming. the key code is 821.
once you have programmed the key, press it once and the phone will work.
Nov 12, 2008 | Executone 64 Corded Phone
Two incoming calls issues
What type of phone system do you have?
Dec 19, 2007 | Lands Phones
Executone 64 Corded Phone Logo
279 people viewed this question
Top Executone Lands Phones Experts
David Burbee
David Burbee
magna buff
batMichael
Level 1 Expert
Are you an Executone Lands Phone Expert? Answer questions, earn points and help others
