Question about Motorola Mobility RAZR V3
Sim card, turning self off
My Razr has been a real problem. It frequently, and sometimes constantly, shows "check sim card or insert sim card". Turning it off and back on sometimes helps but sometimes has to be done over and over. Store personnel have changed the sim card more than once and told me other things to try but nothing helps. Also, when talking on the phone, it shuts down. Sometime the screen is white, other times the phone is turned completely off. At times it works fine, other days like today, I am constantly having to turn it on and off.
    Brigadier General:
  • 7,752 Answers
The mainboard either needs to be flash or take the phone and have the board replaced.
Posted on Dec 28, 2008
Why Is Status 254 showing on failed text to regular recipient - plenty of phone credit , 29 msgs in out box , have had more than that Phone is Motorola Razr Thank you
i think you have a network problem.
you can turn off your phone and turn it on again after 5 minutes then try texting again. if the problem still exists, turn off your phone again and remove the battery and sim card. insert your sim card into another celphone and try to text there. if you have successfully sent the message, you can insert back the sim into your razr phone.
see if this helps.
May 19, 2011 | Motorola Mobility RAZR V3
My Nokia 3220 show insert sim card but i already insert sim card
Check to make sure its not Backward...
2. Check the Sim card it self for damage the contact terminals should not be scratched or touching one another
May 09, 2011 | Nokia 3220
I am using this airtel sim from past 6 month,from 3 days its showing sim registration failed........but when i m switching it off it starts working again but its showing the same problem...
The SIM card may not be making proper electrical contact. Remove the SIM card, clean the contacts on the SIM card and on the cell phone with alcohol then replace the SIM card in the cell phone.
Dec 04, 2010 | Cell Phones
Razr is fine but then turns off, then when on says "Insert SIM"
It sounds like an issue with the battery. Check to make sure the battery is sitting correctly in the phone and make sure the battery doesn't have any water damage. If both are ok, it sounds like the phone is shorting out so you should take it back to the phone company and show them the problem. They may be able to replace the phone.
Aug 21, 2009 | Motorola Mobility RAZR V3
My motorola razr phone will not work. When I turn
Hi when you take that back cover off take out the battery and look for where the sim card is located. It will be very small and slid into a little holder. Take that SIM card out and make sure that the contacts on it line up with the contacts in its Holder. If the SIM is not in right it will always tell you Insert SIM. These phones rely on that SIM Card for the Information and Other Settings they need to work properly.
If you still get that Insert SIM message then it is possible that your phone was not Programmed Properly at the Place You Bought it. Take it to them and they will fix it Free.
May 11, 2009 | Motorola Mobility RAZR V3
Insert sim card showing
Try your sim card to another phone, or try another sim to that phone just to eliminte the problem. Sim card are easily ruin by static discharge
Jan 03, 2009 | Motorola Mobility RAZR V3
Motorola Razr says insert SIM card when it's already in there
You May Have Fryd Ur Sim Card Did U Try Puttin It In Any Other Phones Besides The Other Model?
Jun 14, 2008 | Motorola Mobility RAZR V3
Location of SIM card in Motorola Razr
Are you guys serious....
Verizon & Alltel (which happened to recently finalize the merge) use CDMA. CDMA does not use SIM cards.
AT&T, T-Mobile, etc. use SIM cards - wheter they are 3G networks, TDMA, etc.
Jan 02, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Sim card problem
good day, try to use other sim if still not work, you have to bring your cellphone to your service center. thanks
Sep 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
60 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
