Question about Linksys Wireless-G WRT54G Router
Need key code
Linksys wireless router- need to find security key code for wi fi phone .
    Problem Solver:
  • 7 Answers
in order to get the secret code or security key,you have to log into linksys router interface.the detailed steps are given below:
1)connect a computer to linksys router using an ethernet cable(hardware connection)
2)open a browser(internet explorer or firefox or safari) and in the address bar type in- 192.168.1.1
3)It will prompt you for a username and password-leave the username blank,and in password field type in- admin(in lowercase)
4)now you should be in router page--click on wireless tab,next you can click on security sub tab which will be below to wireless tab(not the security tab adjacent to wireless)
5)now you should be able to view your security key as wep key or wpa key.
6)close the browser without making any change.
p.s:type the address(192.168.1.1.) in address box ,not in any search box,
thank you.
Posted on Dec 11, 2008
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
How do I set security for my Linksys WRK54G 2.4GHZ
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 04, 2010 | Linksys Computers & Internet
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
I need to change my password to accesss wi-fi
If your linksys router has the default information, log into it by going to 192.168.1.1 or 192.168.0.1 with your web browser. Log in with the user name blank and password admin or 1234. Go to wireless, then security, there you can change your password for your wifi.
Dec 29, 2009 | Linksys Wireless-G WRT54G Router
I need to password protect my router can you help??
access your router with it's ip.
http://192.168.2.1
or
http://192.168.15.1
type user as "admin" and password as "admin" or blank or "password"
then click on wi fi or wireless then enable WEP security *** WEP code it is your password to connect your wi fi network .Then anybody need that password to connect your wi fi network.
Nov 22, 2009 | Linksys Wireless-G WRT54G Router
I'm trying to connect to my mobile phone and it's asking for the network key. What's a network key?
First connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
then you can see configuration page of router settings.
Go to wi fi or wireless menu then find WEP or WAP security code key it is your password to connect wi fi network.If it is in * or # format then add new code so you can connect it with new code.
then save settings and restart router.
Then add that code key in mobile for connect wi fi .
Let me know if you need more assistance.
Thanks.
Nov 11, 2009 | Linksys WRT160N Wireless Router
My laptop asking for sercurity key passphrase
Then you can access it with following link
http://192.168.1.1
or
http://192.168.0.1
then go to wi fi security check your WEP code it is your security key connect wi fi network.
Let me know if you need more assistanse.
Thanks
Oct 02, 2009 | Linksys Wireless-N WRT150N Router
I have wireless - router with built in dsl modem DGN2000. Working fine with my desktop but I have just purchased a laptop and have not been able to connect signal to it.
1. Dear! Check your notebook wireless settings and correct it if it is necessory.
2. Chekc your wireless router settings may it need to update for your notebook.
Good Luck
Sep 28, 2009 | Computers & Internet
How to get step by step to secure a wireless router for a linksy
First connect your router to computer with ehtenret cable.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
then go to wi fi security then check WEP or WAP key you have to set new key because it is in * or # format then save settings and restart router.
WEP or WAP key it is your password to connect wi fi internet ,
Thanks.
Sep 07, 2009 | Linksys Wireless-G WRT54G Router
Have a linksys router and adapter not sure how to install, my daughter wants to use her laptop but cant get the internet
Connect your router to computer with ethernet cable.
http://192.168.1.1 or
http://1921.168.0.1
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Thanks.
Aug 29, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G WRT54G Router Logo
173 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
