Question about Nokia 1100
My batteries always low or empty
How you'll fix it??
  • cals_56 Feb 16, 2009
    i have a problem about my 1100 nokia celphone i change already different batteries but still always low bat.please help me what i am going todo
  • 65 Answers
Check if our battery is inflated, if so, your phone is shorted... is your phone dropped? soaked? there are lot of reasons why the phone became shorted...
Posted on Mar 31, 2007
  • 74 Answers
Dear, Firt of all u have to check ur battery mean change a new one if same prob then this prob mostly come from PF some also says it PA use for amplifying signal both RX and TX. when it is currupted then it use more battry even in normal condition and give battery empty message during call and some time also turn of but when u power it again it show ful battery indication at battey level indicator. if its is then u have to change PF located at the top of board. u can also make it short mean ur mobile also can work properly with out this IC for this rate at. chazer92@yahoo.com
Posted on Mar 16, 2007
Let your battery go falt completely then shock it with a 12 volt dc , + on + , - on - . then put it in your mobile and make a full charge be 4 use
Posted on Mar 14, 2007
  • 22 Answers
1 First check your battery 2 Check any shorting between battery contacts 3 Resoldered battery contacts 4 Check PFO
Posted on Mar 12, 2007
Does a one+ 18 volt lithium battery have a fuse
No but will have a deep discharge protection that will come up when the battery is coming below a specific power level.
Sometimes people think on the old batteries to training the cells for capacity but thats wrong , the best is always to switch the batteries do not made a battery inactive for a reserve , have the batteries as soon as you lose some power its the best to leave them on the charger because if the battery is below its deep discharge protection it will not charge anymore when its coming on the charger , then you must load another battery full and connect the full battery with the too low level discharged battery with 2 wires + to the + and the - to the - of the empty battery and wait for 2 minutes in first step and try to connect the almost empty battery to the charger Do not use battery chargers for a car be shure to be safe because of some brands of batteries can have problems with not done experiments.
Mar 02, 2018 | Drills
How often should i charge the batteries?
If modern LI ION batteries are used, keep them always on the charger is the best advice. there is no memory effect on , and there is a deep-discharge protection on them and the device will shut off when the level will come low but dont wait to long with recharge (if a device is not used with a empty battery for a long while that its not easy if the batteries are below that special protecttion level it will sometimes not recognized by the charger anymore. and you can boost if possible with an other loaded battery + to plus and - to - if that happens.
BUT If Nickel Cadmium batteries are used make them always empty before recharge to protect for memory effect faults on capacity. beware thats only by NI-CD. NI-MH Nickel metalhydride batteries have also no memory effects.
Very important its depend on all batteries Better to avoid charging if there are to cold temperatured batteries.
Its very degrease the battery lifetime.
Mar 31, 2017 | The Computers & Internet
I got a 2001 Chevy Venture and fuel gauge always stays on full
The problem is in the fuel sender unit in the tank. It sounds like the float part of the sender unit is binding when it's at the top (when tank is full) and hangs up there till it falls back down when tank is near empty. It will likely have to come out to be checked, fixed, or replaced. Good luck.
Apr 11, 2012 | Chevrolet Chevy Cars & Trucks
My canon powershot a495 has a problem. it always
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jul 04, 2011 | Canon PowerShot A495 Digital Camera
How can I look up the current toner levels on a Toshiba e351c?
when it nearly empty a massage " low toner " appears on screen
when empty you 'll see this massage "replace >>>> "
May 19, 2011 | Toshiba Office Equipment & Supplies
My nokia 2330c-2 is always low on battery even after I have charged it and it most at times hangs and goes off automatically
nokia 2330c calling time battery empty & when restart phone battery full plz provide me this problem's solution ....
Apr 20, 2011 | Nokia Classic 2330 Cell Phone
RCA #D930 remote control stopped working??
good day
2 common causes of malfunction remote control... first,is low battery or empty...if you have a multimeter tester set it to dc and check the voltage of your battery if it is on empty or low battery condition replace it
and secondly,when the infrared is defective...how can you determine?..if you have any digital cameras get it and point it to the top view of your remote then try to look the infrared bulb (LED)then press any button to activate the remote after look at your camera while pressing the remote if you see infrared lights up for every pressed..your remote is OK..if it is not lights up and your battery is good..replace the infrared to fix your problem
thank you and good luck
Apr 09, 2011 | RCA Televison & Video
I have a Xerox 8830, that is getting a LL90 error after printing a couple jobs. I can restart and the error will clear but than comes back after a couple jobs. Is this a sensor or is it some other problem?
LL-90 and LL-91 refer to low toner and too much toner. If low, the cartridge is nearly empty, if too much, tape off half the holes on the cartridge.
Jun 15, 2009 | Xerox 8830 Copier
Bushnell radar gun always displays the same speed
Ever if Your radar gun don't display "low voltage" icon - change Your batteries, use only the best alkaline batteries (High Power) od NiMH rechargeable batteries. That will fix Your problem.
Feb 26, 2009 | Bushnell Velocity Speed Gun
Olympus fe 130
Ive had the same problem with my camera and found that it was the quality of the batterys. you have to use good quality high drain batterys for digital cameras.
Nov 02, 2007 | Olympus FE-170 Digital Camera
Nokia 1100 Logo
146 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
