Question about Canon Rebel XT / EOS 350D Digital Camera
I have a Canon Digital Rebel XTI and the flash pops up but doesn't fire in any mode. Is there something I can do to fix this?
  • 148 Answers
It sounds to me as if the xenon bulb within the built in flash has expired.  It's a quick and easy job for a qualified service engineer to repair this for you.
Posted on Dec 11, 2008
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
My camera rebel xti flash will not work all of a sudden, what could be the problem and how may I fix it?
Does the flash pop up when you try to take a picture in low light in the Green Box Mode? If the flash does not pop up the problem may just be that something sticky is keeping it down. If it pops up but does not fire, the problem is usually either a bad flash tube or the wiring to the flash has broken where the flash head pivots up and down.
When the flash is fully charged the capacitor retains a voltage of over 300 volts even when the camera is turned off and the battery is removed. I've seen several cameras where the owner tried to repair the flash and ended up burning out the entire Main PC Board.
Bob Kilbourn www.camerarepairs.com
Sep 29, 2011 | Canon EOS 400D / Rebel XTi Digital Camera
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I just bought the 430ex II flash and it won't fire on my Rebel XTI.... i read the manual but I'm not sure whats wrong, have any advice?
I assume that flash is turned on. 430ex flash will fire automatically only in AUTO mode. On manual modes you mus manually force the flash to fire.
If flash doesn't fire at all, consider to claim the vendor or let the vendor to check the flash mounted on your camera.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Why does the word, ''busy'' pop up on the canon rebel xti?
If the flash fires a full charge(eg. in a dark environment) then this message will appear whilst it recharges. If the message appears all the time and you cannot take a photo there is most likely a problem. Try taking some pictures without the flash card to eliminate that first.
Apr 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Flash not firing properly
Could be the metering mode you are in. Could be the subject is too far away. Could be ISO is set wrong. Could be the lens aperture can't open up enough. Could be the exposure compensation isn't set correctly. Could be FE Lock is still on and the composition has changed. Does the <flash> icon continue to blink? Then you are too far away.
Sep 12, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 26, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
468 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
