Question about Sharp AL-1641CS Laser Digital Copier
2 lines down the right side of paper - sharp 1641 CS copier
Hi keith, you came up with a solution for me last week and since then we have received a new drum - i replaced the old one and we still have the problem - though i can see how the drum could cause this because this new one had a defect and also created strange marks down the paper. - do you have any other suggestions?
  • jdistel Dec 15, 2008
    Thank you for your help - I have tried cleaning it with alcohol and when i make a copy on the glass itself the lines still appear - it seems that the rollers are fine. Any other ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Your problem is most likely not the drum.
Can you make a copy on the glass itself and the lines DO not appear?
if yes this confirms it is not from the drum. Open the top and look at the Small strip of glass : is it dirty or have two dots, white out or Anything on there???? clean w/ alcohol. Any dots will look like lines when making a copy because the paper is moving on the glass.
If the lines are still coming out even on the glass then take a look at the Fuser (exit where it gets hot) are the rollers smooth and uniform or are they scratched???
Posted on Dec 12, 2008
  • CheckitRight
    CheckitRight Dec 15, 2008
    If the lines still come out when copying on the glass then check the fuser for any scratches (exit where it gets hot)
    Or take out the drum and look inside, you will see a strip of light, clean ( there may be toner on the light )
Can you help: when you turn on the copier AL 1641 CS performs its start-up, pressing enter to copy the scanner remains in the home position of left side
Sounds like the scanner latch is in the locked or latched position. You can hit them easily removing the copier. Look under the area you remove your copies. On the bottom of the scanner, there is a latch lever. Flip it to the unlocked position.
Feb 03, 2011 | Sharp AL-1641CS Laser Digital Copier
Meaning H 4 appear alternative Sharp Al-1641 CS
H4 is nothing but an error code that appears due to power fluctation(in absence of a stabilizer). You please enter # interrupt-C interrupt -14-start to clear to clear the error
Jan 12, 2011 | Sharp AL-1641CS Laser Digital Copier
Sharp AL-1551CS Scan Problem
hi do u have set tha adf limet for 8"x14" just set the corect size of origlan from adf
thanks
May 11, 2010 | Sharp AL-1551CS Copier
Double left line down the side of paper
Sounds like the drum surface has been damaged by some foreign object.
Typically when you get imaging errors such as lines from top to bottom of a page there is a permanent scratch on the drum surface. Pull the drum unit out of the printer/copier and carefully examine the drum surface, you most likely will see the damage quite easily. The only repair is to replace the drum unit with a new one. HOWEVER... be sure to clean the inside of the machine with a toner vacuum to remove any dirt, debris or paperclips, staples, etc that might have accidentally been introduced into the unit.
Hope this helps you out.
Cheers,
Keith
Dec 04, 2008 | Sharp AL-1641CS Laser Digital Copier
Sharp AL1641 prints faded
The toner cart. has been in for a long time, has plenty of toner in it, it has been refilled 2 times.
Sep 17, 2008 | Sharp AL-1641CS Laser Digital Copier
AL1641 CS won't make two sided copies anymore
Sounds like a driver or configuration problem, 1st) Make sure when you are printing, to go to Properties, you must choose 2-sided printing each time on that model, some programs won't allow you to change your printers settings.
2nd) go to control panel/ printers/ Al-1641, right click, properties, In the first tab General it should say at the bottom (Double sided - Yes) If not you need to delete the driver, a fairly common problem, and reload the driver, get the driver from Sharps website to be sure you have the most current driver, if a driver is corrupt it won't tell you there is a problem, make sure it allows you to print two sided.
Jan 11, 2008 | Sharp AL-1641CS Color Copier
Toner issue with several third party toner cartridges
Here is the manual for that machine ( incase you don't have it, check out page 59
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=fcb5a95908d7e226bcd8ab88b0637b4f&q=Sharp+AL-1641CS
$100 for toner, wow, try these guys, I've used them and their services are good. Not sponsoring.
http://www.precisionroller.com/k_sharp_al-1641-cs_toner_cartridge/m180d4669c36/
Oct 22, 2007 | Sharp AL-1641CS All-In-One Laser Printer
Kyocera CS 2030 fax jams
Hi,check settings for fax.Try to check paper attributes for fax.Maybe You have different paper format adjusted for fax printing.
Oct 19, 2007 | Copystar CS-2030 Copier
Sharp AL-1641CS Laser Digital Copier Logo
85 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
