Question about Mitsubishi VS-1280 TV
Continuous scrolling My TV, Mitsubishi VS-5014Ca, scrolls vertically and I'm unable to stop it. The TV is old but hasn't been used much. Any suggestions on how to stop the scrolling? Thanks Alph
  • Alph Farrell Mar 09, 2007
    Thanks cramsvik, your help is appreciated.
    Alph
    Scholar:
  • 121 Answers
If you feel up to it, there is probably a potmeter inside that you could try to adjust. I tried this on a TV a long time ago. You should know, though, that there are thousands of volts in some capacitors in there (so I've been told) that might shock you if you're not careful. *Even if the TV has been unplugged!* The capacitors store power and are not automatically discharged when the TV is unplugged. It's the parts on the cathode ray tube that are (most) dangerous, so don't poke around with your fingers or a metal object. I would probably leave this one to a qualified technecian, though. If you do open it and fix it, make sure to get all the dust in there out while you're at it to prevent any fires later. Your TV will have collected a lot of dust.
Posted on Mar 09, 2007
Pc to tv connection keeps scrolling vertically
its probably your caps on the signal module
c2p05 and c2p08 100uf 16v capacitors
did the problem used to only happen when it was cold? = caps
is there rolling bars? is it a dark unstable picture? = caps
let me know if you need further assistance, the caps solder in
Jun 18, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Vs-45607 was a hand me down and did not come with a remote. the picture has very fast rolling vertical lines........Help!
Typically you can open the back case and you will see two screws, one for vertical scroll and one for horizontal scroll. with a rubber head flat head you can adjust this. Please be advised this is very dangerous and has high voltage. Please get a tech to look at this, he must be familiar with this TV.
Sep 03, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Vertical lines on Mitsubishi 62" DLP
the DM and/or the FMT board are going bad. the chassis needs to be rebuilt. check out www.tv-techs.com
Jan 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Scrolling picture on an old big screen
These models have been known to have faulty capacitors on the PIP module as a result thy loose vertical synvh and the picure will roll. The PIP module is no longer available. But if you would like I can post a way for you to bypass the module and if the modle is at fault your tv will work fine, but you wont have PIP anylonger
Feb 23, 2008 | Mitsubishi VS-60719 60" Rear Projection...
Mitsubishi VS-4506R No vertical hold
Rolling picture
had a few with bad capacitors
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Feb 07, 2008 | Televison & Video
Can you tell me how to stop my TV from Scrolling....
You would have to make some checks:1. CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. You can try and change that cap first. Hope this helps
Sep 01, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Scrolling Input Screen
have tech take a look at your tv the problem is very technical for you to handle the vertical circuit is defected.good luck.a check should be made on the eeprom.
May 06, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Mitsubishi VS-60707
Have same problem on 42in. Problem appears to be a short on one of the boards. If hold the cable input connection and give it a jiggle, it will usually pop in.
May 05, 2007 | Mitsubishi VS-60707 60" Rear Projection...
Vertical rolling
Does you set have PIP (picture in picture)? If it does then the PIP module has a bunch of capacitors that have gone bad (dried out and leaked) causing you to loose vertical sync. Vertical synchronization is what locks your picture keeping it from rolling. Even if you don't have PIP then still you have a vertical sync problem. The set would have to be checked by a tech to find exactly what's happening. Stargazer
Mar 04, 2007 | Mitsubishi WS-55807 TV
Televison & Video Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
