Question about Fantom Drives 300 GB Hard Drive
I can't download from my FD device to my computer
I have a Fantom drivers 300GB external hard drive, that purchased 3 years ago, I used it for 2 years and it was fine never had a single problem with it, the I kept it in my drower for about a year, i took it out yesterday to use it and it didn't download to my computer, i plaugged the power supply in to the wall, turned it on all the lights came on, I plugged the USB in to my computer nothing happen, no download, and all I keep hearing from my Hard Drive was TIC..TIC...TIC.
please try to help me with my problem, I have a lot of very important DATA on my device that I need to get.
Thank you
2 Suggested Answers
marked
  • 6487 Answers
SOURCE: I can't download from my FD device to my computer
First thing that you do here is to try using a different cable because sometimes its only a problem with the cable that you're using and also try to connect the device ona different usb port on your computer...
Posted on Dec 11, 2008
My Fantom 1G GForce is not recognized by my computer, the drive isn't spinning and it is making a ticking sound. Help!
if your computer came with a motherboard disk the drivers could be on it
check all leads that are attached to this external hard drive make sure they are securely seated
click strart control panel administrive tools computer management device manager scroll through all of the devices if you see a yellow question exclamtion ? ! mark or a red X you will need to reinstall the driver right click on the mark select update driver if you can see the usb drive and its
not working ports(com&lpt)right click update driver
if this fails to fix the problem you might need to install a usb 2 or 3 card they can be easily installed and are very cheap
hope this helps
Aug 04, 2011 | Fantom Drives FD GForce MegaDisk 2TB ...
I have a Fantom Titanium II 500 GB external hard drive. It is not being recognized on any of my Windows 7 computers (64 bit Gateway and 32 bit Lenovo). The light on the drive is a constant blue. I tried...
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
Apr 24, 2011 | Fantom Titanium Hard Drive
My Maxtor External Hard Drive is not working
You need to check it with Norton Utilities. I hope you still have this hard drive (this posting is posted 5 years ago) and it is not dead yet, so you can copy all of the valuable files to your other data storage.
Here is the link to download the 30 day trial (free):
http://download.cnet.com/Norton-Utilities/3000-18512_4-10907620.html
Dec 19, 2009 | Maxtor 300GB ONE TOUCH 2 USB2- 7200RPM...
Drive is not switched on
check the input power switch on the rear of the unit...
It should be on 240V. Turn off the computer, then move the switch back and forth a couple of times... set to 240V. this assures the coorect input power to the external drive.
Secondly, move the USB port to another USB port on your computer. If it works fine, then it is a bad USB port.
Third, check the device driver in device manager on your software. try updating the driver... This solves a potential driver issue.
Good Luck,
Jeff
Sep 13, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
My IBM Thinkpad T22 has one usb port, in the back, so I bought a Targus 4-port USB hub. My flashdrives work, even my 16GB FD does. But I plugged in my Western Digital 250GB external hard drive and the...
You need to reinstall your usb drivers.
For that first go to my computer property ->hardware -> device manager
then right click on usb drivers and uninstall all usb drivers 1 by 1.
Then restart computer then check .
If problem still remain then enter in bios setup then go to ide or advanced option then enable "Legacy 2.0" then save settings then restart .
soem times old computer not supports new usb high speed device .
Aug 08, 2009 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
Make sure that your power supply is ok, I mean to say that check the connction. If it is ok then check that you are giving the actual power input to your hard drive. Don't connct the hard drive again. First check the power supply to the wall is having the same out put that required by the hard drive as input. Let me know the result.
Dec 11, 2008 | Fantom Drives 120 GB Hard Drive
Is your drive getting detected in your computer ?
If no then go to control panel and add hardware to get it detected .
MY HARD DRIVE IS NOT DOWNLOADING WHEN CONNECTED TO THE COMPUTER
Clicking coming from the hard drive normally indicates that the drive has failed. Unfortunately, you will need to purchase a new hard drive, unless the warranty on your hard drive is longer than 3 years. Your data can be recovered. I know the best buy geek squad can have the hard drive sent out for data recovery, however the cost for data recovery is quite expensive.
Dec 10, 2008 | Fantom Drives 120 GB Hard Drive
Maxtor one Touch 300GB no steady green light
The USB Isn,t supplying/providing enough Power to the device.
Search e-bay or similar for a 2 into 1 USB Cable.
Then power the unit with 2 USB Ports on the Computer.
2 x USB Into 2 x Sockets On P.C. 1 x Into Device Drive.
This will be enough power to operate the Device Correctly.
I,ve done this on several external Drives, never failed for Me.
Mike @ compurepair.
Mar 16, 2008 | Maxtor OneTouch II external hard drive...
Drive not being recognized
Have you tried this in another PC with, say, WinXP? If it worked then it may be 1 of 2 problems:
1) Driver Issue- you may use a compatible driver and not necessarily a "Fantom" driver. WinME needs drivers for these devices unlike WinXP
2) The USB port is not giving enough power to the drive for it to run (a problem common in older PCs). I have an external USB harddisk that needs to use 2 USB ports in my old Dell laptop since 1 USB port can't supply the power it needs. The cable should have a dual-USB jack on one end, this is so you could use the power from the other USB port.
Hope this helps
Jan 20, 2008 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom Drives 300 GB Hard Drive Logo
74 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
