Question about HP Photosmart M417 Digital Camera
Camera wont work when memory card is inserted
When there is no memory card in the camera it works fine, but when the memory card is inserted, (with fresh batteries) the camera turns on, but then the screen immediately goes blank and the camera shuts off with the lens still open. this is the same memory card that ive always used with this camera, it hasnt been dropped or mishandled, and the card is inserted correctly. (the same thing happenes when the camera is connected to the computer)
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Posted on May 01, 2007
Took out memory card to transfer photos. returned card to camera and it indicated memory card error shut down leaving lens out.
Never remove or insert a memory card while the camera is turned on. Try removing the battery, waiting about 30 minutes, and then putting in a freshly charged battery.
Never remove or insert a memory card while the camera is turned on!!!!!!
Jun 22, 2014 | Pentax Optio Cameras
Tip
Copy Pictures From INTERNAL MEMORY to Memory Card (solution for those who have...
Required:
Samsung D53 Camera
Memory Card (Clean with no pictures on it!)
Fresh batteries
Optional:
Computer
Memory card reader on your computer
Problem:
You have several (or more) photos that were taken with no memory card inserted into the camera, and they have been stored on the camera's internal memory. You have no USB cord to get the pictures off your camera.
Solution:
I don't know if this is in the manual (as this is a used camera I purchased with no manual or USB cord). In my frustration, I accidentally found out how to get my photos off the internal memory and onto my computer's hard drive.
Here are the steps I followed:
1. Ensure fresh batteries are inserted into your camera. You might lose data or get corrupted pictures if the camera dies while you're transferring pictures. Fresh batteries are important.
2. Insert memory card into the camera (where the batteries go) and close the lid.
3. Power camera on.
4. Press the Print/Review button (bottom button to the right of the LCD) once.
5. When you see the words "No Image!" appear, press the Menu/OK button.
6. A new menu will pop up, asking you COPY TO CARD -- use your buttons to highlight "Yes".
7. You will see your camera "Processing!" It will finish on its own, so do not interrupt the task.
(Optional)
8. Once it has finished "Processing!", remove memory card and insert into your computer's memory card reader to see and SAVE your pictures to your computer. Ensure all photos transferred properly before proceeding to Step 9.
9. With the memory card removed from the camera, power the camera back on and delete individual pictures, if you want to reserve internal memory for future emergency picture-taking situations (especially now that you know you can actually get the photos off of the camera's internal memory now!)
on Aug 12, 2008 | Samsung Digimax D53 Digital Camera
I have put fresh batteries in my Canon Power Shot S1 camera and it still will not come on? Can you help me?
Contact failures may have occurred between the camera and the batteries.
Confirming that the [Memory Card / Battery Cover] is securely closed
If the [Memory Card / Battery Cover] is not securely closed, the power of the camera may not turn on.
Close the [Memory Card / Battery Cover] securely, and then turn the power on.
Clean the battery terminals with a dry cotton swab that has a fine and soft tip, and then re-insert the batteries.
If your camera uses four AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries.
1. Be sure that the camera power is off.
2. Slide the battery cover lock in the direction of the arrow, and push the battery cover slightly forward. Then open the cover.
batts_step1.gif 3. Insert the batteries as shown.
batts_step2.gif 4. Close the battery cover.
batts_step3.gif * For the PowerShot S2 IS, PowerShot S3 IS, and PowerShot S5 IS the batteries are inserted in a slightly different order, please refer to the decal inside the battery door for the correct order.
Installing batteries in cameras with 2 batteries. If your camera uses two AA-size alkaline batteries supplied with the camera, follow the procedure below. In addition to Alkaline batteries you may use optional nickel metal hydride (NiMH) batteries. Please see the various examples to find which type matches your camera.
Example 1:
  2. Slide the battery/memory card cover lock in the direction of the arrow (1.gif), and press down while opening the cover (2.gif).
  3. Insert the batteries as shown and close the battery / memory card cover.
Example 2:
  2. Slide the battery cover lock in the direction of the arrow, and open the cover.
* For the PowerShot A300 and PowerShot A310 the battery polarity is reversed.
Dec 05, 2010 | Canon Cameras
How do I unlock my camera so I can take pictures?
There are many reasons for this.
But at least you may try this first.
1.Turn off the camera.
2. Remove your battery and memory card.
3. wait at least 3-5 minutes.
4. Insert fresh battery and memory card.
5. Turn on the camera.
6. It should work now.
This is a basic reset for your camera.
Regards.
Apr 26, 2010 | Jazz JDC31 Digital Camera
Will not turn on
Here are the steps for your V1003 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Feb 04, 2010 | Kodak EasyShare V1003 Digital Camera
Camera wont come on
Since it is dropped there is a strong chance that it might be F.. But. Here are the steps for no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Feb 04, 2010 | Kodak EASYSHARE M340 Digital Camera
Whenever I turn camera on it immediately turns off.Battery new and fully charged.
Here are the steps for M873 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 18, 2010 | Kodak EasyShare M873 Digital Camera
Camera wont turn on-batteries are OK
Here are the steps for M763 no power problems: 1. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Turn the camera on. 2. Without the memory card, turn your camera on. (If it works then it?s your memory card that is faulty) 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a no power repair with KODAK or a new cable.
Jan 15, 2010 | Kodak EASYSHARE M763 Digital Camera
No memory card, set time
The date/time battery is "built in" (not replaceable) to this model according to page 13 in the manual (available here). It is supposed to recharge when you have the regular battery installed, but if you leave the regular battery out for more than "approximately three weeks", the internal battery may go flat.
I'm not sure this has anything to do with the memory card issue, though. Check the battery problem by inserting a freshly charged battery, turning on the camera and setting the correct date and time, then turning off the camera and waiting an hour or so (with the main battery still in the camera). Turn the camera back on, and if the date and time have to be reset again, your internal battery may be bad, and the camera would need to be serviced.
Dec 09, 2008 | Canon PowerShot SD870 IS Digital Camera
Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
HP Photosmart M417 Digital Camera Logo
73 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
