Question about Logitech QuickCam Messenger Web Camera
Logitech 8.3.0 still not working for vista
I used the link someone posted about installing a diff. version, 64bit so it will work with vista, but when i try and connect my webcam to my computer, the driver cannot find my camera.
help me please:)
  • lysslyss49 Dec 21, 2008
    it didnt work.
    i uninstalled all my old stuff.
    rebooted.
    reinstalledand rebooted
    as soon as i plugged my cam in it said it needed to find software.
    i ran the software i just downloaded and a box poped up and said the product is not designed for my current operating system.
  • lysslyss49 Dec 22, 2008
    can give send me the link please?
    Genius:
  • 1,061 Answers
Uninstall old drivers.reboot then reinstall the 64 bit ones reboot then plug cam back in .if cam is plugged in during driver install it will not workRICHARDM69
Posted on Dec 14, 2008
  • Desktopsbyduck-Computers
    You downloaded the wrong one, Go back its there i see it.RICHARDM9
Why does my ethernet not work properly?
In order to decide wheather it is a HW or a SW fault, try to boot another operating system, eg. some one-CD Linux testing distribution. In case it is a SW problem:
- try to instal Asus update (utilities):
ASUS Update V7.17.17 for Windows XP 32bit/XP 64bit/Vista 32bit/Vista 64bit/7 32bit/7 64bit from:
http://www.asus.com/Motherboards/M2NSLI_Deluxe/HelpDesk_Download/
- try to set in BIOS: POST Check LAN Cable: ENABLE (for both LANs). Any error message?
- try to switch off one of LANs: Onboard 1st(2nd) nVidia LAN: DISABLED. Does the other LAN work?
The last step could be testing different version of BIOS...
The easiest way to get LAN ready could be installing PCI LAN card...
May 12, 2014 | Computers & Internet
I have a logitech quickcam 10.0a and i'm looking for driver for windows 7 to install. Can you please help me?
It will depend on if you have a 32bit or 64bit version of Windows 7. If you're unsure, you can check by clicking on the start menu, then right-click computer and select properties. This will open a window with system information including 32/64bit version.
Then go to http://www.logitech.com/en-us/435/352 and select Downloads, then windows 7, your bit version, and click download software.
Please leave feedback if this was helpful. Thanks!
Mar 30, 2011 | Logitech QuickCam Communicate STX Webcam
I just install windows 7 os but no dislplay where can I download an vga driver for Asus P5VD2-MX se
this motherboard is not on asus's list of windows seven supported motherboard, which doesn't mean it doesn't work. use this link to asus's download page: http://support.asus.com/download/download.aspx?SLanguage=en-us if you are using windows 7 32bit version , use the vista 32bit display driver . if your using the the 64bit win7 version, download and install the vista 64bit drivers.
Regards..
Jul 25, 2010 | ASUS P5VD2-MX SE Motherboard
Logitech controller not detecting logitech dual
you need to run the detection wizard again. On 64 bit Windows Vista the path is:
C:\Program Files\Common Files\Logitech\WMDrivers\WMWizard.exe
This fixed my problem. I hope it helps you.
Mar 08, 2010 | Logitech Dual Action Gamepad...
Autocad 2006 on Vista home premiun 64bit
This will not work on vista 64 BIT you will need autocad 2009 64 bit version.
May 04, 2009 | Autodesk AutoCAD 2006
QuickCam Zoom not working after upgrade to Vista
Just read the most wonder article on how toe fix your quickcam zoom for vista follow these steps
These is from 2007 post so you will have to google for the drivers mentioned. I did and it worked
I have a Logitech Quickcam Zoom and this is how I got it to work:
1. Install QuickCam 32-bit Version: 10.5.0 Build 1096b
It can be found here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=10234
2. When you get to the camera detection part where it asks you to plug in your camera, plug it into a new usb port (if you had it plugged in when you installed Vista) and just press skip.
3. Windows may try and find the driver for it, you can cancel that too.
4. Install the old QuickCam software (Version: 8.4.8 build 1034A)and overwrite anything it asks you to (it will fail to install completely because of the new version, but it will put the files you need into the Logitech program files directory.
The old software is here: http://www.logitech.com/index.cfm/downloads/software/CA/EN,CRID=1794,contentid=7649
5. Go to the windows orb (former start button), open control panel, go to system, then on the top left of the window click device manager.
6. Find the unknown usb device (hopefully you only have one... otherwise unplug anything else that doesn't work or you haven't updated the driver for yet)
7. Right click and select update driver, choose a location to find the driver, navigate your way to C:\Program Files\Logitech\QuickCamWebInstall\Drivers\WinNew\PRO2
8. Press OK or whatever, and let it install.
9. Enjoy!
Mine didn't even need to reboot and worked with the 10.5 QuickCapture software. Still need to test with Skype and Live Messenger though.
Jan 08, 2009 | Logitech Quickcam USB Zoom Webcam
I lost my webcam cd installer
how can i download cd installer of my logitech webcam quick cam*8.3.2( window) and quick cam *8.0.1( mac os*)
Aug 22, 2008 | Logitech QuickCam Pro 4000 Webcam
Windows vista home premiun
Please click on the link mentioned below to download the drivers:
Windows Vista Multilingual 32-bit
* Title: QuickCam v11.1.0.2030
* Software Version: 11.1.0.2030
* Post Date: 8/7/2007
* Platform: Windows Vista
* File Size: Approximate download size is 30.7 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110.exe
Windows Vista Multilingual 64-bit
* File Size: Approximate download size is 36.3 megabytes.
http://www.logitech.com/pub/techsupport/quickcam/qc1110_x64.exe
Also visit this website:
http://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/LOGITECH/Logitech-QuickCam-Pro-4000.shtml
Thanks
Aug 22, 2008 | Logitech QuickCam Messenger Web Camera
Also visit this website for other Windows driver:
Thanks
Aug 21, 2008 | Logitech QuickCam Messenger Web Camera
Logitech QuickCam Messenger Web Camera Logo
188 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
