Question about Kenmore 98702 Stacked Washer/Dryer
Brand new kenmore 97812 when in a any wash and spin cycle the agiter kicks on for 5 seconds then goes off for 5 minutes. What is wrong
How do I replace the drain hose?
Posted on Jul 25, 2010
Ge washer whre5550k2ww tub wont spin
It may be the rotor position sensor. i used you tube tutorials. There are many washers that are the same, but different brand names. Matag, whirlpool, kenmore elite oasis, all the same and parts. I got lucky and a cleaning hack. It was to clean between the tob and thre shell. This is located up under where you cannot see, use a mirror and look wherr your detergent, fabric softer and bleach dispensers are. And i found a tutorial on diagnosting code that will do it for you. I think it was holding a cycle 5x for 5 seconds and it will tell you. Whats wrong, Good Luck
Jun 27, 2016 | GE Washing Machines
Washer won't spin. Motor goes thru cycle but not spinning
My kenmore washer won't spin - EASY FIX (PART ONE ...
? 5:45
www.youtube.com/watch?v=fRxKs2EEfbU
Feb 1, 2013 - Uploaded by Michael Borders My Kenmore washer's agitator stopped spinning my cloths during the wash. NO BIG DEAL!!!! EASY and ...
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - If your old or new washing machine does not spin we have some diy fix tips ... Fix Washing Machine That Won't Drain - Washer Not Draining ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Nov 02, 2015 | GE GTWN4250MWS 27" top-load washer with...
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore washer stops spinning a few seconds in to the cycle.
Sounds like the brushes are struggling to get enough power to the motor to spin. Renew motor brushes
Apr 21, 2012 | Kenmore Washing Machines
I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Feb 04, 2010 | Kenmore 24832 Top Load Washer
My kenmore won't pump out the water. what could
couple of possible reasons and this will vary by brand of machine...lid switch could be bad...some machines will wash or agitate with lid up but will not spin unless lid is closed..others will not do nothing with lid up....some brands will not spin if the water level switch can detect water in the tub...this means your machine didnt pump the water out of the machine so it could spin couple of reasons for this 1 bad pump or bad pump motor(some machines have a pump that is driven by a drifferent motor than the one that drives the transmission)usually these machines use the water level switch to activate(turn on/off) the pump when the machine goes into spin cycle... some machines the pump wil come on and stay on for the entire spin cycle...some machines the belt will be bad and you just need a new belt....first thing to do is see if raising the lid will turn the machine off when it is in wash cycle if it does not..then it will in spin cycle..if the machine will not work in spin cycle the lid switch will be the reason why..
Sep 13, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Machine fills with water, sits for a couple of minutes, agitates for 15-30 seconds, stops for 3-5 min. agitates for 15-30 secs etc... When rinsing, empties water starts to spin, kicks into high gear for a...
Your motor/clutch combo is on the way out. The motor is overheating and turning off. Cools down and restarts.
You need a new motor/clutch combo or a new washer. I do not recommend another GE.
Jul 07, 2009 | GE Washing Machines
Washing machine does not drain during rinse cycle?
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 17, 2009 | Whirlpool LSQ9600L Top Load Washer
Kenmore 80 series washer clothes are still dripping wet
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer quit working
it may be waiting for a faulty heater to kick in. try it on a cold water wash, no heat and see if it continues the full wash. if it does not then it may have a faulty timer.
Mar 16, 2009 | Washing Machines
Kenmore 98702 Stacked Washer/Dryer Logo
412 people viewed this question
Fordexpert
Archaeology
Archaeology
reliableservice
