Question about Uniden 5.8GHz Cordless Phone
How to set-up code to retrieve messages while away
Model DXA142882 how to retrieve answer machine messages remotely
  • jaj797 Dec 11, 2008
    Need to set up phone to retrieve messages remotely. Is the secrity # the # to plug in before or after the greeting
    Genius:
  • 1,142 Answers
Playing Your Messages
1) With the phone in standby mode, press the
(play/stop) key. The system announces the
number of new and old messages. The LED
displays the number of new messages, and the
number flashes. The day and time that each
message was received is announced after the
message is played.
2) When all new messages have been played, you
hear a confirmation tone and an announcement
“End of messages.” The message counter
displays the total number of stored messages,
and the system returns to standby
Posted on Dec 11, 2008
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Dec 11, 2008
    Remote Operation
    When you are away from home, you can operate your answering system with any touch-tone
    telephone. Use this function to check for recorded messages, to play or delete messages,
    even record a new greeting message.
    1) Call your telephone number.
    2) During the greeting message, press 0 and enter your PIN code (see page 36).
    3) The answering system announces the current time and the number of messages stored in
    memory. Then you hear "To play incoming message, press zero two.
    For help, press one zero."
    4) You may continue to listen to the voice prompts, or you may select a command from the
    following chart:
  • Maanita Chadha
    For your convenience
    remote operation cards
    are provided for you to
    use while away from
    home (located in the
    back of this manual
    Once you enter the
    remote access menu,
    you must enter a
    command within 15
    seconds, or the
    answering system
    automatically hangs up
    and returns to standby.
  • Maanita Chadha
    Turn on the Answering System Remotely
    If you have forgotten to turn on your answering system, you can turn it on remotely from
    any touch-tone telephone.
    2) Wait ten rings until the system answers. You hear intermittent beeps.
    3) Press 0 and then enter your PIN code. The answering system announces the number of
    messages stored in memory. You hear "To play incoming message, press zero two. For help,
    press one zero."
    4) Press 0 then 6 to turn the answering system on. You hear the outgoing message and a
    confirmation tone.
    5) Hang up the phone; subsequent calls will be answered by the system.
  • Maanita Chadha
    Here is the complete guide
    http://www.uniden.com/pdf/DXAI4288-2om.p...
  • 740 Answers
You program the code on the base its usually a 2 digit code. When you call your house the answering machine will pick then you press * + code you programmed. Good LUCK
    President:
  • 2,110 Answers
Http://www.uniden.com/pdf/DXAI4288-2om.pdf
this document might be helpful to u...
    Genius:
  • 1,199 Answers
Got to www.uniden,com and they will give you step by step instructions!
    Top Expert:
  • Uniden Master
  • 77,186 Answers
Here is the link to your owners manual, the info is in there.
http://www.uniden.com/pdf/DXAI4288-2om.pdf
  • 1 more comment
  • yadayada
    yadayada Dec 11, 2008
    PS, THE INFO U NEED IS ON PAGE 36
  • yadayada
    Setting a Personal Security Code (PIN)
    If you want to be able to play your messages from a remote location, you need to enter a
    two-digit Personal Identification Number (PIN) code (01-99). To select a PIN, perform the
    following steps:
    1) With the phone in standby mode, press the menu/clock key twice.
    The system announces "Security code," and the current PIN code is announced as it is
    displayed on the main base. Then the system announces the instructions for setting the
    PIN code.
    2) Press the or /volume/select key until the desired number appears.
    3) Press the set key to select the PIN code. You hear a confirmation tone, then the
    announcement "Security code" followed by the new PIN code. After a few seconds, the
    system announces “To set ring time, press menu again.”
  • yadayada
    REF PAGE 36 THE SYMBOLS DID NOT COPY FOR THE INSTRUCTIONS.
  • 734 Answers
Its not possible i think...
    Master:
  • 479 Answers
Click the menu button---then setup---then select the message settings by moving <--> buttons.and then click ok after set.
How do I retrieve messages when I am away from home? Model # EXA15580
Remote access away from home first you must enter the PIN code: 1) Enter the Answer Setup menu, and then the Security Code submenu 2) Enter a two-digit PIN code (01-99) using the number keypad (0-9). 3)Press OK
You can operate your answering system from a remote location using any touch-tone telephone. 1) Call your telephone number and wait for the system to answer. If the answering system is off, it will answer after about 10 rings and sounds a series of beeps. 2) During the greeting message (or a series of beeps when the answering system is off), press 0 and enter your PIN code within 2 seconds 3)listen to the instructions from there (to play incoming messages, press zero-two)
Mar 19, 2011 | Uniden TRU8885 Digital Answering Machine
Retrieve messages while away
Since you neglected to specify the model of your Uniden 5.8GHz cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Jun 07, 2010 | Uniden 5.8GHz Expandable Cordless Phone...
Code to retrieve messages
Here are the instructions you need to follow:
If you want to be able to play your messages from a remote location, you need to enter a two-digit Personal Identification Number (PIN) code (01-99).
To select a PIN, perform the following steps:
1) With the phone in standby, press [menu/clock] twice.
The system announces "Security code," and the current PIN code is announced as it is displayed on the base.
Then the system announces the instructions for setting the PIN code.
2) Press [volume/select/ ] or [volume/select/ ] until the desired number appears.
3) Press [set] to select the PIN code. You hear a confirmation tone, then the announcement "Security code" followed by the new PIN code is announced. After a few seconds, the system announces "To set ring time, press menu again."
Note: The PIN code is set to "80" at the factory.
Remote Operation
When you are away from home, you can operate your answering machine with any touch-tone telephone. Use this function to check for recorded messages, to play or delete messages, even record a new greeting message.
