Question about Mamiya RB67 Pro SD Medium Format Camera
Film won't advance
I've just gotten an RB67... After reading the manual, I've loaded the film (220 in a 200 back) correctly (i've even blown the a roll to make sure it was done correctly)... However, when I cock the shutter and release it - the film will not advance. In fact, the red indicator on the exposure counter (I have a Pro-S, not SD) does not appear. Thus, the film back will not allow me to advance the film. I've removed the slide from the back (although, the shutter will release with the slide fully inserted, which isn't supposed to happen). I've tried rotating the back to vertical picture... I've tried using slower shutter speeds... nothing seems to allow me to advance the film.
    Problem Solver:
  • 40 Answers
Perhaps you've already solved the mystery. There are 2 parts to the back of that camera, the film back + the part that it slips onto. And they have little safety latches/pins that couple in order to advance the film & release the shutter. I'm sure those just aren't in the right place. Here in Los Angeles you could take it to any major camera store or repair shop & they've help you out.
Posted on May 10, 2007
Mamiya RB67 Pro S: film counter does not advance, but the film does advance purchase another back same problem. Is there a switch that I'm missing??
If the problem is on the magazine's counter and if the spacing of frames is correct then the counter dial is loose. two screws on the outside front of the top of magazine, two screws in the film chamber hold the top cover. remove leather cover on winding lever loosen screw and remove. you can then remove the complete top housing to expose the counter mechanism.
Oct 30, 2013 | Mamiya Rb67 Pro S Medium Format Camera-...
Why is my canon ae-1 only developing blank film
First thing I would do is sacrifice a roll of film. Load the film as you have been. Then with the back open and tension on the film (do not touch the film over the shutter, advance the film. It may be that you are putting the film on the takeup spool incorrectly. Watch how the film advances on the spool. If it is on the spool incorrectly it will disconnect then not advance. If that does not work it may be a errant takeup spool.
Jul 06, 2012 | Canon EOS-AE-1 35mm SLR Camera
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
Everything seems to function well, actually, I've never used this camera. Got if off of ebay, so maybe I was gypped. Anyways, the film advance lever seems to be stuck. It only goes half way. I can put...
If the lever won't advance even when there is no film in the camera, then I would say there is a problem. (p.s. You haven't told us the make and model)
May 29, 2011 | Cameras
I just bought a Minolta maxxum QTsi from a lady and it had no manual with it, I can't figure out how to load the film. Can you take me step by step on how to load the film and how the camera works when...
Hi, I've found the instruction manual online for you, http://www.mediacollege.com/equipment/manual/konica-minolta/camera/maxxum-qtsi.pdf that way you have it for future reference. For loading film you open up the back of the camera and make sure that the end of the roll of film is aligned with a red mark and then you close the back. For taking pictures you press the shutter button half way in order for it to focus, when the image you want is framed you press the shutter button the entire way and it'll take the photo.
May 13, 2011 | Minolta Maxxum QTsi 35mm SLR Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
Pro-S film back doesn't advance film properly.
There is good chance that the back needs a spring replaced. I've seen them fail many times.
Nov 14, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My Mamiya RB67 triggers and shutter lease lever works but film advance lever doesn't move. Trigger button fired several times but film advance still showing 1.
This is not the best solution as it indicates a faulty film back. The film should advance without resorting to activating the film-wind release lever. That is only for intentionally advancing a partially exposed roll of film. Make sure the multi-exposure lever is not engaged and that the counter does advance and the red mark disappears as you advance to an unexposed frame.
Nov 09, 2009 | Mamiya RB67 Pro SD Medium Format Camera
Shutter will not trigger when film back is attached, only when it is off
Did you made sure the dark slide was removed? Check to see that the firing pins on the camera back are coming through the revolving bracket okay and that they are engaging the pin on the film back (left side). Is there film loaded? You can check without film if you have the multi-exposure lever engaged (red spot visible) and dark slide pulled out.
Nov 06, 2009 | Mamiya RB67 Pro SD Medium Format Camera
My x 370 wont transfer pictures onto the film? The camera looks like it's in good condition. The roles come out blank!
Film cameras directly expose film to light to produce an image: they do not "transfer pictures onto the film", but your phrase is a big clue as it suggests you've only used digital cameras in the past and so may have made a very simple mistake with film loading.
If the film is blank as in transparent, then the film has not been exposed. If it's completely dark then it's been over exposed.
I suspect you mean that the film is unexposed as it's by far the most common fault: cameras like the X-370 have completely manual film loading; the film has to be manually engaged onto the take-up sprockets before closing the back of the camera. After that, correct loading is confirmed by watching to ensure that the rewind crank (top left knob as viewed from rear) rotates every time the film winding lever is used. Note that the frame counter will advance even if the film isn't correctly loaded. Once the film is used up, the winding lever won't operate and the film must be rewound back into the cassette before opening the back of the camera. To do this, you press the recessed button on the underside of the camera and use the rewind crank to rewind the film until you can feel no more resistance at all.
You'll find full instructions on the Norman Butkus website where he's provided a downloadable .pdf manual for your camera for free download.
Hopefully this has solved your problem; if so all I ask in return is for you to rate my answer. If it hasn't, then please add a comment and I'll try to offer other solutions to your problem.
Oct 30, 2009 | Minolta X-370S 35mm SLR Camera
Mamiya RB67 Pro SD Medium Format Camera Logo
359 people viewed this question
Top Mamiya Photography Experts
Marvin
Marvin
DROPNDEAL
DROPNDEAL
Andrew Taylor
Andrew Taylor
Are you a Mamiya Photography Expert? Answer questions, earn points and help others
