Question about JVC HD-61Z786 61" Rear Projection HDTV
Replacing the lamp
I have a HD61Z786 61" TV and we just baought a new lamp. I can not find our book and do not know how to put it in. Help!!
Should be a pretty simple matter. There is a door on the back left side.
Did you buy a lamp or a lamp and housing?
DO NOT TOUCH THE LAMP BARE HANDED!!!
Posted on Dec 25, 2008
  • 25 Answers
There are a lot of tutorials online, also try calling the place you bought it from, they should be able to walk you through the steps. Also, make sure you bought the right lamp model, the # for this TV is TS CL110UAA.
Posted on Apr 16, 2009
I have a wd-57833 work good I got the same one from some one put in a new lamp tv work for 5 hr then stop working on sound or picture but the lamp is good i put in in my tv and it works so i put the p
If the lamp is new and good to go then you may have to reset the lamp replacement counter in your setting menu. When that is set back to zero you wont have a problem until it is time for a new lamp again.
Aug 19, 2014 | Mitsubishi WD Televison & Video
I have a Sharp lcc3234u I followed your guide and replaced the bad ccfl lamp now all the lamps come on but they go from dim to bright then out. Then the green power light starts blinking again. Power...
Make sure you connected all the plug wires in tight and the pc flat ribbon wires to the top of the lcd panel (which has a flip up connection on the lcd plug side that has to be pulled up with your thumb nail and hold the ribbon wire in all the way as you push the connection down to connect it.) When you power the tv on look at each ccfl lamp and see if one is dim or not as bright or has a pink color to it. I had a second lamp on my tv that was bad and had a pink color but lite up and it kicked the power off like your tv is doing. After I replaced it the tv worked find. For some reason these tv`s will get a bad ccfl lamp from time to time. You might buy another ccfl lamp and remove each lamp one at a time and put the new lamp in it starting at the top and going down checking all 10 lamps one at a time this way you will find the bad one. If the tv still will not power on then I would replace the power supply board and the tv should work then. If you need to buy the power supply board go to partsstore.com and put your model # in the search to get the part #. If you need help finding the part # let me know and I will try to help you fine it. After you find the part # you might find a good or new power supply board on Ebay.com at a lower cost. I bought a spare new power supply board on Ebay.com for near nothing for my tv.
Nov 28, 2011 | Sharp Aquos LC-C3234U 32 in. LCD TV
Replaced lamp, pic is dull and not sharp any more,
Did u unplug the tv about half hour before u change a new tv projection lamp,for the tv so the tv power storage left over to disapper and what ever statictic charges magnatic field left to completely gone or to lower it enough not to harm the new tv projection lamp u just starting to put it in wright?The new projection lamp when u handleling it did u have a pair disposable glove on to not causes human static charges and the oils from ur hand to tranfer to the new tv projection lamp itself to caused to it quality funtions?This is the same exact same brand and make to the tv old projection lamp u are replacing not a clone or a tv compatible tv projection lamp wright?U check all connections are correctly installation and tightly before u turn on the tv again wright?U do all these safety procedures,before and after u are replacing a tv projection lamp will help 90-95% it to work correctly,if the tv causes are just requiring replacing a new tv projection lamp only.
Oct 06, 2011 | Mitsubishi WD-62531 Projection Television
I just replaced the lamp on my Samsung HLS5087 and now the TV won't power up. The 3 LEDs are lighting which indicates that the lamp needs to be replaced. I put the old lamp back in to make sure there is...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help to solve the problem,,,,
Dec 06, 2010 | Televison & Video
Lamp bulb replacment
much cheaper to do it yourself, go online put in your tv's model number and seach for thr lamp and make sure you order the entire lamp assembly, on the back of your tv there is a door open and take out old lamp so you know what you are ordering, and when replacing the new lamp amke sure not to touch the lamp
Aug 12, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Red bulb lamp flashing and screen won't turn on. Just replaced lamp bulb with new one - didn;t fix it.
Please make sure lamp cover is fixed in its place securely, you know it was removed to replace lamp so put lamp cover back in its position and turn ON tv.
Hope this info will help you.
Feb 18, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Yellow blob on screen after replacing lamp in Sony KDF-E42A10
optics block, this set is a rear projection and is lcd. means there is no color wheel.
May 01, 2009 | Sony (XL-2400) Projector Lamp for...
Hitachi model # 50V720
I have the same model and had the same problem after replacing the lamp. Turns out if the cover plate is not put back on properly, tv will not power on and lamp ligth comes on. To solve the problem all I had to do is tighten the cover plate screw. Hope this helps.
Nov 17, 2007 | Hitachi 50V720 Television
Tv lamp replacement
I just did this myself. I'm a novice but it wasn't that hard. Your choices are to purchase a complete unit including the casing from a Sony repair shop for around $250, or just replace the lamp.
I just replaced the lamp and saved $130.
I just removed the screws from the side of the casing that protect the lamp. I disconnected the contact points and then popped open the housing.
Remove the screws and the nut that attach to the lamp. Wear gloves when you handle the new lamp so you don't shorten the lifespan of the bulb.
re-attach all the screws and slide it back in.
It took me the longest to have line up the contact points when sliding it back into the TV. Make sure all the connections are snug and keep at it. Don't give up! I'll admit I was tempted!
Oct 27, 2007 | Sony KDS-R50XBR1 50" HDTV
JVC HD-61Z786 61" Rear Projection HDTV Logo
160 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
