SOURCE: starview 2 the box- no signal
hi you never said if you had the power up box for the aerial and if your aerial is facing the correct way make sure you have your connections are right get that checked before you look further you have a few options to do before you delete everything check your signal strength answer these first
SOURCE: starview 3
This guide is intended for use with the Eurovox but the equipment
required is the same for flashing other boxes. The only differences
will be with the relevant box firmware and its loader software.
WHAT YOU NEED:
1. Null Modem Cable ( available from here )
2. Serial to USB Adaptor ( available from here
The above adaptor assumes that you want to use a laptop to do the
job; as most recent laptops do not have a serial port, you must
purchase the adaptor.
The Serial to USB adaptor will come with a drivers disk. So install
this before we go any further and follow on screen instructions.
Connect the adaptor to the USB port on the laptop. Connect one end of
the the Null Modem cable to the Adaptor and the other to the serial
port on the Eurovox.
Provided you have downloaded the correct version, proceed:
The file will have to be extracted. Use winzip or winrar for this procedure ( Very easy )
Ensure the Box is powered on. You can leave connected to the TV if you choose.
If you have your channels set up in Favourites we will back them up
before flashing, although in some instances, the new update will not
affect stored channels if your firmware is not too dated.
Anyway, go to the file which you extracted and start the application. (
It will be named UFL_MaxV_Kuro V........ ) Your first action will be to
upload channel data. Select a name and a location for the file and save
it. It is at this point you will be alerted if the box has connected
with the PC. If it has not, do the following:
Go to Desktop / Right click" My Computer" / Select Properties /
Hardware / Device Manager / Ports & Com Ports. Now select the next
option to appear , in my case it's prolific serial to com port. Now
select Port settings / Advanced / Change com port to 1,2,3 or 4 / OK /
Exit .
Go back to the loader screen and you should now be able to communicate with the box.
Following channel data backup, you must now download the firmware to
the box. Again, it is indicated on the screen and very easy to do. Once
initiated, the box will display DNLD message and a progress bar will
appear on the laptop screen. Allow to complete fully ! Do not disconnect
until UPDATE SUCCESSFUL message appears on the screen. This can, in
some cases, be 30seconds after 100% has been reached on the progress
bar.
Finally, download your channel data and the operation is complete.
Now:
factory reset,
re scan,
go into the menu where you click on the set default key
switch on Emu
exit 3 times
wait for code to update
needs to be done after you have applied the fix,
And if that doesn't work put on Sky or Setanta orParamount+1 for a second, certain channels kickstart the process.
Hope this helps
Chris (ziraffa)
http://www.bubblecableboxes.com/forum/showthread.php?t=223
http://forums.afterdawn.com/thread_view.cfm/722659
SOURCE: cant get the code for my starview box on telewest
00 keys = AA B7 D1 D9 CE 8E 83 AF
01 keys = A1 38 06 29 24 29 8D 2B
SOURCE: my starview 3 box codes keeps going to ff
Press menu..then type in 1570..this will open another menu..go to default and press the default key..then press back..and go into nagravision you should be able now to find your provider..select that and enter your 00 code and store then change to 01 and enter that code..store and exit..make sure your emu key is on it's below the default key..then exit and all should work.
Good luck
Gord