2) During the greeting message, press [0] and enter your PIN code
3) The answering machine announces the current time and the number of messages stored in memory. Then you hear "To play incoming message, press zero two. For help, press one zero."
4) You may continue to listen to the voice prompts, or you may select a command from the following chart:
Command Function Command Function
[0] then [1] Repeat a Message [0] then [6] Answering Machine On
[0] then [2] Play Incoming Messages [0] then [7] Memo Record/Stop*
[0] then [3] Skip a Message [0] then [8] Greeting Message Record/Stop*
[0] then [4] Delete a Message [0] then [9] Answering Machine Off
[0] then [5] Stop Operation [1] then [0] Voice Prompts
* For Memo Record and Greeting Message Record functions, the first time you enter the corresponding command, it
starts the Recording function. If you want to stop the recording, enter the command again.
Note: Once you enter the remote access menu, you must enter a command within 15 seconds, or the
answering machine automatically hangs up and returns to standby.
5) After all of the voice prompts have been played, you hear intermittent beeps indicating that the system is in the
command waiting mode. You may enter another command at this time from the chart.
6) When you are finished, hang up to exit the system. The answering machine automatically returns to standby.
Turn on the Answering Machine Remotely
If you have forgotten to turn on your answering machine, you can turn it on remotely from any touch-tone telephone.
3) Press [0] and then enter your PIN code. The answering machine announces the number of messages stored in memory. You hear "To play incoming message, press zero two. For help, press one zero."
4) Press [0] then [6] to turn the answering machine On. You hear the outgoing message and a confirmation tone.
Feb 28, 2010 | Uniden EXAI5680 Cordless Phone
Remote retrieval of messages
Call your phone number. After the greeting is finished and you hear the beep to leave a message push 123 on a touch tone phone and you will be given a list of things you can choose to do including listening to messages. 123 is the default security code unless the security code has been changed. Since you dont know how to retrieve messages Im assuming the default security code has never been changed.
If 123 is not the default security code and you dont know what the code is, you can change your code in the setup menu. You get to this by pushing the stop/set button on the answering machine and holding it for a couple of seconds. Since GE doesnt offer a downloadable manual for the 29878GE1 you should probably take a look at the manual for the 29875GE1 which is basically the same model with the addition of a digital message counter. Hope this helps.
Jan 12, 2009 | GE 29878GE1 Digital Answering Machine
How do your retrieve messages from home while away from home
Here's the manual:
29869GE2 Digital Answering Machine
You will need to set a security code. When you're away you can call your home phone and enter the code to retrieve your messages. Hope this helps.
Dec 29, 2008 | GE 29869GE2 Digital Answering Machine
Retrieve Messages when away from home
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}table.MsoTableGrid {mso-style-name:"Table Grid"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; border:solid windowtext 1.0pt; mso-border-alt:solid windowtext .5pt; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-border-insideh:.5pt solid windowtext; mso-border-insidev:.5pt solid windowtext; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Instructions for Retrieving Messages While Away from Home
Sony TAM-100 Answering Machine
Step I: Set the Remote ID (security code) on themachine itself:
1 Press (SET/REC).
2 Press (ANSWER ON/OFF).
A voice guide will say: “Pleaseset the security code. To select, pressthe SKIP or REPEAT button. To enter,press the SET button”.
3 Set a two-digit number between 00 and 99 bypressing (SKIP/QUICK) or (REPEAT/SLOW). Press (SKIP/QUICK) to increase a number, or (REPEAT/SLOW) to decrease.
Each time you press (SKIP/QUICK)or (REPEAT/SLOW), the answering machine announces a number.
4 Press (SET/REC). The remote ID code (security code) is set,and you hear a long confirmation beep.
To change the remote ID code(security code), Enter a new remote ID code (security code). The new code will replace the old one.
Note: If a powerinterruption occurs, the remote ID code will not be erased.
Please See Next Post to Continue (my response exceedsallowable text restriction ;-) ).
Oct 24, 2008 | Sony TAM-100 Digital Answering Machine
Remote message retrieval
When you first installed your GE Digital Messaging System, you heard the code that was auto set for it. Once you are out and away from home, phone home and during the answering machine promp press # and then the promps will ask you for your 'pass word [code]. Please be careful as messages deleted by you, you may not beable to retrieve them. This machine doesn't run by cassette tapes.
~ hope the above helps.
Jun 24, 2008 | GE (WMM317440) Answering Machine
How to retrieve messages from the answering machine ..remotely
Remotely Operating Your Answering Machine
Call your telephone number and wait for the answering machine to answer. If the answering machine is off, it will answer after about 10 rings and series of beeping sounds.
During the greeting message (or a series of beeps when the answering machine is off), press [0] and enter your PIN code within 2 seconds (see "Setting a Security Code or Personal Identification Number (PIN)" on page 54).
The answering machine announces the current time and the number of messages stored in memory. You hear "To play incoming messages, press zero-two. For help, press one-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds.
Apr 01, 2008 | Uniden TRU9488 Phone
Retrieve messages
To connect with your answering system:
1 Dial your telephone number from a touch tone phone. 2 When the system answers, enter your Remote Access Code. The system announces the number of messages and begins message playback. 3 Listen to your messages
Change remote access code Press [*] [#]. Follow prompts to set new code.
Apr 01, 2008 | AT&T 1818 Corded Phone
REMOTE ANSWERING MACHINE
On my Uniden (not sure the model) I press 0 during the outgoing message and then my 4-digit pin.
Aug 12, 2007 | Uniden TRU8885 Digital Answering Machine
Uniden 5.8GHz Cordless Phone Logo
49 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
