Question about Fisher and Paykel 23 in. DD-603 Built-in Dishwasher
Anybody have a problem with changing the program on the dd603? the touch buttons are intermittent
  • Anonymous Apr 20, 2009
    I am unable to change the wash options at all
    President:
  • Fisher and P... Master
  • 2,651 Answers
Firstoff youlll needto make sure hat your panel and/or fingers are completly dry, if gets bad enough that you cant change at all then replacing the control board itself will be te answer,
Posted on Jan 25, 2009
How do i repair fisher paykel dd603 problem top drawer stuck on fast cycle, bottom drawe stuck on normal cycle
you will need to replace both draws control boards, with the dd603 control boards they have a small touch button panel on the top of the board which they didn't put a protective layer or plastic over and basically what happens is steam gets on the copper tracking and corrodes it hence the fact it doesn't work anymore, all new control boards even the replacement for yours comes with a plastic strip over the board. hope this helped
Oct 06, 2014 | Fisher and Paykel Dishwashers
Monitor intermittent power problem and horizontal green flickering lines
separate wiring. touching wires creates cross-talk of signals.
Jan 28, 2014 | Computers & Internet
How do i change programed number
Hello Ms Nelling,
You can change the programmed numbers by simply programming new numbers on the saved position.
Press the MENU/SET button and select FAX \ Setup Quick Dial and then choose whether you want to program a speed dial or a one touch button.
If you had previously programmed a 1 touch on button 3, just select that 1-touch and it will ask you if you wish to change the current settings.
Thanks,
Pat
Apr 14, 2011 | Brother IntelliFax-2820 Laser Fax
I need to change the extension's programmed on the left side of the one-touch dialing. Thanks
Press PROGRAM, the button and dial 1 plus the extension of the new number and STORE. You can keep touching new buttons and dial the sequence ending in STORE.
Press PROGRAM to end.
Carl
Jun 21, 2010 | Panasonic KX-T7731 Corded Phone
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Engine misfires badly after cruising a while at 3k revs,
Try to check the computer box and check if it is working and check the timing belt as well make sure it is properly tune up.
Jun 09, 2009 | 1998 Subaru Legacy
Programme stuck
Try swapping the motor controllers (computers) over between the two drawers to see if the fault moves while doing this give the touch buttons at clean. Any questions feel free to ask. Cheers
Apr 22, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Touch buttons dont always work on a dd603 dishwasher
Hi and welcome to FixYa!
If you are talking about the cycle selector buttons up on the top edge of the drawer, I can help you with this. When the selector button gets wet or has moisture buildup or soap residue, it will not sense the touch from your fingertip. It is not a mechanical button per se. If you take a clean dry cloth and wipe the recessed area where your fingertip touches the button, it will respond 100% better than it will when it is dirty or just plain wet. I show my customers this practically every day.
The only other thing that will cause this is the tab behind the control panel sometimes cracks and will not hold the computer tightly against the underside of the drawer edge. This is rare though. Clean the surface of the drawer edge and it will change cycles again like new.
Dec 11, 2008 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & Paykel DD603 setting the water pressure
First off, clean the surface where you select the cycles, over on the right side of the drawer edge. Clean up the entire surface, so that when you lightly touch the cycles, It changes instantly. Also, you said "dd603" but the LP/HP modes are for model 601 and 602.
Open the drawer, select normal first. Now with two hands, hold your fingers over the two outer-most buttons, one on the left side and one on the right. Wait up to six seconds and then the LEDs should all come on in an orange color and the display should show the LP. Press the lock button once, it should change to LP. Make sure you are looking for a manual for a dd601/602. You can get them free at http://www.fisherpaykelparts.net
Dec 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603 Built-in Dishwasher Logo
137 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
