Question about Microsoft Likom HD19A 19" LCD Monitor
Vusys hd19a monitor is always on standby
I have a vusys hd19a monitor. it has the yellow standby light on but never powers up, therefore i never get anything on the screen and the green light never comes on,....any ideas on the problem???
Cut and paste from another site:
I was called to repair similar incident last week. A Compaq box (don't remember the model) with a 'smart' usb keyboard. By this I mean that the keyboard had a row of what I'll call hot buttons. The client had pushed a button with a moon on it causing the monitor to go into sleep mode. I suspect that whatever key you pushed had the same effect.
After plugging a known good monitor into the faulty box I verified that the box was OK. This left me to think the monitor itself had a problem. Plugged the suspect monitor into a known good machine.. and it worked fine!!!
Set machine and monitor to original configuration and still had no video. Decided that the monitor was too smart for its own good and maybe there was something in the monitors menu. Pushed and held the 'menu' button on the monitor for a few seconds and menu comes forward. Green power led also comes on (surprising me) so I powered up the computer and lo and behold the problem is fixed!
Posted on Jan 20, 2009
Manual www princetongraphics
try taking the batteries out or go to the shop where you bought it and go from there...good luck lol :-P
Oct 10, 2013 | Princeton Digital VL1919 19" Monitor
LCD Monitor will power in and when connects to modem the power button is green then turns orange, what is the problem?
When the monitor button turns to yellow that means the monitor is on standby mode. Try rebooting the the computer after you have connected it to your modem. If the light goes to yellow again check that the computer is on and that all the cables are connected properly. HP Computer monitors are a little confusing, Sometimes depressing the power button again while it is yellow will turn it on and should so green.
Jul 21, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Power plug
Most LCD monitors use IEC sockets - these are 3pins sockets.
Power leads are available from computer shops and electrical stores.
Jun 06, 2010 | Microsoft Likom HD19A 19" LCD Monitor
The yellow light on the front of the tv fades in and out constantly while the tv is off.
When the TV is off but still connected to the power the light is usually yellow/orange/amber signifying that TV is in standby mode. If you do not want to see the yellow light, all you have to do is unplug the power cord. But by doing that you may have to reconfigure the TV.
Jan 15, 2010 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Exactly the same problem on boot-up with Likom (Futura) HD19A mon
ok, if your computer is able to boot until you able to use it yet the screen is showing none yet working too, i suggest you change your data cable from the computer to the monitor. i once had a problem like that. it must have been damaged by high input of charge and burnt off though it did not show.
thanks,
wonder
Sep 18, 2009 | Microsoft Likom HD19A 19" LCD Monitor
I have a vusys monitor and for some reason when i plug it in to my computer it displays a message "out of range" and i recieve no picture any solutionfor this please?
Either
1.) The resolution/frequency your computer is currently running at is a higher resolution then the monitor can handle. Use a different monitor, if it works then lower resolution and replace with the vusys.
2.) You have physical failure. Your video card, cable, or monitor is bad. (Or you don't have it plugged into the right card). Try a different monitor if it works then and you did step one, then you probably have a bad cable or monitor.
Apr 30, 2008 | Computers & Internet
HD19A / 19-Inch light flickers but no display
One of 2 possibilities come to mind.
1,  The vga chord is loose on the back of the monitor.
2, Your resolution is set too high or low to be displayed.
The blinking light means that the monitor is either not getting or understanding a signal.
Hope this helps.
Oct 12, 2007 | Microsoft Likom HD19A 19" LCD Monitor
Monitor problem
I have had similar problems. It would appear that the power supply is at fault, not the monitor.
Dec 27, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Monitor Start up
It is the same problem I experienced and now it suddenly stopped and dead.
what the manufacturer of the unit has to say about inherent design fault which they are liable under UK consumer law to rectify within 6 years
And incidently who are manufacturer to this Licon make is please
Jun 29, 2006 | Microsoft Likom HD19A 19" LCD Monitor
Microsoft Likom HD19A 19" LCD Monitor Logo
580 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
