Home | Ruud | 5.0 Tons 12 Seer Split Central System Air... | ALMOST EVERY DAY, MY OUT...
Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
Problem for Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner
ALMOST EVERY DAY, MY OUTSIDE UNIT STOPS WORKING.
By dmcmilum on Dec 11, 2008
WHEN THIS HAPPENS I OPEN UP THE UNIT OUTSIDE & THERE IS ONLY ONE TEST LIGHT FLASSING. I HAVE TO SHORT OUT THE TEST PINS & THEN IT WILL WORK FOR JUST A LITTLE WHILE THEN I HAVE TO REPEAT THE ABOVE STEPS.
Clarification Request
Posted by tborn6 on Dec 22, 2008
sound like the defrost board is going bad. Is the coil clear of all ice outside?
Popular Solutions for Ruud 5.0 Tons 12 Seer Split
Questions and Unsolved Problems for Ruud 5.0 Tons 12 Seer Split
Do you recommend Ruud 5.0 Tons 12 Seer Split Central System Air Conditioner?
Answer
Answer
inside unit runs for several minutes then cuts out resulting in red,yellow and green lights... (More)
Answer
i have a old ruud package unit that needs to be changed out do you have a replacement unit that is... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud 5.0 Tons 12 Seer Split...:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1303
Experience: 15 years field experience and 5 years navy training
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
